ZebMcKayhan
looks ok... iptables confirmes catching DNS packages and sending them to WGDNS1 Chain... but I'm missing the output of:
iptables -nvL WGDNS1 -t nat
to see which packages gets redirected where in the WGDNS1 chain.Code:iptables -nvL WGDNS1 -t nat
There's your problem. dont know why wgm does not populate the DNS rules in your system (@Martineau ?)
E:Option ==> stop wg11
E:Option ==> peer wg11 dns=46.227.67.134
E:Option ==> start wg11
Perhaps wgm gets confused as you have 2 ipv4 DNS populated into wgm, but wgm can only redirect to one (did you get both from your import?). maybe try to change wg11 DNS to only your first one, then restart the peer and see if there is any difference?
Code:E:Option ==> stop wg11 E:Option ==> peer wg11 dns=46.227.67.134 E:Option ==> start wg11
and see if the rules appears in WGDNS1 chain
crap... then I have no idea, think that @Martineau will need to look at your output to figure out why wgm does not populate your WGDNS1 rules. meanwhile, could you post the output of:Got both from import.
Makes no difference.
E:Option ==> start wg11 debug
You will need to provide a FULL debug trace for
wg11
wg11
is stopped, then assuming wg11
is not in Policy mode (auto=Y
) issuesh -x /jffs/addons/wireguard/wg_client wg11
auto=P
) usesh -x /jffs/addons/wireguard/wg_client wg11 policy
am_settings_set wgm_ExecuteResults xxxxxxxxxxxxxxxx
but could someone please kindly provide the .method to decode the Base64 string in my .asp code.
ThanksHow To Encode and Decode Strings with Base64 in JavaScript | DigitalOcean
Learn how to encode and decode strings with Base64 in JavaScript. This guide covers btoa(), atob(), Buffer, modern APIs, and practical examples.www.digitalocean.com
Thanks for the debug trace, and it shows you are currently running
wg_client
+ VERSION=v4.16.19
+ CONFIG_DIR=/opt/etc/wireguard.d/
+ INSTALL_DIR=/jffs/addons/wireguard/
+ SQL_DATABASE=/opt/etc/wireguard.d/WireGuard.db
+ nvram get buildno
wg_manager
Beta v4.17b8 Last Updated Date: 08-Jun-2022e = Exit Script [?]
E:Option ==> uf dev
wg_client
Last Updated Date: 22-May-2022VERSION="v4.17.6"
wgm stop wg11;wgm start wg11;iptables --line -t nat -nvL WGDNS1
There's also a base64.js within the firmware webui, tho nothing is currently using it, so it may disappear in the future.Thanks
Looks like there were some problem with wgm loading your wireguard kernel module possibly. Wgm seems to install fine but were not able to setup the wg21 Wireguard server. What firmware are you on? You could still use wgm but chances are you will get the same error when trying to start your imported client.Hello everybody, I own GT-AX11000 and I want to use WireGuard. I tried to install from amtm but get some error. But Still amtm is showing that I installed it. What are other simple steps to use it? Should i see somewhere web'ui to manage it? I have a VPN provider, which supports WG and I can get that file, but where to add it and how? My plans is to use WG with VPNdirector rules, so is it possible or no?
I am running Merlin 386.5_2. Thanks for the web link, I bookmarked it, but it seems a lot to do to get it working. Maybe it is better to wait when more developed release outs...Looks like there were some problem with wgm loading your wireguard kernel module possibly. Wgm seems to install fine but were not able to setup the wg21 Wireguard server. What firmware are you on?
There is a guide for importing client files and setting it up to autostart, create rules and so on here:
https://github.com/ZebMcKayhan/WireguardManager#setup-wgm
Scroll up for clickable table-of-content to easier find what you are looking for.
No Wireguard GUI has been released yet, but there is an option to duplicate the VPNdirector rules into wgm (menu item 12) if you find that easier then just enter the rules in the wgm menu.
Not really, just import you config file:I am running Merlin 386.5_2. Thanks for the web link, I bookmarked it, but it seems a lot to do to get it working. Maybe it is better to wait when more developed release outs...
import MyVPNConfig.conf
peer wg11 rule add vpn 192.168.1.30 comment MyComputer
peer wg11 auto=P
Well OK.....No Wireguard GUI has been released yet,
wg_manager
Beta v4.17b9wg_manager
.Dummy SAVE Button
and the red 'client' Peer Delete
button (see below)wg_manager.sh
processes lurkingkillall wg_manager.sh
to get out of troublee = Exit Script [?]
E:Option ==> uf dev
wg_manager.sh
updatee = Exit Script [?]
E:Option ==> uf dev
e = Exit Script [?]
E:Option ==> www mount
WireGuard® Manager
ADDon Tab will now be present.e = Exit Script [?]
E:Option ==> createconfig
e = Exit Script [?]
E:Option ==> www unmount
wg11
fails as the selection of the 'client' Peer index doesn't update.wg_manager.sh
sometimes doesn't immediately refresh - simply keep pressing the Refresh Results
button after a couple seconds and the timestamp shown in the results window should now be displayed as expected.am_settings_set
API although I think I observed the truncation with the Javacript method 'stolen' from @juched's Adblock script .Cool! This is really great! Super job!Well OK.....
I've uploadedwg_manager
Beta v4.17b9
Use at your own RISK!!!
Not all features are available, it is simply a proof of concept as the GUI front-end towg_manager
All defined buttons should work, except theDummy SAVE Button
and the red 'client' PeerDelete
button (see below)
NOTE: Advanced users; be aware that if a command is entered that requires a reply prompt e.g. Peer delete request, then you will have zombiewg_manager.sh
processes lurking
(Usekillall wg_manager.sh
to get out of trouble)
To install the Beta WebUI TAB use
Code:e = Exit Script [?] E:Option ==> uf dev
then repeat to physically download 'wg_manager.asp' that is now included in the v4.17b9wg_manager.sh
update
To install the WebUI issue
Code:e = Exit Script [?] E:Option ==> www mount
Hopefully theWireGuard® Manager
To permanently install the WebUI (i.e. survives a reboot), then update the configuration to set the 'WEBUI' directive
Code:e = Exit Script [?] E:Option ==> createconfig
To remove the WebUI
and comment/delete the 'WEBUI' directive from the configuration.Code:e = Exit Script [?] E:Option ==> www unmount
My HTML/Javascript programming skills are rubbish as shown by the coyote-ugly coding and GUI visual layout..
There are a couple of minor flaws that that I need to immediately address....or perhaps someone can point out my errors...
1. Seemingly attempting to show a 'client' other thanwg11
2. The scrollable text box which shows the results of the command sent to scriptwg_manager.sh
sometimes doesn't immediately refresh - simply keep pressing theRefresh Results
2a. The scollable text box can truncate lengthy resulting output. Might be a limitation of theam_settings_set
It is a work in progress, so be gentle!.
***ERROR Unrecognised command line command via WebUI: 'peer wg11'...ignored
import
would Ideally open file location from your device same as when we upgrade firmware. Perhaps this is really difficult, I dunno.create
button could simply splash a typical server then the user could change as he/she wants.Correct,Cool! This is really great! Super job!
Tried it out and the gui mounts correctly under the addons tab.
However, I cant seem to send any commands to wgm, whatever I try I only get, ie:
Perhaps only some commands implemented?Code:***ERROR Unrecognised command line command via WebUI: 'peer wg11'...ignored
wgm peer xxxxx
has never been allowed; you would always be silently presented with the menu! as would wgm clearly, wot a waste of time and effort
!peer import xxxxxx
has been implemented in GUI so most users should be able to get a basic wg11
configured and running via the GUI, although they can't yet set auto=y
/auto=p
etc.Yes most would only have one 'client' Peer and would probably expect everything to be routed viapeer wg11 info is displayed first after restart of the peers, not unexpected. Guess you store away the info needed upon start.
wg11
by default?CorrectThe config part display all disabled even though I have Entware modules enabled. Maybee not finalized yet.
YupSome food for thought for the future:
1)import
I am slowly working thru' the necessary mods to implement the missing features...but VPN Director support is now available (but custom re-mapping/filtering isn't implemented yet) in2) if the plan is that the user should use VPNDirector to create rules, then maybe there should be a Button for it in the gui?
wg_manager
Beta v4.17bA/ wg_manager.asp
EXPERIMENTAL Beta v0,04e = Exit Script [?]
E:Option ==> uf dev
e = Exit Script [?]
e = Exit Script [?]
Well given the main button is titled3) support to edit the peer info such as dns a.s.o. perhaps all should be editeable which would ease the process of setting up a server in the future, then a future
Dummy SAVE Button
surely this might give you a clue why I've deliberately made the wg11
Configuration fields read-only?I will indeed - but thanks for the kinda harsh feed-back for an already stated proof of concept/work-in-progress.Don't know if any of above makes sense to you or wheither it easy/hard to do. Feel free to disregard if you like.
Well, I know a wgm addon that does this quite nicely ;-)Commandwgm peer xxxxx
has never been allowed; you would always be silently presented with the menu! as wouldwgm clearly, wot a waste of time and effort
Yea, I didn't get that, sorry. Maybe because the dummy save button is under configuration options.Well given the main button is titledDummy SAVE Button
surely this might give you a clue why I've deliberately made thewg11
I might sit this one out as I have never used VPNDirector and my setup is kind-of mission-critical (if I value my life that is).I am slowly working thru' the necessary mods to implement the missing features...but VPN Director support is now available (but custom re-mapping/filtering isn't implemented yet) inwg_manager
Beta v4.17bA/wg_manager.asp
It was never my intention of being harsh, just trying to support. well I just leave you to it instead.thanks for the kinda harsh feed-back for an already stated proof of concept/work-in-progress.
Nice work so far! I have installed on my AX88U and (for now) am just trying the Diagnostic commands. My site-to-site is very stable so I won’t mess too much with settings at this point.Well OK.....
Beta v4.17b9
button (see below)
processes lurking
Thread starter | Title | Forum | Replies | Date |
R | Merlin VLAN Manager | Asuswrt-Merlin AddOns | 0 | |
How to get Unbound Manager to display logs in Scribe? | Asuswrt-Merlin AddOns | 15 | |
Wireguard VPN Director for VPN - WireGuard® Manager© v1.04 by Martineau | Asuswrt-Merlin AddOns | 3 |
Welcome To SNBForums
