Treadler
As long as @Martineau is willing, we can persevere. Let’s all sleep on it and regroup in the morning.
One can but hope!
I for one, have reverted to my previous setup, & shall await developments
yea this is rather disappointing.As long as @Martineau is willing, we can persevere. Let’s all sleep on it and regroup in the morning.
go to first page of this thread - enter the command to install from terminal and follow prompts - its very easy and guides you through itI have been following this project for a while now and it's a shame that the main protagonists have their differences.
Still I would like to install Unbound but am lost on the options, both in the installer and which to set in the router itself.
Can someone point me to a good post explaining things?
I'd like to use it as intended, ad-blocking will be handled by Diversion.
Thanks for the input, I already did this before but I would like to know which options to choose like Stubby and stuff and more importantly the "why".go to first page of this thread - enter the command to install from terminal and follow prompts - its very easy and guides you through it
@rgnldo
You are again guessing which unbound parameters might be 'correct', but sneakily using the community as unwittingly exposed guinea pigs without the users' permission - suppose your tweaks are not valid on the target router?
e.g.
i.e. depending on when someone installs unbound, they may actually have any of the following:
Most do not understand the consequences nor indeed what the actual parameters mean, so you need to have a sense of responsibility and open disclosure.Code:edns-buffer-size: 1472 edns-buffer-size: 1232 incoming-num-tcp: 1000 incoming-num-tcp: 600 outgoing-num-tcp: 100
You are abusing the trust of users that wish to use my script to install unbound
THIS IS UNACCEPTABLE.
Add the rqeuested version header in 'unbound.conf' hosted on your GitHub together with a description of the change, so the script can advise if it may be necessary to review the changes you are testing.
...or do you still think your attitude is acceptable?
look fwd to that Jack !!As a quick fix, I have forked and reverted the deletion of the files here: https://github.com/jackyaz/Unbound-Asuswrt-Merlin
A quick sed on @Martineau installer to point to the fork will get people back up and running
I had just started looking into a WebUI for Unbound's stats...
The Brexiteers stand on their own feet.As a quick fix, I have forked and reverted the deletion of the files here: https://github.com/jackyaz/Unbound-Asuswrt-Merlin
I organized the post as it was from the beginning. Installation is intuitive and simple. If you chose to continue, feel free, you are in good hands.As a quick fix, I have forked and reverted the deletion of the files here: https://github.com/jackyaz/Unbound-Asuswrt-Merlin
The Swiss people elected twice (or maybe more times) not to join. We are the tiny grey island in the middle of the EU.Soon then as Singapore of the North Sea.
Unbound should also be a simple set-and-forget service. There isn’t much to configure and adjust. Don’t lose interest yet. I haven’t agreed with the choices to add ad-blocking and Stubby integration because those problems are already solved on Merlin’s firmware very well.
I’m very happy with my minimal config for Unbound and I hope that Martineau will import all the files (that Jack rescued) into his own repo and be the maintainer going forward. The rest of us can suggest changes or make pull requests, but there needs to be tight version control as Martineau has pleaded for at least twice.
I appreciate everyone’s contributions. We’ve come a long way. And with the latest Unbound now released, we’re much more secure.![]()
Welcome To SNBForums
