Your issues are most likely not tied to YazFi if main LAN/WiFi clients are also affected. As a troubleshooting step you can disable the YazFi Guest network and see if the DNS issues persist.
Another troubleshooting step is to experiment using other public DNS servers:
https://www.lifewire.com/free-and-public-dns-servers-2626062
Are you running any other scripts on Asus-Merlin?
What does a trace route to the DNS servers you are using show?
Does the issues persist if you turn off/power off all other network devices except one local network computer connected by Ethernet directly to the Asus-Merlin router?
Have you looked into if your broadband provider is having network issues that may contribute to your DNS issue(s)?
Yea thats what I thought too, which is why I first asked in the thread for the current version of john's fork which Im using. John suggested that while he isn't familiar with how YazFi works, perhaps a loop of continually trying to redirect DNS requests is happening if YazFi uses a DNSfilter, which is why I thought to ask here as well.
have tried switching from 8.8.8.8 to 1.1.1.1 will give it a few days and report back on the results
nop. at least not as far as i know! I did a full factory reset to install john's fork and only recently installed YazFi. Did not configure any other script.
Here's what i got
C:\Users\xxxxx>tracert 8.8.8.8
Tracing route to 8.8.8.8 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms RT-AC66U [192.168.0.100]
2 3 ms 3 ms 3 ms 175.142.207.254
3 5 ms 7 ms 6 ms 10.55.106.17
4 6 ms 4 ms 7 ms 10.55.100.197
5 7 ms 4 ms 7 ms 10.55.48.200
6 7 ms 7 ms 8 ms 72.14.204.208
7 17 ms 19 ms 19 ms 216.239.47.169
8 7 ms 8 ms 9 ms 72.14.239.243
9 7 ms 7 ms 7 ms 8.8.8.8
Trace complete.
This will be a tough one to test out. the family uses the internet 24/7, with one of my more nocturnal sibling typically up even up at 3 or 4am. Will need to try and find a brief moment when i can do this test.
What i can say is that the issue is definitely happening on both LAN and wireless devices, as well as devices connected to the guest network. I have a headless raspberry pi connected to the guest network (isolated), and last night i had trouble running
sudo apt distro-upgrade or
sudo apt install xxx because it would keep running into "temporarily failed to resolve" errors and would need to rerun the commands with --fix-missing once or twice
I haven't a clue as to how i'd investigate this. My problems only appeared after updating the firmware to 51e3 and installing yazfi (unclear exactly when as I waited a few days after firmware update to install yazfi, but only noticed it after installing yazfi)
What I can say is that when I turn on nordVPN on my computer and force all traffic including DNS queries through the tunnel than there's absolutely no problem. DNS resolves lightning fast.
I do have my old ISP provided router somewhere. Let me try replacing my AC66U with that and see if the problem persists
