DomainVPNRouting Domain VPN Routing v3.1.1 ***Release***
***v3.0.6-beta1 has been released***
Release Notes:
Fixes:
- Fixed an issue causing errors during installation when the firewall-start script does not exist and the Firewall Restore setting is disabled.
Hello @Ranger802004, I have added AS8075 to route out of WAN all the time, but I keep getting this "Mar 27 12:03:45 domain_vpn_routing: Query ASN - ***Error*** Failed to query ASN: AS8075" Everything seems to work fine as I am now able to login to live email (which previously would not work through VPN). Is there anything I can check? A simple tracert to microsoft.com on a machine that is behind VPN, routes traffic properly through WAN also.
I think I finally found the ASNs and domains for all the streaming services that I use which I am able to then enter into this script. The problem I've having is that I think it takes longer to run all the queries than the time between cron jobs. Could you add a log file that has the total time it takes for the updates to run (similar to what we see when we run a query manually) so that I can figure out what I need to change the cron job to?
The domains should be cached and restore automatically after a reboot or service restart of firewall if enabled. If you are referring to ASNs they are actively queried so larger sets may take longer to process. The UI prompts the time it takes to process but to add a log feature you can submit a request via GitHub and I can take a look.
Submit an issue via GitHub.
I'm referring to this:
I always get this message now because the check interval is set to 15 minutes.
Rather than blindly pick numbers until I find something that works, I would like to see a log (similar to what you see when you can run a manual query) that says how long the queries took. Then, I can adjust (4) in the config to a more appropriate amount of time.
May I ask how you went about doing this?
Mostly, time. I spent a lot of time looking up ASNs and following the dnsmasq.log file.
Here is what I found for what I use:
AS40027Netflix
AS2906Netflix
AS23286Hulu
AS22604Disney
AS11251Disney
AS398849Disney
AS14618Amazon
AS16509Amazon
For ASN lookups, I used the following websites: https://bgp.tools/, https://netify.ai, https://asnlookup.com, and https://dnschecker.org/asn-whois-lookup.php.
Here is my streaming domain list (I do have CNAME lookup enabled):
auth.hulu.com
www.hulu.com
assetshuluimcom-a.akamaihd.net
assetshuluimcom-a.akamaihd.net.edgesuite.net
geolocation.onetrust.com
a1355.dscd.akamai.net
*.hulu.com
emu.hulu.com
play.hulu.com
player.hulu.com
ariel.hulu.com
vortex.hulu.com
img2.hulu.com
home.hulu.com
discover.hulu.com
img4.hulu.com
img3.hulu.com
img.hulu.com
img1.hulu.com
engage.hulu.com
dynamic-manifest.hulustream.com
doppler.hulu.com
wildcard-dual.hulu.com.edgekey.net
views.hulu.com
e91869.dsca.akamaiedge.net
views.hulu.com.akadns.net
views.ava.hulu.com
diproton-play-prod-us-east-1.hulu.com.akadns.net
auth.huluipv6.com.akadns.net
wildcard.hulu.com.edgekey.net
web.hulu.map.fastly.net
ariel.hulu.com.akadns.net
vortex.hulu.com.akadns.net
dualstack.web.hulu.map.fastly.net
e91869.a.akamaiedge.net
atv-ps.amazon.com
f4200d648f.na.api.amazonvideo.com
player.hulu.com.akadns.net
d001.na.prod.t300.ter.int.amazonvideo.com
q419zmlyfb4fa0.na.api.amazonvideo.com
m.media-amazon.com
images-na.ssl-images-amazon.com
*.na.api.amazonvideo.com
mtalk.google.com
fastly-weighted.na-f.prod.ter.int.amazonvideo.com
ab5tfw7p9728.na.api.amazonvideo.com
fastly-failover-l1-05.na-f.prod.ter.int.amazonvideo.com
d001.na.prod.t100.ter.int.amazonvideo.com
fastly-failover-l1-14.na-f.prod.ter.int.amazonvideo.com
g6h0n6c3n5.map.fastly.net
fastly-failover-l1-17.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-08.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-03.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-10.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-13.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-18.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-20.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-15.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-19.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-11.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-06.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-04.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-02.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-09.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-16.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-12.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-07.na-f.prod.ter.int.amazonvideo.com
fastly-failover-l1-01.na-f.prod.ter.int.amazonvideo.com
I still need to figure out Peacock next.
EDIT: I also used IPvFoo as a broswer extention to help me currate this list and check IPs to see if I could find ASNs for them.
When you enable ASN, do you still need name based routing?
I found it almost impossible to figure out all domain names used by a website, or app.
If that is directed to me, yes. Many of the URLs used by streaming services are handled by Fastly and I didn't want to allow the entire ASN, just the specific domains/IPs used by the specific streaming services I use.
I have a strange issue lately where the script says that one of my OpenVPN clients is down when I can see that it is up. What can I do to troubleshoot why it is returning this message and force the script to update?
***v3.0.6 has been released***
Release Notes:
Fixes:
***v3.1.0-beta1 has been released to the beta channel***
Release Notes:
v3.1.0-beta1 - 04/02/2025
Enhancements:
- Added functionality to cache ASN IP Subnets for faster restoration from reboot or service restart. This can be enabled or disabled via the ASNCACHE configuration option. Default: Disabled
- ASN queries will now check existing IPSets for IP Subnets that are no longer applicable to the ASN and remove them.
Open a GitHub issue
At some point it just resolved itself. I was looking more to see how it does the check so that I could troubleshoot it on the fly.
@Ranger802004 My issue with ASN is that the log states, "jq package is not installed from entware" however it is infact installed.
admin@GT-AX11000-25C0:/tmp/home/root# opkg install jq
Package jq (1.7.1-1) installed in root is up to date.
Any thoughts?
Any thoughts?
Open a GitHub issue so I can investigate.
***v3.1.0-beta2 has been released to the update channel***
Release Notes:
v3.1.0-beta2 - 04/05/2025
Enhancements:
- New configuration options to enable DNS-over-TLS for an interface if a custom DNS Server is configured for it, the options in the configuration menu will become displayed when a DNS Server is configured. DoT requires dig to be installed to function properly.
@Ranger802004 Which policy takes priority over which policy? I just wanted to validate this with you. I added an ASN to the WAN policy (it's a massive amount of IP's), however, a subset of those domains I wanted to route over VPN, so added those to my "Inside" Policy. I did a tracepath (yes, entware package, not tracert) to a URL and it went over WAN as expected, then did a tracepath to another known URL under the same ASN, and it behaved correctly to go through VPN. Can you please confirm? I know these update every 15 minutes via cron, but just want to seek your insights on normal behaviour and if there might be any leakage?
Thanks again for all of your work on this!
Ok, I did some testing and there is indeed some leakage. When I queried my inside policy first, everything worked as expect, however, immediately after I queried my ASN which goes over WAN, URLs tracepathed over WAN which are explicitly added to the Inside Policy. Any appetite for you to give us some control over policy heiarchy? Is that even possible?
