Unbound unbound_manager (Manager/Installer utility for unbound - Recursive DNS Server)
Here is a screenshot of the statistics before.
A screenshot of "rs" does not work.
And the code and statistics (open spoiler) after the firewall restart. (didn't fit all in one screenshot)
Maybe I understand something wrong with cache?
Edit:
And why are the attached screenshot so small after uploading to snb?
unbound (pid 12082) is running... uptime: 0 Days, 06:46:33 version: 1.10.0 # rgnldo Github Version=v1.09 Martineau update (Date Loaded by unbound_manager Fri Apr 17 23:40:00 DST 2020)
1 = Update unbound files and configuration
2 = Remove unbound/unbound_manager
3 = Stop unbound
4 = Show unbound statistics
5 = Install Ad and Tracker blocker (Ad Block)
6 = Install Graphical Statistics GUI Add-on TAB
7 = Enable DNS Firewall
? = About Configuration
v = View ('/opt/var/lib/unbound/'unbound.conf)
e = Exit Script [?]
E:Option ==> 7
Do you want to enable DNS Firewall?
Reply 'y' or press [Enter] to skip
y
unbound_rpz.sh downloaded successfully
Custom '/opt/share/unbound/configs/rpzsites' already exists - 'rpzsites' download skipped
Created startup hook in services-start.
Created cron job.
Creating new unbound.conf.firewall file.
(unbound_rpz.sh): 27269 Attempting to Download 1 of 1 from https://urlhaus.abuse.ch/downloads/rpz/.
######################################################################## 100.0%
Adding zone rpz.urlhaus.abuse.ch to unbound.conf.firewall.
Installed.
Adding 'include: "/opt/share/unbound/configs/unbound.conf.firewall" '/opt/var/lib/unbound/unbound.conf'
unbound DNS Firewall ENABLED
unbound-checkconf: no errors in /opt/var/lib/unbound/unbound.conf
Shutting down unbound... done.
Starting unbound... done.
Checking status, please wait..... unbound OK
Router Configuration recommended pre-reqs status:
[✔] Swapfile=2097148 kB
[✔] DNS Filter=ON
[✔] DNS Filter=ROUTER
[✔] WAN: Use local caching DNS server as system resolver=NO
[✔] Enable local NTP server=YES
[✔] Enable DNS Rebind protection=NO
[✔] Enable DNSSEC support=NO
Options:
[✔] unbound CPU/Memory Performance tweaks
[✔] unbound-control FAST response ENABLED
[✔] DNS Firewall ENABLED
unbound (pid 27399) is running... uptime: 0 Days, 00:00:09 version: 1.10.0 # rgnldo Github Version=v1.09 Martineau update (Date Loaded by unbound_manager Fri Apr 17 23:40:00 DST 2020)
3 = Stop unbound
7 = Disable DNS Firewall [?]
e = Exit Script [?]
E:Option ==> 4
total.num.queries=0 total.num.prefetch=0 total.requestlist.max=0 total.requestlist.current.user=0 msg.cache.count=1011
total.num.queries_ip_ratelimited=0 total.num.expired=0 total.requestlist.overwritten=0 total.recursion.time.avg=0.000000 rrset.cache.count=5580
total.num.cachehits=0 total.num.recursivereplies=0 total.requestlist.exceeded=0 total.recursion.time.median=0 infra.cache.count=0
total.num.cachemiss=0 total.requestlist.avg=0 total.requestlist.current.all=0 total.tcpusage=0 key.cache.count=0
Summary: Cache Hits success=0.00%
unbound (pid 27399) is running... uptime: 0 Days, 00:00:14 version: 1.10.0 # rgnldo Github Version=v1.09 Martineau update (Date Loaded by unbound_manager Fri Apr 17 23:40:00 DST 2020)
3 = Stop unbound
e = Exit Script [?]
E:Option ==>
Unfortunately your very small picture doesn't help, but I think shows
before
msg.cache.count=24xx
rrset.cache.count=69xx
and after
The after cache reference statistics
total.num.queries=0
show that you have made no requests to reference either the preserved 1011 msg.cache entries nor to the preserved 5580 rrset.cache entries available.
You are therefore wrong in your assumption that the cache is totally trashed, it's only the cache reference statistics (rather than the cache contents) that is lost after an unbound restart.
Do you understand the difference?
I would leave it as 1. That would be optimal for you.
Yes, given forked operation each thread is really a new process.
In the GUI report I purposely show these two items for this reason, to allow people to tweak.
Number of queries dropped because request list was full: 0
 Average number of requests in list for recursive processing: 0.735453
On my network the request list was never so full it dropped any requests. Secondly, the number of requests to be recursively processed ( remember cache hits are super fast, just recursive get stats) is under 1, meaning it never has a queue really.
I would guess that number would have to be entering double digits to justify another process.
That is my thinking. But perhaps others feel differently.
Thank you for realizing this feature! Setting up is much easier by your script. And if the VPN-IP of tun1 changes (it sometimes doe...) , it is quite simple to correct within unbound. Perfect!
Kudos to yourself, for innovating/proving the concept :)
So hopefully if you have the time, could you test my 'bloated mess!' :p of a script further?......you should be able to automate the process when the VPN IP changes:
Use the openvpn-event trigger
EDIT: As per post #1574
i.e. vpnclient1-up
/jffs/addons/unbound/unbound_manager.sh   vpn=1   delay=1   &
vpnclient1-route-pre-down
/jffs/addons/unbound/unbound_manager.sh   vpn=disable
Pushed an updated GUI stats change. Fixed display issues, script issues during install and added some features. You do not need to enable the new features as from my testing this should work just fine without that date (but will show some sections with No Data).
- Added adblocked stats (requires log-local-actions enabled)
- Added DNS Firewall stats (requires DNS Firewall enabled, log-rpz)
- Added Top Reply Domains (requires DNS Firewall enabled)
To support this log scraping is done every hour, but if logs not enabled this has no impact.
NOTE: you will need to re-install GUI Stats to get new files and install new tasks.
-- edit ---
Also, it seems unbound team has fixed the URL: issues with the urlhaus site. Seems they didn't support TLS SNI checks for their cert and they have added it. Will need to enable the new tls-use-sni: conf once we have a build in entware that has this change. Likely a few months.
https://github.com/NLnetLabs/unbound/issues/193
@JGrana
Here's your services-start copied from other thread
Sure. Here is my services-start:
#!/bin/sh
/jjfs/scripts/setbashrc.sh
/jffs/scripts/uiScribe startup # uiScribe
/jffs/scripts/connmon startup # connmon
if [ -x /jffs/scripts/MountNAS.sh ]; then
/jffs/scripts/MountNAS.sh # mount local QNap Nas
fi
/jffs/scripts/ntpmerlin startup # ntpMerlin
cru a root_servers "12 4 * * * curl -o \/opt\/var\/lib\/unbound\/root\.hints https://www.internic.net/domain/named.cache" # unbound_manager
cru a UpdateRPZ "*/15 * * * * /opt/var/lib/unbound/rpzupdate.sh"
/jffs/addons/unbound/unbound_rpz.sh startup # Unbound_RPZ.sh
/jffs/addons/unbound/ubcash restore & # Restire Unbound cache if not too old
/jffs/scripts/spdmerlin startup & # spdMerlin
Note - MountNAS.sh is a one-line script that mounts my local NAS share (smb)
ubcash restore is a home made script that reloads unbounds cache if less than 10 mins old.
I don't see unbound in my services start as well as please eleborate MountNAS.sh?
Start unbound_manager and request the VPN
e.g. VPN Client 1
e  = Exit Script [?]
A:Option ==> vpn 1
Option Auto Reply 'y'
 unbound requests via VPN Client  tunnel ENABLED
[/CODE]
For some odd reason, I'm stuck here. When I start unbound_manager and request to look at VPN 1, I keep getting the: "Invalid option "vpn 1" Please enter a valid option.
I'm currently using VPN 1.
Check the VPN config in 'unbound.conf' (or use 'v')
grep VPN /opt/var/lib/unbound/unbound.conf
#outgoing-interface: xxx.xxx.xxx.xxx        # v1.08 Martineau Use VPN tunnel to hide Root server queries from ISP
Check VPN status
ip route show | grep tun1
e.g. VPN Client 1
e  = Exit Script [?]
A:Option ==> vpn 1
'unbound.conf' entry should show VPN IP address
outgoing-interface: 100.120.223.42        # v1.08 Martineau Use VPN tunnel to hide Root server queries from ISP
To reset unbound to the WAN
e  = Exit Script [?]
A:Option ==> vpn disable
 unbound requests via VPN Client tunnel DISABLED
cromo@RT-AX88U:/tmp/home/root# unbound_manager vpn=2
/opt/bin/unbound_manager: local: line 3725: 2: bad variable name
sed: unmatched '/'
[1587236484] unbound-checkconf[23944:0] error: cannot parse ip address: 'xxx.xxx.xxx.xxx'
[1587236484] unbound-checkconf[23944:0] fatal error: cannot parse outgoing-interface specified as 'xxx.xxx.xxx.xxx'
***ERROR requested re(Start) of unbound ABORTed! - use option 'vx' to correct 'unbound.conf' or 'rl' to load a valid configuration file
should i have set the IP on the conf file first?
@JGrana
#!/bin/sh
fi
Unbound is started by /opt/etc/init.d - not services-start. The periodic updating of information (root_servers and rpz) are handled by services-start (via a cron job/cru).
The MountNAS.sh is an older script I wrote that mounts a partition from a NAS to the router (using SMB). I used to coordinate a back up job with it. I left it in - it's often a quick way to move files between other PC's in my house and the router. Im too lazy to look for and plug in USB sticks ;-)
sed: unmatched '/'
I've pushed a Hofix; use 'u' when it appears.
Version=3.04 md5=c72b117b0a1c009e30a49c849e168fac
although I can't replicate the 'sed' error.. but the xxx.xxx.xxx.xxx is correctly replaced in 'unbound_conf':confused:
 unbound_manager vpn=1
/opt/bin/unbound_manager: local: line 3725: 1: bad variable name
Adding 'include: "/opt/share/unbound/configs/unbound.conf.add"  '/opt/var/lib/unbound/unbound.conf'
In 'Easy' menu mode, many commands are not available - particularly experimental 'Advanced' commands/features.
it works!
thanks!
if vpn goes down, dns stops, right? or is there a fallback?
Yes, if the VPN disconnects then unbound will stop.
The feature is currently experimental to use at your own risk.
However, as an 'Advanced' user, you will need to ensure that you implement a fallback
vpnclientX-route-pre-down
unbound_manager   vpn=disable
etc.
etc.
thank you,
do I simply create /jffs/scripts/vnpclient1-route-pre-down and /jffs/scripts/vpnclient1-route-up, and they are automatically called on those events?
[edit]
found it: i needed to get a copy of /jffs/scripts/openvpn-event too
Ok ...I apologize for my ignorance, but how do I get to advanced mode?
Check VPN status
[/CODE]
Ok, finally im getting somewhere haha. So when I run the command "ip route show | grep tun1" I get the following:
admin@RT-AX88U-xxxx:/tmp/home/root# ip route show | grep tun1
10.16.10.9 dev tun11 proto kernel scope link src 10.16.10.10
Do I simply copy and paste the 10.16.10.9 to the unbound script?
Why not follow the instruction in post #1500:rolleyes:
