uiDivStats uiDivStats - WebUI for Diversion statistics
The size of dnsmasq.log* will cause this. A new and improved sqlite version is being worked on :)
Appreciate the response and I will patiently await the update!
A sneak peek of the reworked uiDivStats:
NoFreeWifi :D:D Do you live in a large populated area by chance? ;)
Looks great and can't wait!
Hi, (and excuse my bad english, it`s not my native language)
I have installed uiDivStats for the first time and recognized following:
"Domains on Blocklist" : the number is double of it should be.
For comparison in "Diversion":
I use only one blocklist at the moment (https://dbl.oisd.nl/)
Greetings
EDIT: I did some further research....Could it be that it does double blocked domain count because IPv6 is enabled in my case? That would make sense because every domain is represented as IPv4 and IPv6 = double count...?
Greetings
I’ll get that fixed in Jack’s code ASAP.
Yes, you are right. When you enable IPV6, blocked domain count in Diversion doubles.
Not in the Diversion UI but its stats function misses that division by two. And so does uiDivStats.
A pull request for @Jack Yaz uiDivStats has been made: https://github.com/jackyaz/uiDivStats/pull/24
- This fixes the double count in the stats function when IPv6 is enabled.
A minor update for the Diversion stats function has also been pushed, use u to update Diversion.
Is anyone else experiencing successful etc hosts lookups as blocked domains?
Possibly similar issue reported in the Diversion thread if those hosts IPs contain your Pixelserv IP (e.g. 192.168.50.2 and 192.168.50.28 or 192.168.50.205).
