Hi all,
I use an RT-N66U and Western Digital 2TB USB2 external drive.
Firmware Version:3.0.0.4.354.29 (Merlin build)
Has anyone come across these "error -62" errors:
I had the 2TB external drive working very nicely for VPN and SVN but last week the USB ports seem to have gone inactive. This hapened with the 270 version of Merlin, so the first thing I did was upgrade to the new beta but that did not help.
I have tried multiple different USB external storage device, all of which mount fine on Windows machines. I have tried several different USB cables. I also formatted my 2TB to ext3 on a linux machine and it was mounted OK on the Linux box.
Nothing gets seen by the N66U on USB anymore though.
Any ideas? Much appreciated if you have
Cheers,
Andy
Jan 1 00:00:07 kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:07 kernel: usbcore: registered new interface driver usb-storage
Jan 1 00:00:07 kernel: USB Mass Storage support registered.
Jan 1 00:00:07 kernel: ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c0202000
Jan 1 00:00:07 kernel: NTFS (with native replay) support included
Jan 1 00:00:07 kernel: optimized: speed
Jan 1 00:00:07 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Jan 1 00:00:07 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 1 00:00:07 kernel: ehci_hcd 0000:00:04.1: EHCI Host Controller
Jan 1 00:00:07 kernel: ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
Jan 1 00:00:07 kernel: ehci_hcd 0000:00:04.1: EHCI Fastpath: New EHCI driver starting
Jan 1 00:00:07 kernel: ehci_hcd 0000:00:04.1: irq 6, io mem 0x18004000
Jan 1 00:00:07 kernel: ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
Jan 1 00:00:07 kernel: usb usb1: configuration #1 chosen from 1 choice
Jan 1 00:00:07 kernel: hub 1-0:1.0: USB hub found
Jan 1 00:00:07 kernel: hub 1-0:1.0: 2 ports detected
Jan 1 00:00:07 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jan 1 00:00:07 kernel: ohci_hcd 0000:00:04.0: OHCI Host Controller
Jan 1 00:00:07 kernel: ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2
Jan 1 00:00:07 kernel: ohci_hcd 0000:00:04.0: irq 6, io mem 0x18009000
Jan 1 00:00:07 kernel: usb usb2: configuration #1 chosen from 1 choice
Jan 1 00:00:07 kernel: hub 2-0:1.0: USB hub found
Jan 1 00:00:07 kernel: hub 2-0:1.0: 2 ports detected
Jan 1 00:00:07 kernel: usbcore: registered new interface driver usblp
Jan 1 00:00:07 kernel: drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
Jan 1 00:00:07 kernel: usbcore: registered new interface driver asix
Jan 1 00:00:08 kernel: usb 2-1: new full speed USB device using ohci_hcd and address 2
Jan 1 00:00:08 kernel: usb 2-1: device descriptor read/64, error -62
Jan 1 00:00:08 kernel: usb 2-1: new full speed USB device using ohci_hcd and address 3
Jan 1 00:00:09 kernel: usb 2-1: device descriptor read/64, error -62
Jan 1 00:00:09 kernel: usb 2-1: new full speed USB device using ohci_hcd and address 4
Jan 1 00:00:09 kernel: usb 2-1: device not accepting address 4, error -62
Jan 1 00:00:09 kernel: usb 2-1: new full speed USB device using ohci_hcd and address 5
Jan 1 00:00:10 kernel: usb 2-1: device not accepting address 5, error -62
Jan 1 00:00:10 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jan 1 00:00:10 kernel: usbcore: registered new interface driver cdc_ether
Jan 1 00:00:10 kernel: usbcore: registered new interface driver net1080
Jan 1 00:00:10 kernel: usbcore: registered new interface driver rndis_host
Jan 1 00:00:10 kernel: usbcore: registered new interface driver zaurus
Cheers,
Andy
