Martineau
Part of the Furniture
I've uploaded v2.08
Abject apologies to those who are obsessed with viewing statistics and have had to endure excruciating withdrawal symptoms!
Fix: 's+' and 'scribe' commands are no longer executed - broken in v2.07 i.e. new menu order 's*' took precedence
Fix: When uninstalling unbound using 'z' it would complain and leave package 'unbound-checkconf' behind:
Change: Implemented pull-request by @dave14305 to enhance Stubby-Integration for legacy routers running @john9527's 374.43 LTS releases
Existing unbound package found. Removing unbound
Removing package unbound-control-setup from root...
Removing package unbound-control from root...
Removing package unbound-anchor from root...
Removing package unbound-checkconf from root...
Collected errors:
* print_dependents_warning: Package unbound-daemon is depended upon by packages:
* print_dependents_warning: unbound-checkconf
* print_dependents_warning: These might cease to work if package unbound-daemon is removed.
* print_dependents_warning: Force removal of this package with --force-depends.
* print_dependents_warning: Force removal of this package and its dependents
* print_dependents_warning: with --force-removal-of-dependent-packages.
***Error occurred when removing unbound
