Setting up Transmission through Entware
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
proc on /proc type proc (rw)
tmpfs on /tmp type tmpfs (rw)
devfs on /dev type tmpfs (rw,noatime)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
/dev/mtdblock5 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw)
/dev/sda1 on /tmp/mnt/sda1 type ext3 (rw,nodev,noatime,data=ordered)
It's all ok, dunno why do you have this issues, try to reformatt the drive and install all from scratch
I'm running 380.61. Also, I don't know what to do with that information.
Could use VI to create the file and paste the contents into it and make it executable. Do you see the files listed in directory?
Nope. I don't even have a "/opt/etc/transmission" folder. The only folder/files that "opkg install transmission-web" installs is the "/opt/share/transmission" folder, and its contents.
If I try to create the S88transmission file, starting it up fails.
Can I assist you through team viewer? Send me ID and temporary pass using contact form hqt.ro/contact
I am trying to reinstall Transmission from your guide here: https://github.com/RMerl/asuswrt-merlin/wiki/Transmission-through-Optware using Optware instead of Entware.
But when it comes to line 4 :
wget -c -O /opt/etc/init.d/S95transmission http://goo.gl/cSA0os
I get ERROR 404: Not Found.
Which guide should I use, Optware or Entware? I have installed Optware.
Im guessing that line 4 (wget) should download the S95transmission file from a location that does not exists? The http://goo.gl/cSA0os
