URL-Fliter limit??
tsunami2311
Like the title says is there limit to how many urls I can put in there before it becomes detrimental to the router? I have started the process of filtering out streaming sites. up to about 35+ and was wonder if to many will cause an issue?
If would at somepoint I will do this threw opendns url blocking but that requires me to keep updating my ip on there end
How about opendns and no-ip?
Look into using IPSET instead. I think there is an example in the wiki.
I want it to just terminate like the site dont existent or is down. using opendns has no option to silently block the site, the Url-Filter just terminates that connection like it dont exist or is down.
https://github.com/RMerl/asuswrt-merlin/wiki/Disable-Windows-10-tracking
And this dont explain how to MAKE said txt file that is needed to use the scripts or how to make the other scripts even when i follower all the stuff in the code box exactly how they was posted there it did nothing which why i never bother.
side question in system log>connection I gathering that just show IP's and not the name of the site? cause I only ever seen it show ip's if it showed names I could use that to find which sites i need to block instead broadly blocking them.
OK. Well, I like the ipset idea. I use iptables to drop packets from certain IPs or MACs. There's probably a way to specify destination addresses, although I'm not sure you will get DNS resolution.
Another way is to use WFilter. It also uses a blocking page, but the page is customizable. I suppose you could create a blank page or something like that.
I see them. but back to my original question is there limit to how many i can put in there and will it be detrimental to router performance if to much is block there.
