Butterfly Bones
I like it, I guess you will add stats and what is blocked?For the curious, I've got a hardcoded bar chart on the latest WebUi page - thoughts?
ufWhere can we download it!![]()
the usual u option![]()
hover over the bars ;-)I have no data, just graph.
Yes - i've hardcoded sample data from my own stats for now as proof of concept - live data to come laterIs this using the new method RMerlin introduced to you?![]()
You'd be surprised how many services using Facebook's APIsHa, ha. I was wondering who was on facebook on my network (the correct answer is 'no-one')!![]()
It's possible, but I'm not sure what impact it will have on stat generation timeI didn't know about that! But none in my network.
A request, if possible. With the ability to hover over the bar chart we want information for, can there be more than 10, 20 or 50 bars now?![]()
Same here for meOn my RT-AC86U with 384.11 Beta 2, I have not seen the bottom graph populate from over 30 minutes ago.
I have updated using the 'u' and the 'uf' options. I have used the '1' option to generate the stats and have also waited for the 30 minutes for the stats to be updated like before on the half hour and hourly marks.
I also tried using the refresh trick CTRL F5 in Edge too.
Is there something I've missed?
I've been tweaking - try option u now and then generateOn my RT-AC86U with 384.11 Beta 2, I have not seen the bottom graph populate from over 30 minutes ago.
Working fine nowI've been tweaking - try option u now and then generate
Mm I've been dabbling with passing the -F option, and some loops seem to run twice when watching in htop - I'll message you my findings later to see if I'm on the right track@ColinTaylor brought up the merit of using Entware grep instead of the BusyBox grep in a conversation. This cuts down the time to generate the stats by more than 50%. I'll let you know what to change after some more testing @Jack Yaz.
Welcome To SNBForums
