Did you survive the Entware upgrade?What used to be a lean, mean recursive DNS SERVER now seems to have evolved into a bloated mess. No matter what I try, amtm will not install unbound. Keep getting errors and I am unable to resolve them. Oh well, it was good while it lasted. Back to Quad9.
opkg list-installed *unbound*
And that file is automatically generated from rpzsites file now during install of DNS Firewall option. No need to create that file.
Unfortunately I personally have several other files .txt and of course 'reset.conf'/'user.conf' plus various test/broken configs, but thanks for the tip.if all you have is configs in this directory, you could just make one solid directory and define it as a single one line in the unbound.conf file
Code:include: "/opt/share/unbound/configs/*"
I did quickly post the solution (as identified by others) here, but I can't be held responsible for the Entware fiasco through your use of amtm.No matter what I try, amtm will not install unbound. Keep getting errors and I am unable to resolve them. Oh well, it was good while it lasted. Back to Quad9.
Well thanks for this overwhelmingly disappointing expression of support for my effortsWhat used to be a lean, mean recursive DNS SERVER now seems to have evolved into a bloated mess.
...... yet another reason to throw in the towel and delete my posts and remove such offending scripts.
Good luck with Quad9 etc.
Regards,
Well thanks for this overwhelmingly disappointing expression of support for my efforts;.... yet another reason to throw in the towel and delete my posts and remove such offending scripts.
Regards,
Why not build in a check and correct it, this has nothing to do with amtm. Since your installer does install it why not do the right thing?I did quickly post the solution (as identified by others) here, but I can't be held responsible for the Entware fiasco through your use of amtm.
Regards,
Collected errors:
* check_data_file_clashes: Package libunbound-light wants to install file /opt/lib/libunbound.so.8
But that file is already provided by package * libunbound
* opkg_install_cmd: Cannot install package unbound-checkconf.
***ERROR occurred installing unbound
<sigh>Why not build in a check and correct it, this has nothing to do with amtm. Since your installer does install it why not do the right thing?
Code:Collected errors: * check_data_file_clashes: Package libunbound-light wants to install file /opt/lib/libunbound.so.8 But that file is already provided by package * libunbound * opkg_install_cmd: Cannot install package unbound-checkconf. ***ERROR occurred installing unbound
Please select an option: lr
running logrotate ... done.
checking logrotate log for error
==> /opt/tmp/logrotate.daily <==
Press [Enter] to continue:
I was kindly asking to build in a fix or the users sake. Nowhere do I accuse or insult you or your intelligence.<sigh>
So here we go again, spitefully, "do the right thing?' (not at all passive aggressive eh?) criticising my script although this time you will have to continue to do it publicly rather than via your previous PMs.
Realistically I don't feel that the script could ever be coded to intelligently (using AI) to comprehensively interpret every single possible reason in the future why the Entware package install suddenly failed.
Clearly, with the benefit of the technical hindsight, I could now proactively recognise the 'check_data_file_clashes:' and parse the rest of the error message to generate/issue the necessary appropriate recovery command, but apparently the script's current methodology allowed a competent knowledgeable user to instantly recognise immediately what the underlying issue was and within 5 minutes generously posted the technical solution to assist others.
Q. How many other scripts do this 'auto-healing' ?
P.S. I never stated/implied that amtm was the cause either...although some posts may try and put 2+2 to make 5 here
Yet another self esteem knock......and I haven't had coffee yet.
Diversion does, as did AB-Solution in its days. And amtm - the whole script is built as an "auto self-healing" app.Q. How many other scripts do this 'auto-healing' ?
I'm moving on...Please--I don't want two of my favorite people here at odds with one another.
Welcome To SNBForums
