Skynet Skynet - Router Firewall & Security Enhancements
Hey Adamm,
Is there a limit to how many addresses can be blocked? I reached 65535 IPs being banned a few days ago and the number has not increased since which doesn't seem right?
Cheers!
Hey Adamm,
Cheers!
This is more the likely due to the "maxelem" defaulting at 65535 when not specified. I'll get you the exact syntax when I finish work but you should be able to work it out from here
EDIT;
When creating your IPSets its best to leave this stuff unspecified as IPSet is supposed to dynamically adjust the values, but in this case seeing it isn't you would need to specify the following.
ipset -N -q Whitelist nethash --maxelem 65535
ipset -N -q Blacklist iphash --maxelem 65535
ipset -N -q BlockedCountries nethash --maxelem 65535
EDIT;
__________________
How and where would I place this info?
Update: I have two ipset files....ipset.txt and ipset2.txt where ipset.txt is the most recent and includes the whitelist, all the blacklisted ips and countries and ipset2.txt includes the whitelist and blocked ips but not the countries (I only recently added the countries) .
In each file I have the following:
-N Whitelist nethash --hashsize 1024 --probes 4 --resize 50
-N Blacklist iphash --hashsize 298932 --probes 8 --resize 50
-N BlockedCountries nethash --hashsize 298932 --probes 4 --resize 50
Are these the values I need to overwrite and is it normal to have the two ipset files?
I also, in the ipamount file see the magic number 65535.
Thanks!
Thanks!
ipset.txt is where each set is saved to every hour. ipset2.txt is a backup of that file every 24 hours.
That being said, the values only need to be replaced in ipset.txt then a reboot should fix your issue (as it will load ipset.txt on boot)
ipamount is just where I store the number of banned IP's for the syslog to reference.
Am I supposed to just add the three lines or replace (overwrite) the three current lines?
Thanks!
Thanks!
Just overwrite the current lines in the file and IPSet should do the rest of the work for you after a reboot when it loads the file (ipset.txt)
I have installed the scripts to the correct locations and have checked to ensure they are executable. I am not getting any banned IP's and when I run the script manually
sh /jffs/scripts/firewall-start
I get the following output:
Correct Settings Detected.
[IP Banning Started] ... ... ...
iptables: Bad rule (does a matching rule exist in that chain?).
iptables: No chain/target/match by that name.
/opt/bin/firewall: line 145: echo: Argument list too long
Started:  Wed Jul  9 07:26:48 DST 2014
Finished: Wed Jul  9 07:26:49 DST 2014
0 IP's currently banned.
Output from:
ipset -n -L
Type: nethash
References: 1
Header: hashsize: 1024 probes: 4 resize: 50
Members:
192.168.225.0/24
192.168.1.0/24
Type: iphash
References: 2
Header: hashsize: 1024 probes: 8 resize: 50
Members:
Type: nethash
References: 1
Members:
Any ideas as to what I need to change?
This thread is great!
I just setup an AC68U with RMerlin and I want to block all non-us countries. I started looking at IPTables to block all the subnets from IPDeny.com, but its too many rules which will cause bad perf. I was directed to look at ipsets since its supposed to not impact performance.
So I started reading this thread at the first post. Is that first post still the best instructions for this or are there updates?
I am not sure how the country is determined in this method. However it is detected, how often is it updated with most recent subnets?
In the post, it says that this will grab IP's from the syslog and automatically ban them. Did I read that right?
Does this ban individual IP's or subnet ranges?
I would really like to implement this on my AC68U and also my Linux web server. I just want to make sure that I am working with the most accurate process when I start implementing it.
Thanks!
I just decided to re-set this up on a new router after a massive flood of dropped connections in my syslog from China!
Here is the code, and I am making the assumption Adamm doesn't mind me re-posting his excellent work:
firewall-start
#!/bin/sh
echo "0 * * * * /tmp/mnt/sda1/asusware.arm/bin/firewall save" > /var/spool/cron/crontabs/admin
echo "0 5 * * * /tmp/mnt/sda1/asusware.arm/bin/firewall backup" >> /var/spool/cron/crontabs/admin
[ -n "`pidof crond`" ] && killall -q crond
sleep 1
crond
sh /tmp/mnt/sda1/asusware.arm/bin/firewall
and /opt/bin/firewall
#!/bin/sh
## 17/04/2014 --- RT-AC56U/RT-AC68U Firewall Addition v2.2 #
###          ----- Make Sure To Edit The Following Files -----                       #
### /jffs/firewall-start				 <-- Sets up cronjob/iptables rules			 #
### /opt/bin/firewall					 <-- Blacklists IP's From /opt/tmp/ipset.txt #
### /opt/tmp/ipset.txt                   <-- Banned IP List/IPSet Rules              #
#####Commands / Variables#####
UNBANSINGLE="unban"          # <-- Remove Single IP From Blacklist
UNBANALL="unbanall"          # <-- Unbans All IPs In Blacklist
REMOVEBANS="removeall"       # <-- Remove All Entries From Blacklist
SAVEIPSET="save"             # <-- Save Blacklists to /opt/tmp/ipset.txt
BANSINGLE="ban"              # <-- Adds Entry To Blacklist
BANCOUNTRYSINGLE="country"   # <-- Adds entire country to blacklist
BANCOUNTRYLIST="bancountry"  # <-- Bans specified countries in this file
WHITELIST="whitelist"        # <-- Add IPs from path to Whitelist
BACKUPRULES="backup"         # <-- Backup IPSet Rules to /opt/tmp/ipset2.txt / Checks for firmware updates
started=`date`
bannedips=/opt/tmp/ipamount
cat /opt/bin/firewall | head -23
# Unban / Unbanall / Removeall / Save / Ban / Country / Bancountry / Whitelist / Backup #
if [ X"$@" = X"$UNBANSINGLE" ]
then
	echo "Input IP Address To Unban"
	read unbannedip
	logger -t Firewall "[Unbanning And Removing $unbannedip From Blacklist] ... ... ..."
	ipset  -D Blacklist $unbannedip
	echo "`sed /$unbannedip/d /opt/tmp/ipset.txt`" > /opt/tmp/ipset.txt
	echo "$unbannedip Is Now Unbanned"
elif [ X"$@" = X"$UNBANALL" ]
then
	echo "[Unbanning All IP's] ... ... ..."
	logger -t Firewall "[Unbanning All IP's] ... ... ..."
	ipset --flush Blacklist
	ipset --flush BlockedCountries
elif [ X"$@" = X"$REMOVEBANS" ]
then
	expr `ipset list | wc -l` - 15 > /opt/tmp/ipamount
	echo "[Deleting All `cat $bannedips` Entries From Blacklist] ... ... ..."
	logger -t Firewall "[Deleting `cat $bannedips` Entries From Blacklist] ... ... ..."
	ipset --save > /opt/tmp/ipset.txt
elif [ X"$@" = X"$SAVEIPSET" ]
then
	echo "[Saving Blacklists] ... ... ..."
	echo "`sed '/crond: USER admin/d' /tmp/syslog.log`" > /tmp/syslog.log
elif [ X"$@" = X"$BANSINGLE" ]
then
	echo "Input IP Address"
	read bannedip
	logger -t Firewall "[Adding $bannedip To Blacklist] ... ... ..."
	ipset -q -A Blacklist $bannedip
	echo "$bannedip Is Now Banned"
elif [ X"$@" = X"$BANCOUNTRYSINGLE" ]
then
	echo "Input Country Abbreviation"
	read country
	for IP in $(wget -q -O - http://www.ipdeny.com/ipblocks/data/countries/$country.zone)
	do
	ipset -q -A BlockedCountries $IP
	done
elif [ X"$@" = X"$BANCOUNTRYLIST" ]
then
	echo "[Banning Spam Countries] ... ... ..."
	for country in pk cn in jp ru sa
	do
    do
	done
	done
elif [ X"$@" = X"$WHITELIST" ]
then
	echo "Input file location"
	read WHITELISTFILE
	for IP in `cat $WHITELISTFILE`
	do
	ipset -q -A Whitelist $IP
	echo $IP
	done
elif [ X"$@" = X"$BACKUPRULES" ]
then
	echo "Backing Up Current IPSet Rules"
	cp -f /opt/tmp/ipset.txt /opt/tmp/ipset2.txt
else
		if [ X"`nvram get fw_log_x`" = X"drop" ]
		then
			echo "Correct Settings Detected"
		else
			nvram set fw_log_x=drop
			nvram commit
		fi
		if [ X"`nvram get fw_enable_x`" = X"1" ]
		then
			echo "Correct Settings Detected."
		else
			nvram set fw_enable_x=1
			nvram commit
		fi
	echo "[IP Banning Started] ... ... ..."
	logger -t Firewall "[IP Banning Started] ... ... ..."
	ipset -q -R  < /opt/tmp/ipset.txt
	ipset -q -N Whitelist nethash
	ipset -q -N Blacklist iphash
	ipset -q -N BlockedCountries nethash
	iptables -D logdrop -m state --state NEW -j LOG --log-prefix "DROP " --log-tcp-sequence --log-tcp-options --log-ip-options
	iptables -D INPUT -m set --match-set Whitelist src -j ACCEPT
	iptables -D INPUT -m set --match-set Blacklist src -j DROP
	iptables -D INPUT -m set --match-set BlockedCountries src -j DROP
	iptables -D logdrop -m state --state NEW -j SET --add-set Blacklist src
	iptables -I INPUT -m set --match-set Blacklist src -j DROP
	iptables -I INPUT -m set --match-set BlockedCountries src -j DROP
	iptables -I INPUT -m set --match-set Whitelist src -j ACCEPT
	iptables -I logdrop -m state --state NEW -j SET --add-set Blacklist src
	ipset -q -A Whitelist 192.168.1.0/24
	ipset -q -A Whitelist `nvram get lan_ipaddr`/24
	echo "`sed '/DROP IN=/d' /tmp/syslog.log`" > /tmp/syslog.log
	echo "`sed '/DROP IN=/d' /tmp/syslog.log-1`" > /tmp/syslog.log-1
fi
#Logging#
OLDAMOUNT=`cat /opt/tmp/ipamount`
echo "Started:  $started"
echo "Finished: `date`"
expr `ipset -L Blacklist | wc -l` - 6 > /opt/tmp/ipamount
NEWAMOUNT=`cat /opt/tmp/ipamount`
echo "`cat $bannedips` IP's currently banned."
logger -t Firewall "[Complete] `cat $bannedips` IPs currently banned. `expr $NEWAMOUNT - $OLDAMOUNT` New IP's Banned. "
Unknown arg `--match-set'
Asus RT-AC66U v.376.49
admin@kgw:/tmp/mnt/OPTWARE# iptables -V
iptables v1.3.8
admin@kgw:/tmp/mnt/OPTWARE# ipset -V
ipset v4.5, protocol version 4.
Kernel module protocol version 4.
admin@kgw:/tmp/mnt/OPTWARE# iptables -A INPUT -m set --match-set blacklist src -j LOG --log-prefix "DROP blacklist entry: "
iptables v1.3.8: Unknown arg `--match-set'
Try `iptables -h' or 'iptables --help' for more information.
Update: Solved by change "-m set --match-set blacklist" to "-m set --set blacklist"
I got this log:
Dec 27 19:51:55 dropbear[24029]: Bad password attempt for 'admin' from 122.225.109.206:48156
Dec 27 19:51:56 dropbear[24031]: Login attempt for nonexistent user from 122.225.109.206:53411
Dec 27 19:51:56 dropbear[24029]: Exit before auth (user 'admin', 10 fails): Max auth tries reached - user 'admin' from 122.225.109.206:48156
Dec 27 19:51:56 dropbear[24032]: Child connection from 122.225.109.206:56225
Dec 27 19:51:56 dropbear[24033]: Child connection from 122.225.109.206:56757
Dec 27 19:51:57 dropbear[24031]: Login attempt for nonexistent user from 122.225.109.206:53411
Dec 27 19:51:58 dropbear[24031]: Login attempt for nonexistent user from 122.225.109.206:53411
Dec 27 19:51:58 dropbear[24032]: Login attempt for nonexistent user from 122.225.109.206:56225
Dec 27 19:51:59 dropbear[24032]: Login attempt for nonexistent user from 122.225.109.206:56225
Dec 27 19:51:59 dropbear[24031]: Login attempt for nonexistent user from 122.225.109.206:53411
Dec 27 19:52:00 dropbear[24031]: Login attempt for nonexistent user from 122.225.109.206:53411
Dec 27 19:52:00 dropbear[24032]: Login attempt for nonexistent user from 122.225.109.206:56225
Dec 27 19:52:01 dropbear[24031]: Exit before auth: Max auth tries reached - user 'is invalid' from 122.225.109.206:53411
Dec 27 19:52:01 dropbear[24032]: Login attempt for nonexistent user from 122.225.109.206:56225
Dec 27 19:52:01 dropbear[24035]: Child connection from 122.225.109.206:2035
Dec 27 19:52:01 dropbear[24033]: Bad password attempt for 'admin' from 122.225.109.206:56757
Dec 27 19:52:02 dropbear[24032]: Login attempt for nonexistent user from 122.225.109.206:56225
Dec 27 19:52:02 dropbear[24033]: Bad password attempt for 'admin' from 122.225.109.206:56757
Dec 27 19:52:02 dropbear[24032]: Exit before auth: Error reading: Connection reset by peer
Dec 27 19:52:02 dropbear[24033]: Exit before auth (user 'admin', 2 fails): Error reading: Connection reset by peer
Dec 27 19:52:02 dropbear[24035]: Exit before auth: Error writing: Connection reset by peer
Dec 27 20:00:01 [B][COLOR="Red"]Firewall: [Complete] 0 IPs currently banned. 0 New IP's Banned. [/COLOR][/B]
Dec 27 20:17:03 dropbear[24157]: Child connection from 122.194.76.75:1077
Dec 27 20:17:05 dropbear[24157]: Login attempt for nonexistent user from 122.194.76.75:1077
Dec 27 20:17:06 dropbear[24157]: Exit before auth: Disconnect received
Dec 27 20:17:09 dropbear[24158]: Child connection from 122.194.76.75:3897
Dec 27 20:17:14 dropbear[24158]: Login attempt for nonexistent user from 122.194.76.75:3897
Dec 27 20:17:14 dropbear[24158]: Exit before auth: Disconnect received
Dec 27 20:17:18 dropbear[24159]: Child connection from 122.194.76.75:5940
Dec 27 20:17:24 dropbear[24159]: Login attempt for nonexistent user from 122.194.76.75:5940
Dec 27 20:17:24 dropbear[24159]: Exit before auth: Error reading: Connection reset by peer
Dec 27 20:47:56 dropbear[24279]: Child connection from 113.161.0.114:52661
Dec 27 20:47:57 dropbear[24279]: Exit before auth: Exited normally
Isn't the firewall script supposed to ban these ips?? What's going on?
Then i ran the firewall script manually, with following output:
admin@RT-AC56U:/tmp/home/root# sh /jffs/scripts/firewall-start
#!/bin/sh
.txt #
Started:  Sat Dec 27 20:56:51 GMT 2014
Finished: Sat Dec 27 20:56:52 GMT 2014
What am i missing??
My problem seems the same as post #49, but no answer?
Eet_46,
Try the command "firewall save" one time. Not using this right now but seemed to kick start the banning for me if I remember correctly.
Well, i already ran this command some time ago, to make it create /opt/tmp/ipset.txt.
So that file exists already, making me doubt that this is the solution :/
Btw, only thing i edited was the path in "firewall-start", from
to
as it otherwise gave me an error.
I saw this question being asked a few times and this thread being linked so I thought i'd post my current code. I removed a few functions like my autoupdate feature until I get my VPS up and running again.
#!/bin/sh
## - 25/12/2014 ---		RT-AC66U/RT-AC56U/RT-AC68U Firewall Addition v2.5 -  		#
### /jffs/scripts/firewall					 <-- Blacklists IP's From /jffs/scripts/ipset.txt #
### /jffs/scripts/ipset.txt					 <-- Banned IP List/IPSet Rules			  #
SAVEIPSET="save"             # <-- Save Blacklists to /jffs/scripts/ipset.txt
NEWLIST="new"				 # <-- Create new IPSet Blacklist
DUMPCFE="dumpcfe"	     	 # <-- Dumps current CFE to /jffs/scripts/cfe.dump
UPDATECFE="updatecfe"	     # <-- Flash CFE from /jffs/scripts/cfe.flash (reset nvram afterwards)
start_time=`date +%s`
cat /jffs/scripts/firewall | head -28
# - Unban / Unbanall / Removeall / Save / Ban / Country / Bancountry / Whitelist / Hideme / Findme/ DumpCFE / UpdateCFE  / Backup - #
then
	read unbannedip
	echo "`sed /$unbannedip/d /jffs/scripts/ipset.txt`" > /jffs/scripts/ipset.txt
then
then
	nvram set Blacklist=`expr \`ipset -L Blacklist | wc -l\` - 6`
	echo "[Deleting All `echo \`nvram get Blacklist\`` Entries From Blacklist] ... ... ..."
	logger -t Firewall "[Deleting All `echo \`nvram get Blacklist\`` Entries From Blacklist] ... ... ..."
	ipset --save > /jffs/scripts/ipset.txt
then
then
	read bannedip
then
	read country
	do
	done
then
	do
       	do
	done
	done
then
	read WHITELISTFILE
	do
	echo $IP
	done
elif [ X"$@" = X"$NEWLIST" ]
then
	echo "Does The Blacklist Need To Be Downloaded? yes/no"
	read ENABLEDOWNLOAD
		if [ X"$ENABLEDOWNLOAD" = X"yes" ]; then
			echo "Input URL For IPSet Blacklist"
			read DOWNLOADURL
			wget -O /jffs/scripts/ipset2.txt $DOWNLOADURL
		fi
	echo "Input New Set Name"
	read SETNAME
	sed -i "s/Blacklist/$SETNAME/g" /jffs/scripts/ipset2.txt
	ipset -q -R  < /jffs/scripts/ipset2.txt
	echo "Successfully Added New Set"
elif [ X"$@" = X"$DUMPCFE" ] && [ X"`nvram get model`" = X"RT-AC68U" ]
then
	echo "Dumping CFE"
	logger -t Firewall "[Dumping CFE] ... ... ..."
	OLDCFE="`strings /dev/mtd0 | grep model` - `strings /dev/mtd0 | grep bl_v` - `strings /dev/mtd0 | grep 0:ccode` - `strings /dev/mtd0 | grep et0macaddr` - `strings /dev/mtd0 | grep 0:macaddr` - `strings /dev/mtd0 | grep 1:macaddr` - `strings /dev/mtd0 | grep secret_code`"
	cat /dev/mtd0 > /jffs/scripts/cfe.dump
	echo "Sucessfully Dumped CFE - $OLDCFE"
	logger -t Firewall "Sucessfully Dumped CFE - $OLDCFE"
elif [ X"$@" = X"$UPDATECFE" ] && [ X"`nvram get model`" = X"RT-AC68U" ]
then
	echo "Flashing new CFE"
	logger -t Firewall "[Flashing new CFE] ... ... ..."
	OLDCFE="`strings /dev/mtd0 | grep et0macaddr`  `strings /dev/mtd0 | grep 0:macaddr`  `strings /dev/mtd0 | grep 1:macaddr`  `strings /dev/mtd0 | grep secret_code`"
	NEWCFE="`strings /jffs/scripts/cfe.flash | grep et0macaddr`  `strings /jffs/scripts/cfe.flash | grep 0:macaddr`  `strings /jffs/scripts/cfe.flash | grep 1:macaddr`  `strings /jffs/scripts/cfe.flash | grep secret_code`"
		if [ X"`echo $OLDCFE`" = X"`echo $NEWCFE`" ]; then
			echo "Correct Values Detected"
			/jffs/scripts/mtd-write cfe.flash boot && status="Successfully flashed new CFE. `strings /dev/mtd0 | grep bl_v`   `strings /dev/mtd0 | grep 0:ccode`   $NEWCFE"  || status="Failed flashing new CFE"
			logger -t Firewall "$status ... ... ..."
			echo "$status"
		else
			echo "Values Missing From New CFE - Make Sure Values Are Hex'd In" && status="Values Missing From New CFE - Make Sure Values Are Hex'd In"
			echo "Old CFE - $OLDCFE"
			echo "New CFE - $NEWCFE"
		fi
else
		then
		else
			echo "Enabled SPI Firewall"
			nvram commit
		fi
		then
		else
			echo "Enabled Firewall Logging"
			nvram commit
		fi
		if [ X"`nvram get clkfreq`" != X"1200,800" ] && [ X"`nvram get model`" = X"RT-AC68U" ]
		then
			echo "Enabled Overclock - Current Clock `nvram get clkfreq`"
			nvram set clkfreq=1200,800
			nvram commit
		else
		fi
	echo "`sed '/IP Banning Started/d' /tmp/syslog.log`" > /tmp/syslog.log
	ipset -q -R  < /jffs/scripts/ipset.txt
	iptables -D logdrop -m state --state NEW -j LOG --log-prefix "DROP " --log-tcp-sequence --log-tcp-options --log-ip-options  > /dev/null 2>&1
	ipset -q -A Whitelist 192.3.148.0/24
fi
# - Logging - #
OLDAMOUNT=`nvram get Blacklist`
NEWAMOUNT=`nvram get Blacklist`
nvram set BlacklistTotal=`expr \`ipset -L | wc -l\` - 26`
start_time=$(expr `date +%s` - $start_time)
echo "[Complete] $NEWAMOUNT IPs currently banned. `expr $NEWAMOUNT - $OLDAMOUNT` New IP's Banned. `nvram get BlacklistTotal` Banned Overall [`echo $start_time`s]"
logger -t Firewall "[Complete] $NEWAMOUNT IPs currently banned. `expr $NEWAMOUNT - $OLDAMOUNT` New IP's Banned. `nvram get BlacklistTotal` Banned Overall [`echo $start_time`s]"
#!/bin/sh
echo "0 * * * * /jffs/scripts/firewall save" > /var/spool/cron/crontabs/admin
sleep 5
crond
Sorry, i'm a bit confused now, with your new code, some of the changes would be nice to know why they are made :)
Maybe an update of the main post, so everything is up to date? That would be a lot easier, rather than one having to read through the entire thread to gather bits of info..
Hold the Phone... why does this script backup and flashes the bootoader?
#!/bin/sh
then
    read unbannedip
then
then
then
then
    read bannedip
then
    read country
    do
    done
then
    do
           do
    done
    done
then
    read WHITELISTFILE
    do
    echo $IP
    done
then
    read ENABLEDOWNLOAD
            read DOWNLOADURL
        fi
    read SETNAME
then
    echo "Dumping CFE"
then
            echo "$status"
        else
        fi
else
        then
        else
            nvram commit
        fi
        then
        else
            nvram commit
        fi
        then
            nvram commit
        else
        fi
fi
# - Logging - #
#!/bin/sh
sleep 5
crond
