[Tutorial] Webcam video surveillance via mjpg-streamer
Hey guys,
I have an Asus N56u running with Padavan firmware and I recently installed mjpg-stramer with a Logitech C310 webcam.
All works well until I stop S96mjpg-streamer. After that, I can no longer start the stream, I always get this error:
Feb 1 13:09:12 MJPG-streamer [1142]: starting application
Feb 1 13:09:12 MJPG-streamer [1142]: enabling daemon mode
Feb 1 13:09:12 MJPG-streamer [1144]: MJPG Streamer Version: svn rev: Unversioned directory
Feb 1 13:09:12 MJPG-streamer [1144]: Using V4L2 device.: /dev/video0
Feb 1 13:09:12 MJPG-streamer [1144]: Desired Resolution: 640 x 480
Feb 1 13:09:12 MJPG-streamer [1144]: Frames Per Second.: 15
Feb 1 13:09:12 MJPG-streamer [1144]: Format............: MJPEG
Feb 1 13:09:12 MJPG-streamer [1144]: www-folder-path...: /opt/share/www/webcam/
Feb 1 13:09:12 MJPG-streamer [1144]: HTTP TCP port.....: 3000
Feb 1 13:09:12 MJPG-streamer [1144]: username:password.: disabled
Feb 1 13:09:12 MJPG-streamer [1144]: commands..........: enabled
Feb 1 13:09:12 MJPG-streamer [1144]: starting input plugin input_uvc.so
Feb 1 13:09:12 MJPG-streamer [1144]: starting output plugin: output_http.so (ID: 00)
Feb 1 13:09:12 kernel: xhci-hcd xhci-hcd: Trying to add endpoint 0x81 without dropping it.
Feb 1 13:09:12 kernel: usb 1-2: Not enough bandwidth for altsetting 2
Feb 1 13:09:12 MJPG-streamer [1144]: Error grabbing frames
In order to fix the issue I restart the router and then I start the mjpg-streamer agan and it works.
Any idea why am I getting this error and how can I fix it without rebooting the router? maybe I also need to stop another process along with mjpg-streamer?
Thanks alot
I [RT-AX86U Pro] Constant blips during video calls Asuswrt-Merlin 8
