VPNMON VPNMON-R3 v1.3.10 -Jan 1, 2025- Monitor WAN/Dual-WAN/OpenVPN Health & Reset Multiple OpenVPN Connections (Now available in AMTM!)
@Viktor Jaep Suggestion for a new feature - would it be possible to add an option to schedule the vpn server list update (Option U from the main menu), say daily or weekly etc.?
It seems NordVPN have been adding/removing servers in recent weeks, which then causes VPNMON to try and connect to a server which doesn't exist.
Hey @TITAN... it should automatically refresh the list if you have option #5 enabled, ie. when it resets your connection. You currently can schedule a reset anytime/frequency with a custom cronjob, or schedule for it to happen 1x a day from within VPNMON. Are you looking for the custom server list to refresh without a connection reset?
I think that's exactly what I want, I have now enabled it so let's see how I go
Thanks @Viktor Jaep
Not yet, but that is definitely on my to-do list... 😉
Hey - thanks so much for your "coffee" donation! I truly appreciate it! ♥️
I don't know if this will help in the process, but I found this yesterday and was able to modify it so that I can now use WireGuard to connect to my Dedicated IP with Nord.
It's strange but that guide was no help to me. How did you get the option to generate a new token? I can't find it anywhere.
Yeah, the process changed a little in the past year.
  1. Log into your Nord dashboard.
  2. Go to Manual Setup.
  3. Click Get Access Token.
  4. Verify if needed (I have 2FA on, so I had to verify using the code sent via email).
  5. Generate a new token.
  6. You only need the token for a short period of time to obtain your Private Key, so you can use a 30 day expiration.
Wow, that was easy. Quick question. Do you know if there's a way to pass a specific city to the api to generate more local configs, ie the default for the uk is London, but I'm nowhere near there? I can get openvpn files more local and with a better ping. Right now I have 2 choices, better speed (great for upload/download) or better ping (great for gaming).
You should be able to use the exact same query you use for OVPN to narrow between types but then also include that you want WireGuard servers (which I think all are). With that, you can create your own. As an example, I took the default from that website which returned three conf files and modified only the Endpoint. Everything else stayed the same. This thread has a few tutorials on how to run various queries: https://www.snbforums.com/threads/v...list-generation-tutorials-and-examples.88022/
Could not load from AMTM. Entering vp did nothing. Probably broken.
Was able to add with this:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/VPNMON-R3/main/vpnmon-r3.sh" -o "/jffs/scripts/vpnmon-r3.sh" && chmod 755 "/jffs/scripts/vpnmon-r3.sh"
Just tried - I didn't have any issue. Just uninstalled VPNMON-R3 from my test router... used AMTM to install it with the 'vp' option. Subsequently was able to open it back up from AMTM with 'vp'. But glad to see you found a workaround to getting it installed! :)
Sorry, The USB my swap file is on became disconnected. I think that was the reason
