user1234567890
Thanks. There's no ethernet in any part of the house, apart from the room where the router is, and it is all connected in relatively short 3m runs, and all hidden and tidied behind a big AV cabinet, and normally it is pristine, but at the moment, it's a mess, because I keep changing routers and other devices. It's easy enough for me to run a cable from downstairs to upstairs, but it will mean running it outside.I was under impression you do have Ethernet around the house. If you don't - this changes the game.
Was this old router enough to cover the place? If yes or almost - you better get a new All-In-One router. I would try RT-BE88U, it's dual-band, but it has expected better range and all the ports you need in one reasonable priced device. It may have some firmware quirks, but based on user feedback works well. You have to set some realistic expectations and find the balance between cost and speed. If you go for speed in this thick brick walls house the cost of the project including new Ethernet infrastructure may jump sky high.
So, regarding the 2.5gbe question. I was thinking that with the faster wifi 6e speeds, two of us connected at once working (zoom, teams etc), plus daughter on YouTube may saturate a 2.5gbe?
The old router was ok. it wasn't outstanding as far as coverage goes. Upstairs was obviously much less and there was nothing at all outside in the garden, and there is now with the BE98. I would like to keep that strength of signal if possible, all over the house. I saw the U7 Pro Wall, and that has a 2.5gbe, and ticks all the other boxes, do you reckon that would be enough for a busy family/working from home setup, or add a second one upstairs? I do have realistic expectations, but this is all new territory for me, so if it seems like I don't, it's just lack of knowledge on this subject, which is why I'm here
As for ideal conditions, well, no. It's an unusual house, in that the main supporting wall through the centre, is also a chimney, which is about 4 or 5 bricks thick, so that can cause wifi problems if the signal is not that great to start with. It's fine with the BE98 all over the house and in the garden. With the RT-AC68U, the ring doorbell would sometimes disconnect. and the signal was not the best on the back bedroom, but it was useable.
