Tech9
Part of the Furniture
They claim to test routers with a documented methodology/criteria.
I had a few budget TP-Link routers in my hands with better Wi-Fi than much more expensive Asus and Netgear routers.
The TP-Link Archer AX20 was a previous Wirecutter top pick. They didn't like the TP-Link Archer AX21 though.Nowhere to be found in Canada as well. I expect this model to be discontinued, if not already.
TP-Link Archer AX21 Review: An Excellent Wi-Fi Router for Most Homes
This hassle-free router will upgrade your home network to Wi-Fi 6 -- and it's faster than the competition, too.www.cnet.com
I appreciate the link though I'd hoped for feedback from members that actually use TP-Link AX routers. Regardless I appreciate the feedback and will definitely steer clear of the RT-AX68 since most of the research shows its one of the weaker modelsNowhere to be found in Canada as well. I expect this model to be discontinued, if not already.
Interesting how the top pick is the AX50..I've had great success with Ebay factory refurb items and I can get the AX1800 for $35 with a 2 year warranty though its obvious the AX50/55 might be betterThey claim to test routers with a documented methodology/criteria. I don't use them as my primary source but wouldn't call it random. I recalled that they like TP-Link so thought I'd post it.
The Best Wi-Fi Routers
We’ve tested the latest Wi-Fi routers and found the best options—from budget models to top-of-the-line—to make your wireless network faster and more responsive.www.nytimes.com
AX50 yes. But the article also states "The TP-Link Archer AX55 will be our new top pick in an upcoming rewrite of this guide." Just FYI...Interesting how the top pick is the AX50..I've had great success with Ebay factory refurb items and I can get the AX1800 for $35 with a 2 year warranty though its obvious the AX50/55 might be better
Some subjective reviews will show the AX86U outperforming the older AX88U @ distance for example.
All that might be true. I bought an AX86U and it's the first router I've ever had that provides a reliable fast 5GHz signal throughout my entire house. It's the best router I've owned. Maybe not perfect but I'm happy with itNo one here uses any router in your apartment. You have to find yourself what works best for you.
My AX86U can't outperform at distance my AC86U. It's just has weaker walls and obstacles penetration. Archer C80 for $50 beats AX86U то АC clients through two walls as well. MediaTek based entry-level router. AX88U is better than AX86U. I had one AX88U in my routers collection.
When I read CNET reviews and knowing how the channel relies on ad revenue, its hard not to think they're biased towards any brand that 'invests'. I imagine the same holds true with others making it challenging for the consumer. After reading all of these comments, I'm wondering if it even makes sense to upgrade, LOLI would take all "reviews" with a grain of salt.
Their "best" WIFI router uses dead Intel platform that was sold off to Maxlinear a few years ago. Chances of the platform being updated with security updates are very slim. Especially with TP link.. A company that only pushes 1-3 updates in a lifecycle.
They recommend AX88U as upgrade pick while GT-AX6000 succeeds the 4 year old AX88U platform with newer Gen 2 AX hardware and 2x 2.5G.. Pricing isn't much different either, at least on sale. (Newegg sold GT-AX6000 for $273 USD for Black Friday).
Any testing they're doing is going to be skewed towards the reviewers home and doesn't really reflect "performance". Some subjective reviews will show the AX86U outperforming the older AX88U @ distance for example.. It doesn't really matter.
The same way ill call out other "reviewers" for only posting Line of sight results. It's complete non sense... Just buy multiple routers and keep the best one that works in your home.
I would avoid 2x2 hardware coming from 3x3, but hey Im biased.
but had a 3x3 +3x3 config
How many of your clients support 3x3 and how many 4x4?Would recommended 4x4 main Radio for DFS
How many of your clients support 3x3 and how many 4x4?![]()
Only when we want to provide range over distance.is to provide range over distance on weaker 2x2 clients
Do you have any confirmed information about what exactly of provide range over distance can be talked about?
I'm afraid that the difference is so small that it is necessary to confirm the gain by testing and comparing the devices.
Should be superior to entry 2x2 + 2x2 solutions with legacy AC clients.
No. What matters most is RF design sensitivity*. The old AC68U is weaker than many newer 2x2 routers. Don't look the TX power and number of streams between few generations routers. There is a huge difference in both range and performance between BCM4360 and BCM4365E, both 3x3.
* - TP-Link provides the numbers in specs, unlike many other manufacturers (AX21 example, 5GHz):
BCM4366E (AC86U, AC 4x4) outperforms BCM43684 (AX86U, AX 4x4) in my environment as well. AX86U with it's 4x4 radio has the same range as AX20 with built-in SoC BCM6755 2x2 radio. Go figure. Perhaps there are other design elements in play here, not only the environment. By the way, some TP-Link routers have very high quality printed PCB antennas. High quality in sense well engineered.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
