Wireguard Session Manager - Discussion (2nd) thread
Sorry to chip in, but would this require you to copy Home.conf to the remote peer? As it is not in the list of files to copy over, or is this command not requiring this?
Yes, and I'm sure @JGrana would know that is required until I push wireguard_manager Beta v4.15b2 with the updated instructions....assuming that is the correct fix.
e.g.
    WireGuard Site-to-Site Peers Home and Cabin created
    Copy Cabin/Home files:
-rw-rw-rw-    1 admin    root           645 Jan 27 18:59 Cabin.conf
-rw-rw-rw-    1 admin    root            45 Jan 27 18:59 Cabin_private.key
-rw-rw-rw-    1 admin    root            45 Jan 27 18:59 Cabin_public.key
-rw-rw-rw-    1 admin    root           649 Jan 27 18:59 Home.conf
-rw-rw-rw-    1 admin    root            45 Jan 27 18:59 Home_private.key
-rw-rw-rw-    1 admin    root            45 Jan 27 18:59 Home_public.key
    to remote location
    Import Home on remote site using 'import Home type=device'
    Press y to import Home or press [Enter] to SKIP.
y
    [✔] Config Home import as wg22 Site-to-Site (FORCED as 'server') success
On Home, external site Cabin has been automagically 'imported'.....so
On Cabin, try
e  = Exit Script [?]
E:Option ==> import Home type=device
:) I assume it works?
Thanks, did the import Home type=device
And it now shows nicely!
(BTW, I saw the later post and yes, I had already copied Home.conf to the remote site)
And. yes, the iPhone peer, setup on Home is working!
Brilliant :)
Thanks for taking the time to test/provide feedback on the wireguard_manager Site-to-Site feature.
Just one thing remains...
Do the stats for the connection show correctly? i.e. for a 'client' Peer connecting to a commercial WireGuard ISP, it is usually useful to see how much data is being transferred per hour.
e.g.
Jan 28 11:00:00 RT-AX86U-22B0 (wg_manager.sh): 31069 wg11: transfer: 7.25 MiB received, 1.87 MiB sent        0 Days, 04:33:19 from 2022-01-28 06:26:41 >>>>>>
Jan 28 11:00:00 RT-AX86U-22B0 (wg_manager.sh): 31069 wg11: period : 7.22 MiB received, 1.86 MiB sent (Rx=7574190;Tx=1954877)
Not sure if this is something that the Site-to-Site connection already shows or requires you to manually request?
e  = Exit Script [?]
E:Option ==> generatestats
    wg11: transfer: 7.25 MiB received, 1.87 MiB sent        0 Days, 06:07:19 from 2022-01-28 11:26:41 >>>>>>
    wg11: period : 7.23 MiB received, 1.86 MiB sent (Rx=7572481;Tx=1954811)
When doing the list command, the transfers are displayed, and are correct. The Cabin router reboots once or twice a day right now - dnsmasq Tainted errors...
Here is list from Home:
E:Option ==> list
        interface: wg21  Port:61820     10.9.8.1/32                     VPN Tunnel Network      # Home - 192.168.1.0/24
                peer: a2Y9jgXsX8fq0K4nIgewAeIoOG8DT4gPGnqfLU4ddS0=      10.9.8.2/32             # Cabin Site-to-Site LAN 192.168.2.0/24
                 latest handshake: 29 seconds ago
                 transfer: 74.78 MiB received, 43.32 MiB sent           0 Days, 17:51:46 from 2022-01-27 13:42:44
                peer: dnr70S9aDzbx82AVVDR3+Ba0jtI7zCe2U4QoLF2mXH0=      10.9.8.3/32             # iphone13 "Device"
                 latest handshake: 1 minute, 5 seconds ago
                 transfer: 170.43 MiB received, 1.14 GiB sent           0 Days, 17:51:46 from 2022-01-27 13:42:44
                peer: PMorJ8SxpxU9O9W7irJ8jnVWq9LLBdxEqxpYmKQ/LRg=      10.9.8.4/32             # iPad "Device"
        WireGuard ACTIVE Peer Status: Clients 0, Servers 1
And Cabin:
E:Option ==> list
        interface: wg22  Port:61821     10.9.8.2/32                     VPN Tunnel Network      # Cabin - 192.168.2.0/24
                peer: VXlOz/BkxGWpYbvqVzDjz7tl/QkZkADrmpq07AT8FCM=      10.9.8.1/32             # Home - 192.168.1.0/24
                 latest handshake: 22 seconds ago
                 transfer: 25.53 MiB received, 57.74 MiB sent           0 Days, 07:42:26 from 2022-01-27 23:53:57
The generatestats command is somewhat confused. It might be related to the time issue. Here is generatestats on Home
        Cabin: transfer: 74.85 MiB received, 43.40 MiB sent             0 Days, 17:54:23 from 2022-01-27 13:42:44
        Cabin: period : -418832711 Bytes received, -372768768 Bytes sent (Rx=-418832711;Tx=-372768768)
        iphone13: transfer: 170.56 MiB received, 1.14 GiB sent          0 Days, 17:54:23 from 2022-01-27 13:42:44
        iphone13: period : 143.36 KiB received, 0 Bytes sent (Rx=146801;Tx=0)
And from Cabin:
        Home: transfer: 25.62 MiB received, 57.81 MiB sent              0 Days, 07:45:09 from 2022-01-27 23:53:57
        Home: period : -60775465 Bytes received, -110016593 Bytes sent (Rx=-60775465;Tx=-110016593)
Note that I added another peer device to Home - iPad. It works great!
E:Option ==> list
I've uploaded wireguard_manager Beta v4.15b2 - might be cosmetically pleasing/useful?
e.g. Annotation/tag/comment has always been allowed for a Peer, but it was never actually applied for a Road Warrior 'device' Peer...
.......everything after the comment keyword is free form text to be applied.
e  = Exit Script [?]
E:Option ==> peer iPad comment This is a better description than just 'device'!
And from Cabin:
OK Thanks, my generatestats suspicions are confirmed, I'll take a look.
EDIT: Probably these may fix the issue:
On Cabin
TS=$(date +%s);sqlite3 /opt/etc/wireguard.d/WireGuard.db "INSERT into traffic values('Home','$TS','*','*','*','*');"
TS=$(date +%s);sqlite3 /opt/etc/wireguard.d/WireGuard.db "INSERT into traffic values('Home','$TS','0','0','0','0');"
On Home
TS=$(date +%s);sqlite3 /opt/etc/wireguard.d/WireGuard.db "INSERT into traffic values('Cabin','$TS','*','*','*','*');"
TS=$(date +%s);sqlite3 /opt/etc/wireguard.d/WireGuard.db "INSERT into traffic values('Cabin','$TS','0','0','0','0');"
Hey!
Never seen this before
***ERROR: WireGuard 'client' doesn't have a LOCAL IP Address! - try 'peer wg12 ip=xxx.xxx.xxx.xxx/32'?
(wg_manager.sh): 4893 WireGuard client service ('wg12') NOT running.
I get it when I start, stop, restart peer.
Hey!
Dont you get any ip in your .conf file? Or it's not just imported properly?
Compare your .conf content (Address: ) and your imported ip
E:Option ==> peer wg12
On Cabin
On Home
OK, I did these commands - and it fixed the funny date/time issue. Looks good.
As a side, get this.
I did these commands on an airplane flying somewhere over Chicago USA.
I fired up the Wireguard app on my iPad. Worked.
SSH’d into Home (using the local LAN address/wireguard tunnel).
Did the Home commands.
Then ssh’d (over a another wireguard tunnel) to the remote Cabin and ran the commands there.
Everything worked. Incredible.
Think I got the error after WGM update. Solved it by deleted the peer and added it back.
FYI, just a couple of minor typos
Thanks, corrected.
an awful lot of detailed documentation for a script that started out as a quick and dirty WireGuard module installer!
Yes... but only a small part is related to the actual usage of wgm as I choose to write this as a tutorial it shows more about how to setup the system so it works as intended while also trying to add in info about why and how to integrate with other scripts as YazFi, Transmission and Unbound.
Maybee I just have too much spare time
Hi need help?
Requesting WireGuard VPN Peer start (wg11)
        wireguard-clientwg11: Initialising Wireguard VPN 'client' Peer (wg11) to premium.paakkya.tk:7070 (# N/A) DNS=216.103.130.130,176.103.130.131
iptables v1.4.21: Bad IP address "176.103.130.130,176.103.130.131"
Try `iptables -h' or 'iptables --help' for more information.
        wireguard-clientwg11: Initialisation complete.
        WireGuard ACTIVE Peer Status: Clients 1, Servers 0
Hi need help?
It appears to be a syntax error for iptables. In which wg11.conf parameters you enter these IP address? I don’t have two ip in my config file and don’t have such issue.
Hi need help?
I have 2 dns in my conf file and wgm only imports the first one. Dont know why it failed in your case.
To resolve, run:
E:Option => peer wg11 dns=94.140.14.14
(Updated to new adguard dns as they changed)
There may be more issues, look at peer by:
And check if you have dual ips in more places.
I deleted the wg21 files before. How can I recreate them?
e  = Exit Script [?]
E:Option ==> peer help
    peer help                                             - This text
    peer                                                  - Show ALL Peers in database
<snip>
    peer new [peer_name [options]]                        - Create new server Peer e.g. peer new wg27 ip=10.50.99.1/24 port=12345
but simply issuing
e  = Exit Script [?]
E:Option ==> peer new
    *** Ensure Upstream router Port Foward entry for port:11503 ***
    Press y to Create 'server' Peer (wg23) 10.50.3.1/24:11503 or press [Enter] to SKIP.
will pick the next free 'wg2x' interface (in my case 'wg23' as both 'wg21' and 'wg22' are currently defined), and configure it with appropriate default values e.g. VPN Tunnel Subnet and ListenPort (which may be customised later to your personal preference)
Siri Shortcuts works perfectly with wgm... very convenient way to switch between clients...
Thanks guys
Thanks guys
If you use diversion addons there is a ready made shortcuts available.
Depends on your preference, you can combine all your shortcuts into one single shortcuts with selection menu like diversion shortcuts.
