JGrana
Thanks, when I get to ssh in, I will try that.That might already be there with generatecsv
@Snoopotic, the CPU on the router isn't powerful enough.
Even the RT-AX88U with 4x 1.8GHz cores can't show me my symmetrical 1Gbps Fibre speeds, but an i7 desktop (wired) can.
Integrate with cake-qos to test without the bandwidth limits. You could maybe set cake-qos to unlimited for the duration of the speed test, but of course any latency/bufferbloat testing would need the limits re-applied.Any feature requests for v4? May as well get them in now while I'm working on it![]()
would starting and stopping cake-qos not be better, as this can be done directly at command line, whereas config changes cannot? config changes would also require backing up and restoring chosen cake parameters, adding complexity.Integrate with cake-qos to test without the bandwidth limits. You could maybe set cake-qos to unlimited for the duration of the speed test, but of course any latency/bufferbloat testing would need the limits re-applied.
Yes, thinking simply I agree.would starting and stopping cake-qos not be better, as this can be done directly at command line, whereas config changes cannot? config changes would also require backing up and restoring chosen cake parameters, adding complexity.
note im not a cake user, my 550mbps connection is more than cake can handle on my 86u.
So indeed spdMerlin is not quite as fast as running the CLI on my Windows desktop. I have seen 800+ upload using spdMerlin on occasion. And, the fastest server for me is not included in the ten servers that spdMerlin presents. I found it by trial and error using the web interface I believe.
spdMerlin
Windows CLI
Not going to change back, sorry.But the graph is still limited. I prefer the two separate graphs. Clear accurate and upfront.
V4 has this and more@Jack Yaz - as part of your update/upgrade for this really useful utility - any chance you could include - just below the "Run speedtest" button [?] - a Toggle select for turning automatic speedtests ON or OFF [Item 6 of your script menu]. 90%+ of the time I SSH to your script menu it is to do no more than toggle on or toggle off.
Pretty sure that'll be the most common reason for folks to hit your SSH menu after configuring.
Awesome ... will patiently await releaseV4 has this and more
If I remember correctly, spdMerlin generates about 1-1.5 TB of traffic per month.
I beleive this would be 100 percent dependent on the ISP provided speed. One speedtest for me uses around 1.6-1.8 GB.
Welcome To SNBForums
