Unbound - Authoritative Recursive Caching DNS Server
DNS cache hit/miss ratio performance
stub-zone:
    stub-addr: 127.0.0.1
    stub-first: yes
Result:
total.num.queries=1710
total.num.queries_ip_ratelimited=0
total.num.cachehits=1027
total.num.cachemiss=683
total.num.prefetch=6
total.num.zero_ttl=0
total.num.recursivereplies=683
  • DoT should be disabled since it won't be used with Unbound.
  • DNSSEC can be disabled in the GUI since Unbound will do its own DNSSEC.
I've amended my dnsmasq.postconf to account for any DNSMASQ DNSSEC directives from the GUI. I don't change any nvram because if I disable Unbound, I still want DNSSEC for my ISP DNS servers.
#!/bin/sh
# Commented out here in case others do not use Diversion
#. /opt/share/diversion/file/post-conf.div # Added by Diversion
CONFIG=$1
. /usr/sbin/helper.sh
if [ -n "$(pidof unbound)" ]; then
        UNBOUNDLISTENADDR=$(netstat -nlup | grep unbound$ | grep "^udp " | grep " 127\.0" | head -1 | awk ' { print $4 } ' | tr ':' '#')
        if [ -n "$UNBOUNDLISTENADDR" ]; then
                pc_delete "servers-file" "$CONFIG"
                pc_delete "no-negcache" "$CONFIG"
                pc_delete "trust-anchor=" "$CONFIG"
                pc_delete "dnssec" "$CONFIG"
                pc_replace "cache-size=1500" "cache-size=0" "$CONFIG"
                pc_append "server=$UNBOUNDLISTENADDR" "$CONFIG"
                pc_append "proxy-dnssec" "$CONFIG"
        fi
fi
Yea I still use mine with Dot cannot get past the clear text access being sent to root sservers being accessible.
stub-zone:
    stub-first: yes
Result:
DNSFilter does not work Chromecast. Selecting by device I don't think is cool.
What do you think about these rules?
iptables -t nat -A PREROUTING -i br0 -p udp --dport 53535 -j DNAT --to "$(nvram get lan_ipaddr)"
iptables -t nat -A PREROUTING -i br0 -p tcp --dport 53535 -j DNAT --to "$(nvram get lan_ipaddr)"
iptables -t nat -A PREROUTING -s 192.168.1.0/24 -d 8.8.8.8 -p udp --dport 53535 -j DNAT --to 192.168.1.1
iptables -t nat -A PREROUTING -s 192.168.1.0/24 -d 8.8.4.4 -p udp --dport 53535 -j DNAT --to 192.168.1.1
With these rules unbound will work very well.
iptables -t nat -A PREROUTING -p udp --dport 53 --dst "$(nvram get lan_ipaddr)" -j DNAT --to-destination "$(nvram get lan_ipaddr)":53535
iptables -t nat -A PREROUTING -p tcp --dport 53 --dst "$(nvram get lan_ipaddr)" -j DNAT --to-destination "$(nvram get lan_ipaddr)":53535
iptables -t nat -A PREROUTING -s 192.168.1.0/24 -d 8.8.8.8 -p udp --dport 53535 -j DNAT --to "$(nvram get lan_ipaddr)"
iptables -t nat -A PREROUTING -s 192.168.1.0/24 -d 8.8.4.4 -p udp --dport 53535 -j DNAT --to "$(nvram get lan_ipaddr)"
Is this still being tested?
I didn't see it in the instructions on pg.1 unless I missed it, but under WAN, should these options be yes/no if we're wanting to try unbound:
Enable DNS rebind protection?
Enable DNSSEC support ?
Validate unsigned DNSSEC replies?
Also does the built in NTP option need to be off?
Under system administration:
Enable local NTP server?
Intercept NTP client requests?
no
What does this mean?
"Configure NTP server Merlin"
Enable local NTP server? yes or no
Intercept NTP client requests? yes or no
Just make sure the normal ntp sync is working. No need for running the extra ntp server. DNSSEC and DoT would need valid time as a prerequisite.
Thanks for the assist...one last question....once setup, how can I test if its working or doing its job?
/opt/etc/init.d/S61unbound check
ps | grep unbound | grep -v grep
netstat -lnptu | grep unbound
netstat -lnpt | grep -E '^Active|^Proto|/unbound'
unbound-control status
unbound-control stats_noreset
unbound-control -c /opt/var/lib/unbound/unbound.conf stats_noreset | grep total.num
one last question
Test these arguments with iptables. Many application or service requests have their own dns server encryption.
nano /jffs/scripts/firewall-start
iptables -t nat -A PREROUTING -i br0 -p udp --dport 53 -j DNAT --to IP_ROUTER
iptables -t nat -A PREROUTING -i br0 -p tcp --dport 53 -j DNAT --to IP_ROUTER
iptables -t nat -A PREROUTING -s IP_ROUTER.0/24 -d 8.8.8.8 -p udp --dport 53 -j DNAT --to IP_ROUTER
iptables -t nat -A PREROUTING -s IP_ROUTER.0/24 -d 8.8.4.4 -p udp --dport 53 -j DNAT --to IP_ROUTER
iptables -t nat -A PREROUTING -p udp --dport 53 --dst IP_ROUTER -j DNAT --to-destination IP_ROUTER:53535
iptables -t nat -A PREROUTING -p tcp --dport 53 --dst IP_ROUTER -j DNAT --to-destination IP_ROUTER:53535
I'm back to running Unbound with Diversion and dnsmasq. Smooth as silk. Took a tcpdump (am I allowed to say that?) and saw all the recursive queries going out to the various servers.
I did update my dnsmasq.postconf to combine my grep strings for UNBOUNDLISTENADDR:
#!/bin/sh
CONFIG="$1"
       UNBOUNDLISTENADDR=$(netstat -nlup | grep "^udp.* 127\.0\..*\/unbound$" | head -1 | awk ' { print $4 } ' | tr ':' '#')
       fi
fi
And I added an unbound-anchor update to the S61unbound startup to ensure the updates are happening.
#!/bin/sh
if [ "$1" = "start" ] || [ "$1" = "restart" ]; then
       # Wait for NTP before starting
       logger -st "S61unbound" "Waiting for NTP to sync before starting..."
       ntptimer=0
       while [ "$(nvram get ntp_ready)" = "0" ] && [ "$ntptimer" -lt "300" ]; do
               ntptimer=$((ntptimer+1))
               sleep 1
       done
       if [ "$ntptimer" -ge "300" ]; then
               logger -st "S61unbound" "NTP failed to sync after 5 minutes - please check immediately!"
               echo ""
               exit 1
       fi
fi
/opt/sbin/unbound-anchor -a /opt/var/lib/unbound/root.key
export TZ=$(cat /etc/TZ)
ENABLED=yes
PROCS=unbound
ARGS="-c /opt/var/lib/unbound/unbound.conf"
PREARGS="nohup"
PRECMD=""
POSTCMD="service restart_dnsmasq"
DESC=$PROCS
PATH=/opt/sbin:/opt/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
. /opt/etc/init.d/rc.func
