[Tutorial] Webcam video surveillance via mjpg-streamer
Connecting to www.asuswrt.eu (www.asuswrt.eu)|91.216.151.23|:443... connected.
WARNING: cannot verify www.asuswrt.eu's certificate, issued by `/C=IL/O=StartCom Ltd./OU=Secure Digital Certificate Signing/CN=StartCom Class 1 Primary Intermediate Server CA':
Self-signed certificate encountered.
HTTP request sent, awaiting response... 200 OK
Length: 118633 (116K) [application/vnd.shana.informed.package]
Saving to: `/tmp/mjpg-streamer_r63-2_mipsel.ipk'
0% [ ] 0 --.-K/s in 0s
2014-11-04 17:04:25 (0.00 B/s) - Read error at byte 0/118633 (Invalid argument). Retrying.
Fixed, refresh page and try again.
@Paxsat Did you manage to install optware version?
I'm not at home, if I can try again tomorrow night to do the installation. Thanks
Inviato dal mio SM-N7505 utilizzando Tapatalk
admin@RT-N66U:/tmp/home/root# wget -c -O /opt/etc/init.d/S99webcam http://goo.gl
/4sFegj
Connecting to goo.gl (74.125.232.134:80)
Connecting to asuswrt.eu (91.216.151.23:80)
wget: server returned error: HTTP/1.1 416 Requested Range Not Satisfiable
/4sFegj
Requested Range Not Satisfiable error is when file is already downloaded.
ls -l /opt/etc/init.d/
proced with next step
admin@RT-N66U:/tmp/home/root# wget -c -O /opt/etc/webcam/videomod.sh http://goo.
gl/nHuCdc
Connecting to goo.gl (74.125.232.133:80)
go next step
gl/nHuCdc
go next step
Yes, already have have this file too
Two or more cameras.
Prompt, and possibly on the router to use more than one camera and how to set up in this case?
I want to try through USB HUB.
Dunno if is possible with multiple cameras but I tried with usb hub without success, maybe a powered hub.
Can I access the webcam with ipv6 address?
Use sixxs tunnel
the webcam stops after a few minutes. at the command ./S99webcam restart.. is ok for few minutes
in the log
Feb 19 13:19:14 kernel: uvcvideo: Failed to resubmit video URB (-27).
in the log
If you updated firmware to 378.50, you have to download updated modules from point 3
I [RT-AX86U Pro] Constant blips during video calls Asuswrt-Merlin 8
