Unbound - Authoritative Recursive Caching DNS Server
I am pretty new to this stuff, but can follow instructions, Lol.
I have installed Unbound on my AX88U using the script. I am running Merlin 384.15.0 beta 1. The installation went well. However, when I use DNS Leak Test (https://www.dnsleaktest.com), it says that my DNS server is my ISP's. I am concerned as I set up Cloudflare in my router. Before I installed Unbound, the same test confirmed that I was using Cloudflare as my DNS servers.
Am I misunderstanding the concept here?
Just bought this router yesterday, running this script also, setup went well... Doing the dns leak test, mine is coming up with 4 servers, 2Cloudflare, then 2 others.. But none are my ISP
Refer post #930 above, directs you to where I had the same issue initially.....:)
FYI, my config; no Stubby integration, use Unbound’s native ad blocker, & the memory/performance =“y” during installation.
So if you upgrade, I would suggest these steps:
/opt/etc/init.d/S61unbound stop
service restart_dnsmasq
cp -p /opt/etc/init.d/S61unbound /opt/etc/init.d/xS61unbound.bak
opkg update
opkg upgrade
chown nobody /opt/var/lib/unbound
mv -f /opt/etc/init.d/xS61unbound.bak /opt/etc/init.d/S61unbound
/opt/etc/init.d/S61unbound start
There is also the return of the unbound-checkconf utility. install it with:
opkg install unbound-checkconf
So, for an amateur like me, I should stay away from that update until the Unbound guru/s get everything fixed maybe.....
Or maybe extend my very small scripts experience, & do as advised!:D
[Edit] & it’s done, didn’t hurt a bit!
Router Configuration recommended pre-reqs status:
[✔] Swapfile=3145720 kB
[✔] DNS Filter=ON
[✔] DNS Filter=ROUTER
[✔] WAN: Use local caching DNS server as system resolver=NO
[✔] Enable local NTP server=YES
[✔] Enable DNS Rebind protection=NO
[✔] Enable DNSSEC support=NO
Options:
[✔] unbound Logging
[✔] Stubby Integration
[✔] Ad and Tracker Blocking (No. of Adblock domains=51753,Blocked Hosts=1,Whitelist=22)
[✔] unbound CPU/Memory Performance tweaks
[✔] DNS Filter=ON
Options:
[✔] unbound Logging
The Stubby integration is why you’re seeing Cloudflare servers.
If you want Unbound to take over full dns duties, no need to integrate Stubby.:)
@rgnldo, @Martineau
Well, I don't claim to fully understand the reasons behind it, but hopefully this 2nd flare-up (in the space of a week), doesn't threaten to unravel the progress that has been made on this project. Gentlemen...for the sake of SNBforum community, please take a deep breath and step back temporarily until you feel you can recommit to this amazing project.
Is that the native unbound logging or syslog-ng/scribe logging?
I think i found problem -(at least it worked for me) when unbound logging was no longer working when upgraded to latest entware with scribe enabled.
I found that opt/etc/syslog-ng.d/unbound was set to other than octal 0600. Setting it to octal 0600 ( same as other files in this directory) fixed the logging issue.
@joe scian I just checked and mine is already set to octal 0600 but the GUI still freezes when on the System Log page when I enable it in uiScribe '1'. :(
Yes my problem was that logging wasnt happening at all after the upgrade - I am getting a little delay or freezing for a second or two when the unbound logging is there in scribe - but its not that bad at all on my ac 5300
I re-installed scribe, rebooted the router and now everything seems to be up-to-date and working as expected. :)
Thanks for the info, uninstalling
just saw this also: Stubby encrypts DNS queries sent from a client machine to a DNS Privacy resolver increasing end user privacy. So not sure if I should just leave it. or like you said let UNbound take over
A matter of preference really.
If you want DoT, (dns privacy), Unbound is probably superfluous/unnecessary for you?
If though, you want to have an ‘in house’ recursive resolver, unbound is good; disable dns privacy, reinstall Unbound without integrating stubby, let Unbound do its business.
Choices, choices......:)
'S02haveged' download FAILED with curl error 404
getting this error while trying to install it again?
Hmmm, I could be wrong, but looks like the project might be dead?:(:eek:
I’m off it till the protagonists can find some area of agreement.....
Ive just Format JFFS partition at next boot.. started fresh...and I get the same thing..just now
I get the same everytime
Rerun unbound_manager nochk and select the Remove Existing unbound Installation option
[✔] Swapfile=2097148 kB
[✔] DNS Filter=ON
Options: unbound Advanced install - User will be prompted to install options
Looks like you may be correct. I just uninstalled Unbound and will just keep monitoring the situation. It’s really a shame, there is real potential here.
