spdMerlin The future of spdMerlin
Set QoS upload/download bandwidth using spdMerlin (via Ookla speedtests)
Welcome to the world of varying bandwidths(powered by ookla). Ookla is running an autobandwidth service and doesn't know it yet.....
I received a status as the jpg after checked the amtm's update status(in fact i'm using the latest verion of spdmerlin 4.0).It doesn't bother me at all just for the feedback.
Is it normal by the way ?
That looks suspiciously like thr config file isn't loading. Can you please check for browser console errors? Also run option uf if you haven't already, there's a lot of regular changes on develop and you may be on one where I broke something
I would be glad to check for errors if I knew how. about all I can do is hit F12.
I did update uf, and it's still the same.
It shows that I am using the usb in amtm. It worked correctly before 4.0, or it ran and graphed the results.
system log says:
Nov 19 11:42:01 RT-AC86U-8F38 spdMerlin: No interfaces enabled, exiting
Yes as it checks for updates in master not development branch.
@Jack Yaz I've noticed a few "blanks" within the Packet Loss results...not sure if it is a calculation, conversion, or what there....Noticed it on both routers so that would make me think issue is across the board??
it's blank if the speedtest server you connect to doesn't report packet loss. not all speedtest servers support it, which is why i initially pushed back on adding this feature as I knew i would get questions like this!
I hope every one wanting to show appreciation gets a chance to stop by this page.
system log says:
ok that means there's nothing selected in the auto speedtest section.
sorry, for console errors, hit F12 then click the Console tab, like below. Anything in red send a screenshot of please:
Actually looks like jq is missing. Can you check by running
 opkg install jq
please?
Hmmm, installing jq fixed my issue as well. I never could select a specific server.
Hello.
Since a couple days, Im getting a ton of errors after selecting "choose a server" option. I have to stop the script with ctrl c and wait for a while in order to use it again since it locks the process.
##                       _  __  __              _  _              ##
##                      | ||  \/  |            | |(_)             ##
##       ___  _ __    __| || \  / |  ___  _ __ | | _  _ __        ##
##      / __|| '_ \  / _  || |\/| | / _ \| '__|| || || '_ \       ##
##      \__ \| |_) || (_| || |  | ||  __/| |   | || || | | |      ##
##      |___/| .__/  \__,_||_|  |_| \___||_|   |_||_||_| |_|      ##
##          |_|                                                   ##
##                       v4.1.1 on RT-AC3100                      ##
##              https://github.com/jackyaz/spdMerlin              ##
Choose an interface to speedtest:
1.    All
2.    WAN
3.    VPNC3
Choose an option:    3
What mode would you like to use?
1.    Auto-select
2.    Preferred server
3.    Choose a server
Choose an option:    3
Generating list of closest servers for VPNC3...
/jffs/scripts/spdmerlin: line 2990: jq: not found
[: bad number
1)  |
[: bad number
2)  |
[: bad number
3)  |
[: bad number
4)  |
[: bad number
5)  |
[: bad number
Hello.
##                       _  __  __              _  _              ##
##          |_|                                                   ##
1.    All
2.    WAN
3.    VPNC3
Choose an option:    3
1.    Auto-select
2.    Preferred server
3.    Choose a server
Choose an option:    3
[: bad number
1)  |
[: bad number
2)  |
[: bad number
3)  |
[: bad number
4)  |
[: bad number
5)  |
[: bad number
Maybe jq got messed up. Try reinstalling jq. Happened to me once.
Opkg install jq
thanks! that fixed it
This is a known issue a few have mentioned to jack. It seems if you uninstall a script that uses jq it will effectively render jq unavailable for spdmerlin. One script that uses jq is X3Mrouting, if this is removed jq gets removed. There may be other scripts that use jq as well but I haven't investigated. Ultimately it is up to script devs to maintain that dependencies are installed when required
