spdMerlin The future of spdMerlin
Testers wanted for the new feature to speedtest against chosen server(s)! Please use option uf and give it a whirl. I'm fairly confident its working on 384.19 on my 86U and now need some others to give it a try please
Tested ... but also on AC86U - so not much to add ... except maybe a little tidy up at "standard" webui width ... see below ...
WAN server window drops by a line ,,, VPNC1 is fine ...
Then I discovered an "easter egg?" which must be lurking in your code ??? :cool:
I was able to "stretch" the width of the page to my hearts content at a certain point ...
:D:D:cool:
:D:D:cool:
Hm not sure why your wan line is doing that, maybe I'll hardcode a max width for the select.
Resizing textareas is a standard browser feature so i can't claim that one
Never spotted that text-areas feature on the router's webui before ... but have now spotted some more :oops: outside your many addons.
Like Netstat page - text below Diagnose button.
thnx
Just tested v4.00 on my RT-AX88U with RMerlin 386.1 Alpha 3 running.
Works great! :D
After the latest "uf" sometimes the General Config settings revert back to the previous setup despite being Saved after I Run a manual Speedtest from the GUI. I get the following Console errors:
jquery.js:5 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
send @ jquery.js:5
DevTools failed to load SourceMap: Could not load content for http://192.168.1.5/ext/shared-jy/hammer.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
send @ jquery.js:5
which settings? do you see the changes actually in the config file on the router? i.e. you're pressing save, page reloads with correct settings. then running a speedtest and when it finishes settings are reverting?
EDIT: fixed
EDIT: fixed
Yes that's correct. I have experienced the change in Enable scheduled speedtests from No to Yes and Exclude speedtests from QoS from Yes to No.
When the test is running there is a message "Speedtest in progress for WAN" and then "Refreshing Tables and settings" appears which reloads the page and the settings revert to their previous values like above
Man, that is awesome, I just loaded it.
I don't know if this is a bug or not, but when I changed the data location in the UI to usb, it stayed to jffs. I am pretty sure I had it on usb before.
Is this a feature that isn't quite ready yet maybe?
A couple of people have reported this but I'm not able to reproduce it, files move back and forth as they should. Can you check if the USB folder was populated at all?
It looks like there are three folders on my /mnt/sandisk32 usb: entware, skynet, lost+found, and myswap.swp file
It don't look like it unless it puts them in a subfolder. And if I am looking in the right place. I am still a 1st grade Linux student.
But that makes me wonder where the other scripts are putting their data on the usb.
for me now after one of the updates graphs are not showing data. stored to usb, list of folder:
 ls -la /opt/share/spdmerlin.d
drwxrwxrwx    3 admin    root          4096 Nov 16 13:23 .
drwxr-xr-x   16 admin    root          4096 Nov 10 09:36 ..
-rw-rw-rw-    1 admin    root           184 Nov 16 13:23 .interfaces
-rw-rw-rw-    1 admin    root           184 Nov 16 13:23 .interfaces_user
-rw-rw-rw-    1 admin    root           184 Nov 16 13:23 .interfaces_user.bak
-rw-rw-rw-    1 admin    root             0 Nov 10 09:37 .tableupgraded2_VPNC1
-rw-rw-rw-    1 admin    root             0 Nov 10 09:37 .tableupgraded2_VPNC2
-rw-rw-rw-    1 admin    root             0 Nov 10 09:37 .tableupgraded2_VPNC3
-rw-rw-rw-    1 admin    root             0 Nov 10 09:37 .tableupgraded2_VPNC4
-rw-rw-rw-    1 admin    root             0 Nov 10 09:37 .tableupgraded2_VPNC5
-rw-rw-rw-    1 admin    root             0 Nov 10 09:37 .tableupgraded2_WAN
-rw-rw-rw-    1 admin    root             0 Nov 11 11:12 .tableupgraded3_WAN
-rw-rw-rw-    1 admin    root             0 Nov 10 09:37 .tableupgraded_VPNC1
-rw-rw-rw-    1 admin    root             0 Nov 10 09:37 .tableupgraded_VPNC2
-rw-rw-rw-    1 admin    root             0 Nov 10 09:37 .tableupgraded_VPNC3
-rw-rw-rw-    1 admin    root             0 Nov 10 09:37 .tableupgraded_VPNC4
-rw-rw-rw-    1 admin    root             0 Nov 10 09:37 .tableupgraded_VPNC5
-rw-rw-rw-    1 admin    root             0 Nov 10 09:37 .tableupgraded_WAN
-rw-r--r--    1 admin    root           699 Nov 16 13:23 config
-rw-r--r--    1 admin    root           703 Nov 16 13:23 config.bak
drwxrwxrwx    2 admin    root          4096 Nov 16 13:23 csv
-rw-rw-rw-    1 admin    root          5770 Nov 16 13:23 spdjs.js
-rw-r--r--    1 admin    root        110592 Nov 16 13:12 spdstats.db
-rw-rw-rw-    1 admin    root         39996 Nov 16 13:12 spdtitletext.js
what might be a reason ?
check for browser console errors, they are usually the first thing to check if other things render correctly
they'll be in entware. can you run
ls -la /opt/share
please?
(/opt is a symlink to your entware directory)
fixed with reinstall.
Can be the graphs for interfaces without data hidden ?
ls -la /opt/share
please?
yes, sir, sorry about the delay, I had to take off and go to work.
