Jack Yaz
Part of the Furniture
no problem! looks like like spdmerlin directory is there. does the webui still show jffs?yes, sir, sorry about the delay, I had to take off and go to work.
Other than:
I think v4 is almost feature complete!
- Disable/enable options when automatic testing is on/off
- AutoBW in WebUI
flexqos 1.0.6 will work best, as it picks up on a restart_qos event call (which spdmerlin makes with the autobw feature)Great job! It looks like you have managed to give me an excuse to run 5 VPN'S
. This is quite a unique accomplishment Jack. Thank you for your awesome work. -- Does the AutoBW have capabilities to work along side flexQoS?
v1.0.6 is still lingering in the development branch since I had to make some significant changes to eliminate the requirement for a restart_firewall. So I'm hoping for moreflexqos 1.0.6 will work best, as it picks up on a restart_qos event call (which spdmerlin makes with the autobw feature)
v4 is also in develop so hopefully users know what they're in forv1.0.6 is still lingering in the development branch since I had to make some significant changes to eliminate the requirement for a restart_firewall. So I'm hoping for morevictimstesters to confirm I didn't break anything since I no longer receive the wan interface name from the firewall-start script.
Uncaught ReferenceError: prefix is not defined
at SaveConfig (user5.asp:1269)
at HTMLInputElement.onclick (user5.asp:1)
DevTools failed to load SourceMap: Could not load content for http://192.168.1.5/ext/shared-jy/hammer.min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
yes. And there's not graphs there yet.no problem! looks like like spdmerlin directory is there. does the webui still show jffs?
That looks suspiciously like thr config file isn't loading. Can you please check for browser console errors? Also run option uf if you haven't already, there's a lot of regular changes on develop and you may be on one where I broke somethingyes. And there's not graphs there yet.
Question to all users.Also if Auto BW is Enabled does it automatically adjust the QoS Bandwidth values to the Configured scale factor after each Speadtest? It does work if I Update the values manually with Option 1.
i vote for scheduled as i run mine nightly when everyone is asleep with less traffic to compete with. manual i may run to see what i get randomly during the day and it may be less consistent.Question to all users.
Should AutoBW apply to all speedtests, whether manual or scheduled, or scheduled only? (I don't want to make this configurable, there's enough options already!)
From what I've seen, Asus' speedtest inclusion in 386 looks very good, making me unsure if I should continue with spdMerlin as a project.
For anyone running 386, is there anything spdMerlin does that Asus' doesn't, and vice versa?
I vote a toggle to let the user decide......I too vote for scheduled since if it is done with every manual speedtest it will restart the FlexQoS every time I run the speedtest which will result dropping my active audio streamign connections.
With great power comes greater responsibility....
It looks like there are three folders on my /mnt/sandisk32 usb: entware, skynet, lost+found, and myswap.swp file
It don't look like it unless it puts them in a subfolder. And if I am looking in the right place. I am still a 1st grade Linux student.
But that makes me wonder where the other scripts are putting their data on the usb.
I had this same issue after upgrade. I did first time manually using AMTM and WebUI has caught up.Man, that is awesome, I just loaded it.
I don't know if this is a bug or not, but when I changed the data location in the UI to usb, it stayed to jffs. I am pretty sure I had it on usb before.
Is this a feature that isn't quite ready yet maybe?
Question for dummies - what is AutoBW and how does it differ from exclusion from QoS? No using QoS so do not quite understand.Question to all users.
Thread starter | Title | Forum | Replies | Date |
vnStat Exclude spdMerlin from vnStat reports | Asuswrt-Merlin AddOns | 3 | |
Router Speed Test (spdMerlin) | Asuswrt-Merlin AddOns | 5 |
Welcome To SNBForums
