So what do I do to fix it. Already formatted the USB drive twice & installed form scratch.It looks like your cru l lines were missing, and unbound did not install properly.
Follow the install process correctly using instructions from the first page and the github if necessary. I am not able to replicate your issues, so I do not understand where the flaw in the process is. Or where the procedure failures is happening. Maybe post you whole ssh session with copy and paste so people can see what is happening when you install.So what do I do to fix it. Already formatted the USB drive twice & installed form scratch.
I did. Tried just now again with the one line command from github-Follow the install process correctly using instructions from the first page and the github if necessary. I am not able to replicate your issues, so I do not understand where the flaw in the process is. Or where the procedure failures is happening. Maybe post you whole ssh session with copy and paste so people can see what is happening when you install.
This time it didn't even wait for me to confirm-Try installing without logging.
Try running option z first and then rerun the installer. The errors seem to occur from your unbound.conf file tho because it is failing to check it as a proper config file.This time it didn't even wait for me to confirm-
Do you want to ENABLE unbound logging? (You can dynamically ENABLE/DISABLE Logging later from the main menu)
Reply 'y' or press ENTER to skip
/opt/var/run: No such file or directory
[1585562005] unbound-checkconf[15504:0] fatal error: pidfile directory does not exist
Restarting dnsmasq.....
Done.
***ERROR FATAL...ABORTing!
SameTry running option z first and then rerun the installer. The errors seem to occur from your unbound.conf file tho because it is failing to check it as a proper config file.
it wouldn't hurt, but i imagine if you have any old unbound files lingering around, that could also be causing this issue.Should I start from scratch again. Format jffs, format USB, install entware, create swap file then again install unbound? I did this just before & installed Skynet, Diversion which are running fine.
I might just reset the router too in the case? If the old unbound files were lingering around only in USB then USB format would have fixed this issue.it wouldn't hurt, but i imagine if you have any old unbound files lingering around, that could also be causing this issue.
Have you tested to see that unbound is in fact not working after installing by trying to load a browser or running a dig test just to confirm this isn't a glitch in the install process?I might just reset the router too in the case? If the old unbound files were lingering around only in USB then USB format would have fixed this issue.
How are you installing Entware? Some key files and directories seem to be missing based on your output.Should I start from scratch again. Format jffs, format USB, install entware, create swap file then again install unbound? I did this just before & installed Skynet, Diversion which are running fine.
I was installing through amtm. Have now reset the router, formatted USB using amtm,created swap file, installed entware again and then installed unbound without logging & adblocking, seems fine now. Now installing skynet then will install diversion.How are you installing Entware? Some key files and directories seem to be missing based on your output.
Curious, what does:I was installing through amtm. Have now reset the router, formatted USB using amtm,created swap file, installed entware again and then installed unbound without logging & adblocking, seems fine now. Now installing skynet then will install diversion.
ls -l /jffs/addons/unbound/unbound_stats.sh
chmod +x /jffs/addons/unbound/unbound_stats.sh
/jffs/addons/unbound/unbound_stats.sh install
It won't need the executable bit set if its prepended with sh.I see a small bug in the unbound_manager.sh, so it may not be executable. if you do not see RWX, the you need to make the script executable via:
Yes, but good point, maybe I should change the services scripts to be launched via sh to avoid the need for chmod.It won't need the executable bit set if its prepended with sh.
EDIT: nevermind, I think you mean after the install.![]()
If I want to add diversion on my current setup ( UnBound + Skynet) do I need to alter something on Unbound side or just install the script.
What do you advise.
Thank you.
Thank you.You can install diversion and it just configures DNSMasq for ad blocking. Since the solution in unbound_mangaer already uses DNSMasq, there is no change needed. However no need to run two ad blockers, so disable unbound's adblock portion and just alow diversion to do it.
Welcome To SNBForums
