uiDivStats - WebUI for Diversion statistics
Jack Yaz
Part of the Furniture
v2.3.0
Updated 2021-01-09
A graphical representation of domain blocking performed by Diversion.
uiDivStats is free to use under the GNU General Public License version 3 (GPL 3.0).
This project is hosted on GitHub
Love the script and want to support future development? Any and all donations gratefully received!
PayPal donation
Buy me a coffee
Supported firmware versions
You must be running firmware Merlin 384.15/384.13_4 or Fork 43E5 (or later) Asuswrt-Merlin
Installation
Using your preferred SSH client/terminal, copy and paste the following command, then press Enter:
/usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/jackyaz/uiDivStats/master/uiDivStats.sh" -o "/jffs/scripts/uiDivStats" && chmod 0755 /jffs/scripts/uiDivStats && /jffs/scripts/uiDivStats install
Usage
WebUI
uiDivStats can be configured via the WebUI, in the LAN section.
CLI
To launch the uiDivStats menu after installation, use:
uiDivStats
If this does not work, you will need to use the full path:
Screenshot
v2.3.0 is now available
Changelog:
  • NEW: Added feature to configure and update uiDivStats in the WebUI
  • NEW: Added feature to update daily stats in the WebUI
  • NEW: Added query log filter for type=65 queries to WebUI query log
  • NEW: querylog will attempt to clean up stale querylog processes
  • NEW: Added option to use logarithmic scale for charts, in addition to the default linear scale (credit to @dave14305 for adopting this in FlexQoS and inspiring me to add it)
  • IMPROVED: Query log in WebUI can now be sorted by clicking column headers
  • IMPROVED: WebUI help text if Diversion text stats report doesn't load
  • IMPROVED: Stat generation should be faster due to a new database index for client IPs (this will be created on update and may take some time)
  • CHANGED: Launch from post-mount on startup instead of services-start
