Does it do that through the new API (like I thought) or is it still the same method as before?uiScribe still overrides the default System Log page. We could mount to a separate page, but you'd then have 2 logging tabs - one for default syslog (i.e. messages) and another tab for everything else.
That wouldn't be great UX.
no problem. We're all here to learn! Since uiscribe is just overriding a page and doesn't need a new tab it's dead simple. The complex stuff is when overriding unused pages and needing to insert a tab. the new api makes adding a tab much simpler, and the user mount points removes the need for me to override obscure unused pagesDoes it do that through the new API (like I thought) or is it still the same method as before?
I have a hard enough time remembering how my script works, I need to learn to keep my mouth shut about other people's scripts ...
This is dumb silly really stupid question I need to clarify, sorry I'm on some serious pain killers and my mind is fuzzy, and will be for some time.In response to the recent issues uncovered with upgrading syslog-ng, and a couple things I've picked at, scribe 2.4.2 is up.
Update available for /opt/etc/logrotate.d/afpd.
(a)ccept, (r)eject, or (v)iew diff for this file? v
--- /opt/etc/logrotate.d/afpd
+++ /opt/share/logrotate/examples/afpd
@@ -1,6 +1,4 @@
/opt/var/log/afpd.log {
-minsize 1024k
- daily
rotate 2
postrotate
/usr/bin/killall -HUP syslog-ng
@@ -1,6 +1,4 @@
Until you're used to them diffs can be a bit difficult to understand, even without pain meds.This is dumb silly really stupid question I need to clarify, sorry I'm on some serious pain killers and my mind is fuzzy, and will be for some time.![]()
Not quite. Minsize means it has to be at least that big to rotate, regardless of the period specified. So as it was before, the file had to be at least 1M, AND it had to have been at least a day since the log was last rotated. In other words, both conditions had to be satisfied to rotate the log. Yes, on our routers, we only run logrotate once a day at 00:05, but on other systems, logrotate might run every hour, or even more often.The new afpd filter, the - are removed and the + are added?
I loose minsize 1024k for the default 4MB max? and no daily rotate, only after the maxsize of 4MB?Code:Update available for /opt/etc/logrotate.d/afpd. (a)ccept, (r)eject, or (v)iew diff for this file? v [/quote] Yes, more accurately, the lines marked - are only in the first file (/opt/etc/logrotate.d/afpd), the lines marked + are only in the second file (/opt/share/logrotate/examples/afpd), and unmarked lines are in both files. [quote] --- /opt/etc/logrotate.d/afpd +++ /opt/share/logrotate/examples/afpd @@ -1,6 +1,4 @@ /opt/var/log/afpd.log { -minsize 1024k - daily rotate 2 postrotate /usr/bin/killall -HUP syslog-ng
The first number pair (1,6) is the starting line number(1) and number of lines shown that are part of the first file(6). The second pair is the starting line number(1) and the number of lines shown that are part of the second file(4). The pairs are preceded by - and + as a reminder of which file the pair refers to. Obviously, this isn't important in a files as short as these, but if I'm looking a diff between, say, one version of scribe and another, and I see a difference I want to investigate, the first number of each pair tells me where to find that section in each file.This line totally looses me.
ThanksCode:@@ -1,6 +1,4 @@
destination messages {
file("/opt/var/log/messages" template("${R_DATE} ${HOST} ${MSGHDR}${MESSAGE}\n") );
rm -f /tmp/mnt/USBNAME/entware/var/log/messages
This filter should work, right?Did somebody already write a filter for NextDNS?
# log all NextDNS logs to nextdns.log
destination d_nextdns {
file("/opt/var/log/nextdns.log");
filter f_nextdns {
program("nextdns");
log {
source(src);
filter(f_nextdns);
destination(d_nextdns);
flags(final);
#eof
From the scribe main menu, use "uf" to update the filters. One of the filters it should ask you about is /opt/etc/logrotate.d/A00global. Updating A00global will set the maximum log size to 4M. That should trim them down at the next logrotate run. If you've done this and are STILL having problems, post or PM me the results ofI'm still getting heavy lag in the browser when viewing scribe logs. I saw comments saying reduce the log sizes. But I am not finding it clear how to go about that. Can someone explain what I need to do to set a default setting that won't lag the browser?
ls -lart /opt/var/log
If you've done this and are STILL having problems, post or PM me the results...
username@DSL-AC68U-0628:/tmp/home/root# ls -lart /opt/var/log
-rw-r----- 1 nobody root 640839 Feb 12 05:18 dnsmasq.log1
-rw-r----- 1 nobody root 3120859 Feb 12 05:20 dnsmasq.log2
drwxr-xr-x 2 username root 4096 Feb 12 06:43 .
drwxr-xr-x 7 username root 4096 Feb 12 17:44 ..
-rw------- 1 username root 382640 Feb 12 20:32 messages
-rw-r----- 1 nobody root 473747 Feb 12 20:34 dnsmasq.log
-rw------- 1 username root 3722 Feb 12 20:35 logrotate.log
-rw------- 1 username root 48219 Feb 12 20:35 syslog-ng.log
-rw------- 1 username root 10353438 Feb 12 20:35 skynet-0.log
The skynet log is too big and probably isn't being collapsed hourly through skynet. I think therein lies your problem.Yeah I think I have been running with the default 4MB. I was trying to lower it to 1MB to see if that helped but wasn't sure how to do it properly or if it would resolve the issue. Here is the ls output:
Code:username@DSL-AC68U-0628:/tmp/home/root# ls -lart /opt/var/log -rw-r----- 1 nobody root 640839 Feb 12 05:18 dnsmasq.log1 -rw-r----- 1 nobody root 3120859 Feb 12 05:20 dnsmasq.log2 drwxr-xr-x 2 username root 4096 Feb 12 06:43 . drwxr-xr-x 7 username root 4096 Feb 12 17:44 .. -rw------- 1 username root 382640 Feb 12 20:32 messages -rw-r----- 1 nobody root 473747 Feb 12 20:34 dnsmasq.log -rw------- 1 username root 3722 Feb 12 20:35 logrotate.log -rw------- 1 username root 48219 Feb 12 20:35 syslog-ng.log -rw------- 1 username root 10353438 Feb 12 20:35 skynet-0.log
The only large one is skynet-0.log, and it isn't touched by logrotate anyways. Skynet should clear it hourly. If you're getting over 10 gigs in 35 minutes though, that's HUGE, so I suspect for some reason the Skynet scrub isn't happening. It's just past the hour now, how big is skynet-0.log now?Yeah I think I have been running with the default 4MB. I was trying to lower it to 1MB to see if that helped but wasn't sure how to do it properly or if it would resolve the issue. Here is the ls output:
sh /jffs/scripts/firewall settings syslog /opt/var/log/skynet-0.log
What's the output ofI just reset the logs on Skynet, and set the log file location using this command:
Not sure if that will fix it, I don't see a command to set the log to collapse hourly in the Skynet command.Code:sh /jffs/scripts/firewall settings syslog /opt/var/log/skynet-0.log
cru -l
What's the output of(that's an 'el' not a 'one')Code:cru -l
username@DSL-AC68U-0628:/tmp/home/root# cru l
00 2 * * Thu sh /opt/share/diversion/file/update-bl.div reset #Diversion_UpdateBL#
20 5 * * * sh /opt/share/diversion/file/rotate-logs.div #Diversion_RotateLogs#
20 17 * * * diversion count_ads count #Diversion_CountAds#
5 0 * * * /opt/sbin/logrotate /opt/etc/logrotate.conf >> /opt/tmp/logrotate.daily 2>&1 #logrotate#
25 5 * * * sh /jffs/scripts/firewall banmalware #Skynet_banmalware#
25 1 * * Mon sh /jffs/scripts/firewall update #Skynet_autoupdate#
0 * * * * sh /jffs/scripts/firewall save #Skynet_save#
40 */12 * * * sh /jffs/scripts/firewall debug genstats #Skynet_genstats#
*/5 * * * * /jffs/scripts/connmon generate daily #connmon_daily#
2 * * * * /jffs/scripts/connmon generate weekly #connmon_weekly#
3 */3 * * * /jffs/scripts/connmon generate monthly #connmon_monthly#
12,42 * * * * /jffs/scripts/spdmerlin generate #spdMerlin#
The firewall save job should scrub the log, so I wonder why it isn't running. On the other hand I don't have that genstats entry.Code:username@DSL-AC68U-0628:/tmp/home/root# cru l 00 2 * * Thu sh /opt/share/diversion/file/update-bl.div reset #Diversion_UpdateBL# 20 5 * * * sh /opt/share/diversion/file/rotate-logs.div #Diversion_RotateLogs# 20 17 * * * diversion count_ads count #Diversion_CountAds# 5 0 * * * /opt/sbin/logrotate /opt/etc/logrotate.conf >> /opt/tmp/logrotate.daily 2>&1 #logrotate# 25 5 * * * sh /jffs/scripts/firewall banmalware #Skynet_banmalware# 25 1 * * Mon sh /jffs/scripts/firewall update #Skynet_autoupdate# 0 * * * * sh /jffs/scripts/firewall save #Skynet_save# 40 */12 * * * sh /jffs/scripts/firewall debug genstats #Skynet_genstats# */5 * * * * /jffs/scripts/connmon generate daily #connmon_daily# 2 * * * * /jffs/scripts/connmon generate weekly #connmon_weekly# 3 */3 * * * /jffs/scripts/connmon generate monthly #connmon_monthly# 12,42 * * * * /jffs/scripts/spdmerlin generate #spdMerlin#
That is the new webgui stats generation to get a nice graphs page under the Firewall tab.The firewall save job should scrub the log, so I wonder why it isn't running. On the other hand I don't have that genstats entry.
( sh /jffs/scripts/firewall settings webui enable|disable ) Enable/Disable WebUI
Yeah, at this point I think it's either (a) you have an issue with your Skynet installation, or (b) you're really getting ~20 gigs per hour of Skynet logs which is massive, and I'd think your internet would barely be functional at that rate. Judging from what I have now, I get about 20 megs/hour of Skynet logs - 3 orders of magnitude less!The firewall save job should scrub the log, so I wonder why it isn't running. On the other hand I don't have that genstats entry.
...I think it's either (a) you have an issue with your Skynet installation...
Feb 13 08:47:01 AC3100 syslog-ng[10549]: The current log file has a mismatching size/inode information, restarting from the beginning; state='affile_sd_curpos(/var/lib/logrotate.status)', stored_inode='7925593', cur_file_inode='7937689', stored_size='207', cur_file_size='207', raw_stream_pos='0'
Welcome To SNBForums
