Please provide screenshots/outputs of:I'm not sure exactly why but uiDivStats increases the CPU usage dramatically during high usage of dnsmasq, which means during heavy web surfing between multiple web pages but I guess this is expected but I'm not sure this is caused by uiDivstats directly.
This is with uiDivStats;
This is without;
maybe this is because of USB Stick write processes of uiDivStats I'm not sure but this is what I see.
On the other side; I can't feel any problems like web pages stuck or any other slowness.
atop #install from entware opkg install atop
htop #install from entware opkg install htop
df -Th | grep mnt | grep dev
I have security systems constantly chatting and i do not experience cpu issues. how do you have your diversion setup?I'm not sure exactly why but uiDivStats increases the CPU usage dramatically during high usage of dnsmasq, which means during heavy web surfing between multiple web pages but I guess this is expected but I'm not sure this is caused by uiDivstats directly.
This is without;
Code:atop #install from entware opkg install atop htop #install from entware opkg install htop df -Th | grep mnt | grep dev
admin@FaTiii:/tmp/home/root# df -Th | grep mnt | grep dev
/dev/sda1 ext2 14.7G 1.3G 12.6G 9% /tmp/mnt/entware
how many domains does your diversion blockfile block?Code:admin@FaTiii:/tmp/home/root# df -Th | grep mnt | grep dev /dev/sda1 ext2 14.7G 1.3G 12.6G 9% /tmp/mnt/entware
https://imgur.com/a/Iy8jmHd
atop is too complex for me but as I check htop I saw taildns and pixelserv-tls at the top most of the time, and this is when I try to access many pages in a couple of seconds.
Diversion 4.1.12 by thelonelycoder
RT-AC88U (armv7l) FW-384.17 @ 172.24.5.1
965,296 blocked domains by 2 hosts file(s)
356,841 t 14,528 w 10 n ads since Jun 17 08:26
/mnt/entware | Size 14.7G | Used 1.3G (9%)
d Diversion Standard enabled
c communication DivUn stats backup FWun
a ad-blocking to IP 172.24.5.254
l logging dnsmasq.log 25.5M
ep pixelserv-tls 172.24.5.254 v2.3.1
b blocking list Large Mon @ 1:00
el edit lists 210 w 22 b 0 wb 936 yt
f follow dnsmasq.log
ac update ads counter Auto-update au off
ds dnsmasq settings on
sw manage swap file /mnt/entware 1.0G
ct change theme colors green
sh shell history on
cj show cron job(s)
sf show file content
e exit u update less options o
Dnsmasq settings:
See the Dnsmasq man page what these options do:
http://www.thekelleys.org.uk/dnsmasq/docs/dnsmasq-man.html
1. Disable Dnsmasq settings
2. log-async 5
3. cache-size 1500
4. bogus-priv on
5. domain-needed on
6. log-queries=extra
Enter selection [1-6 e=Exit]
Code:Diversion 4.1.12 by thelonelycoder RT-AC88U (armv7l) FW-384.17 @ 172.24.5.1 965,296 blocked domains by 2 hosts file(s) 356,841 t 14,528 w 10 n ads since Jun 17 08:26 /mnt/entware | Size 14.7G | Used 1.3G (9%) d Diversion Standard enabled c communication DivUn stats backup FWun a ad-blocking to IP 172.24.5.254 l logging dnsmasq.log 25.5M ep pixelserv-tls 172.24.5.254 v2.3.1 b blocking list Large Mon @ 1:00 el edit lists 210 w 22 b 0 wb 936 yt f follow dnsmasq.log ac update ads counter Auto-update au off ds dnsmasq settings on sw manage swap file /mnt/entware 1.0G ct change theme colors green sh shell history on cj show cron job(s) sf show file content e exit u update less options o
Code:Dnsmasq settings: See the Dnsmasq man page what these options do: http://www.thekelleys.org.uk/dnsmasq/docs/dnsmasq-man.html 1. Disable Dnsmasq settings 2. log-async 5 3. cache-size 1500 4. bogus-priv on 5. domain-needed on 6. log-queries=extra Enter selection [1-6 e=Exit]
Disabling Dnsmasq settings does not change anything. I'm using Sandisk Extreme 16GB USB3.0 in USB 2.0 port.
atop screenshot is fine. htop shows that network map is using all of your CPU. try navigating to a static WebUI page (or logging out) and repeat the tests.Code:admin@FaTiii:/tmp/home/root# df -Th | grep mnt | grep dev /dev/sda1 ext2 14.7G 1.3G 12.6G 9% /tmp/mnt/entware
I experienced this same issue with the DS setting in diversion enabled along time ago before UiDivstats was around. I disabled it and rebooted the router and the problem went away.Logged out and opened many web pages in about 15-20 seconds, all loaded fine with no error and I got this;
Then I've uninstalled uiDivStats; flushed DNS of my PC and deleted databases of firefox and restarted.
this time (after uninstalling uiDivStats) I've tried to open 40 tabs as soon as possible and for your reference here my 9900K CPU usage during this;
I mean second test should be more intense for router but it didn't even sweat.
Mine are complety disabled meaning I do not have that diversion "experimental" feature enabled.Could you please send your current DS settings? Even I disable settings I think I can change bogus-priv and domain-needed.
Let me change the settings as same of yours reboot and check
That's a point. What filesystem and number of partitions do people have on their USB drive?
Code:admin@RT-AC86U:/tmp/home/root# df -Th | grep mnt | grep dev /dev/sda3 ext4 6.3G 2.7G 3.2G 46% /tmp/mnt/entware /dev/sda1 tfat 7.9G 1.3M 7.9G 0% /tmp/mnt/data
ASUSWRT-Merlin RT-AX88U 384.17_0 Sun Apr 26 02:29:04 UTC 2020
Makaveli@RT-AX88U-0B10:/tmp/home/root# df -Th | grep mnt | grep dev
/dev/sda1 ext4 436.6G 1.3G 412.0G 0% /tmp/mnt/Scripts
htop is showing hardly any cpu usage - do you see the 100% there or on network map? honestly, im starting to think network map is a steaming pile of s**t that causes the router to work overtime to show anythingHere we go.
Uninstalled 2.1.0
Deleted dnsqueries.db
Installed 2.1.0
Diversion and scMerlin are the the only scripts I currently have installed on 384.17. It has been at least a year since a factory reset and looking at an old screen shot I took of Diversion after first installing the version is 4.0.6.
Now seeing the cpu spiking to 100% and alternating between cores. It's been going at it for about 20 minutes now.
/dev/sda1 ext2 7.2G 2.1G 4.8G 30% /tmp/mnt/Diversion
Looks like the "complete" message only prints to the console at the moment, and wont appear in the log file. I assume that's where you're looking? I'll fix that for the next releaseGood catch. htop is not showing the spikes when I monitor it and it is showing around 1-4% usage. But...the last log entry from uiDivStats is:
Jun 17 11:05:23 uiDivStats: Starting first run of stat generation...
Should there be a log entry stating that the generation has completed? It's been running for over three hours now.
I am seeing values in the uiDivStats tab. On the DNS Queries graph the x-axis jives with the time that I installed 2.1.0. It's showing roughly 300 total DNS queries and ~50 blocked.
Just in case it might make a difference my stats config in Diversion is:
My USB stick does have an activity light and it seems way more active that it used to be. Pretty much going nonstop with a pause here and there.
Welcome To SNBForums
