Jack Yaz
Part of the Furniture
Most of my scripts have an option to store data on USB, particularly those that use databases. I'm gradually adding that ability to all of themNvram is quite small compared to jffs. On my AX88U, nvram is 128KB and jffs is 63MB. Huge difference!
As a result, as Asus has added more and more important values/settings/variables to nvram (so it survives reboots and resets) the need to find areas to "reduce" usage is expected. DHCP static is one area that has been reduced, I believe once before this time as well. Nvram is critical - jffs is the next spot to move things to.
The main problem (for us users) in using jffs is that, unlike nvram, it is not really permanent. A factory device reset and/or a "format jffs at next boot" will erase what you have in jffs.
As users of these fine addons, we should remember to backup jffs to USB once in a while.
