YazFi YazFi - enhanced AsusWRT-Merlin Guest WiFi inc. SSID <-> VPN Client
I suspect this might be the nvram variables for isolation misbehaving. Can you reproduce with a reboot? V3.0.5 is going to do more than validation on the variables for isolation
I was not able to reproduce any problem from a router reboot.
Before reboot:
# nvram getall | grep isolat | sort
size: 65327 bytes (65745 left)
wl0.1_ap_isolate=1
wl0.2_ap_isolate=0
wl0.3_ap_isolate=0
wl0_ap_isolate=1
wl1.1_ap_isolate=0
wl1.2_ap_isolate=0
wl1.3_ap_isolate=0
wl1_ap_isolate=0
wl2.1_ap_isolate=0
wl2.2_ap_isolate=0
wl2.3_ap_isolate=0
wl_ap_isolate=1
After reboot:
size: 65241 bytes (65831 left)
wl0.1_ap_isolate=1
wl0.2_ap_isolate=0
wl0.3_ap_isolate=0
wl0_ap_isolate=1
wl1.1_ap_isolate=0
wl1.2_ap_isolate=0
wl1.3_ap_isolate=0
wl1_ap_isolate=0
wl2.1_ap_isolate=0
wl2.2_ap_isolate=0
wl2.3_ap_isolate=0
wl_ap_isolate=1
YazFi: YazFi v3.0.4 starting up
YazFi: wl0.1 passed validation
YazFi: wl0.1 (SSID: 223_110_IoT) - sending all interface internet traffic over WAN interface
YazFi: YazFi v3.0.4 completed successfully
Feb 22 12:26:02 router YazFi: YazFi v3.0.4 starting up
Feb 22 12:26:03 router YazFi: wl0.1 (SSID: 223_110_IoT) - sending all interface internet traffic over WAN interface
Feb 22 12:26:06 router YazFi: YazFi v3.0.4 completed successfully
Feb 22 12:26:06 router YazFi: Forcing YazFi Guest WiFi clients to reauthenticate
Feb 22 15:44:14 router YazFi: YazFi v3.0.4 starting up
Feb 22 15:44:15 router YazFi: wl0.1 (SSID: 223_110_IoT) - sending all interface internet traffic over WAN interface
Feb 22 15:44:19 router YazFi: YazFi v3.0.4 completed successfully
Feb 22 15:44:46 router YazFi: YazFi v3.0.4 starting up
Feb 22 15:44:47 router YazFi: wl0.1 (SSID: 223_110_IoT) - sending all interface internet traffic over WAN interface
Feb 22 15:44:50 router YazFi: YazFi v3.0.4 completed successfully
Before reboot:
wl0.1_ap_isolate=1
wl0.2_ap_isolate=0
wl0.3_ap_isolate=0
wl0_ap_isolate=1
wl1.1_ap_isolate=0
wl1.2_ap_isolate=0
wl1.3_ap_isolate=0
wl1_ap_isolate=0
wl2.1_ap_isolate=0
wl2.2_ap_isolate=0
wl2.3_ap_isolate=0
wl_ap_isolate=1
After reboot:
wl0.1_ap_isolate=1
wl0.2_ap_isolate=0
wl0.3_ap_isolate=0
wl0_ap_isolate=1
wl1.1_ap_isolate=0
wl1.2_ap_isolate=0
wl1.3_ap_isolate=0
wl1_ap_isolate=0
wl2.1_ap_isolate=0
wl2.2_ap_isolate=0
wl2.3_ap_isolate=0
wl_ap_isolate=1
Personally I'm wondering if the nvrams are null/empty prior to YazFi
OK so it's good another device can connect (and presumably internet etc works fine). Which version of YazFi are you running?
What error does the TV display when trying to join?
Do you have DNSFilter set in the normal LAN? If not, I wonder if the Panasonic doesn't like its DNS being force re-routed. You could test by setting FORCEDNS to false.
Another thing to try would be "forgetting" the network on the TV and re-entering details.
Hi Jack
The error while trying to connect is a never ending circle rather than a blue tick signifying a successful connection. "A home network is available but connection to the internet is not possible. The gateway dosent respond."No I have no DNS filter . Forcedns makes no difference. The panasonic TV provides you with all Network SSIDs when connecting - you choose the one to connect to - there is no option to forget it. I did re-enter parameters manually - no difference
Hi Jack
For the sake of testing, you can try to reset your TV back to factory defaults. :)
That will 'forget' the network properly.
Jack
I have narrowed it down by looking at connections. When I connect to my 5.1 network on 192.168.2.240 - I see port 53 ( DNS ESTABLISHED on address 192.168.2.240 - router) . Connectivity to network is fine. When I connect to 5.1 Guest and Gateway is 192.168.4.240 IP address- 192.168.4.75 in connections I see Port 53 - ASSURED address 192.168.2.240 ( router ) BUT NOT ESTABLISHED. So its a DNS issue as to why its not connecting to internet.
###### 5 GHz Networks ######
###### Guest Network 1 (wl1.1) #####
wl11_ENABLED=true
wl11_IPADDR=192.168.4.0
wl11_DHCPSTART=2
wl11_DHCPEND=254
wl11_DNS1=192.168.2.240
wl11_DNS2=192.168.2.240
wl11_FORCEDNS=true
wl11_REDIRECTALLTOVPN=false
wl11_VPNCLIENTNUMBER=1
wl11_LANACCESS=false
wl11_CLIENTISOLATION=false
Jack
wl11_ENABLED=true
wl11_DHCPSTART=2
wl11_DHCPEND=254
wl11_FORCEDNS=true
Can you send me the diagnostics from YazFi please in a PM? Option d in the menu
Generating YazFi diagnostics...
YazFi: Diagnostics saved to /tmp/YazFi.tar.gz.enc with passphrase 7dcmgjtkyis5qgxmjy2n7wbs5ebzwaoq
just rename file back to original
BTW Sorry misled you- After refreshing connections I do indeed get Port 53 with ESTABLISHED status. So its not that at all,
I wonder if the TV is trying to access something else which is blocked by YazFi but not the normal network. Can you run the below 2 commands on the router and then monitor syslog while you attempt to connect the TV to the YazFi network please? These will log all traffic coming from the TV
iptables -I FORWARD -s 192.168.4.75 -j LOG
iptables -I INPUT -s 192.168.4.75 -j LOG
23 20:03:27 kernel: IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=68 TOS=0x00 PREC=0x00 TTL=64 ID=31863 PROTO=UDP SPT=39223 DPT=53 LEN=48
Feb 23 20:03:27 kernel: IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=68 TOS=0x00 PREC=0x00 TTL=64 ID=31864 PROTO=UDP SPT=43604 DPT=53 LEN=48
Feb 23 20:03:27 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=168.63.205.102 LEN=87 TOS=0x00 PREC=0x00 TTL=63 ID=31865 DF PROTO=TCP SPT=54670 DPT=8443 WINDOW=1026 RES=0x00 ACK PSH URGP=0
Feb 23 20:03:27 kernel: IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=94 TOS=0x00 PREC=0x00 TTL=64 ID=31866 DF PROTO=TCP SPT=14097 DPT=53 WINDOW=1040 RES=0x00 ACK PSH URGP=0
Feb 23 20:03:27 kernel: IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=94 TOS=0x00 PREC=0x00 TTL=64 ID=31867 DF PROTO=TCP SPT=15821 DPT=53 WINDOW=1040 RES=0x00 ACK PSH URGP=0
Feb 23 20:03:28 kernel: IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=31868 DF PROTO=TCP SPT=14097 DPT=53 WINDOW=1040 RES=0x00 ACK URGP=0
Feb 23 20:03:28 kernel: IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=31869 DF PROTO=TCP SPT=15821 DPT=53 WINDOW=1040 RES=0x00 ACK URGP=0
Feb 23 20:03:28 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=31870 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:03:28 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=31871 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:03:28 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=31872 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:03:28 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=31873 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:03:28 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=31874 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:03:29 kernel: IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=31875 PROTO=UDP SPT=39223 DPT=53 LEN=44
Feb 23 20:03:29 kernel: IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=31876 PROTO=UDP SPT=43604 DPT=53 LEN=44
OK so I see DNS traffic, and your diagnostics look good on that. I need to see what this is for though...
EDIT: it's for netbios
This is with my standard 5.1 Ghz network connected- IP address of TV is 192.168.2.82 - and connection to Internet is OK
Feb 23 20:21:47 kernel: IN=br0 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=192.168.2.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=36408 PROTO=UDP SPT=29110 DPT=137 LEN=58 MARK=0x8093005e
Feb 23 20:21:48 kernel: IN=br0 OUT= MAC=d0:17:c2:ec:06:80:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=192.168.2.240 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=36409 DF PROTO=TCP SPT=21247 DPT=8200 WINDOW=65535 RES=0x00 SYN URGP=0
Feb 23 20:21:48 kernel: IN=br0 OUT= MAC=d0:17:c2:ec:06:80:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=192.168.2.240 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=36411 DF PROTO=TCP SPT=21247 DPT=8200 WINDOW=1040 RES=0x00 ACK URGP=0
Feb 23 20:21:48 kernel: IN=br0 OUT= MAC=d0:17:c2:ec:06:80:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=192.168.2.240 LEN=383 TOS=0x00 PREC=0x00 TTL=64 ID=36412 DF PROTO=TCP SPT=21247 DPT=8200 WINDOW=1040 RES=0x00 ACK PSH URGP=0
Feb 23 20:21:48 kernel: IN=br0 OUT= MAC=d0:17:c2:ec:06:80:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=192.168.2.240 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=36418 DF PROTO=TCP SPT=21247 DPT=8200 WINDOW=1003 RES=0x00 ACK URGP=0
Feb 23 20:21:48 kernel: IN=br0 OUT= MAC=d0:17:c2:ec:06:80:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=192.168.2.240 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=36419 DF PROTO=TCP SPT=21247 DPT=8200 WINDOW=1040 RES=0x00 ACK URGP=0
Feb 23 20:21:48 kernel: IN=br0 OUT= MAC=d0:17:c2:ec:06:80:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=192.168.2.240 LEN=52 TOS=0x00 PREC=0x00 TTL=64 ID=36420 DF PROTO=TCP SPT=21247 DPT=8200 WINDOW=1040 RES=0x00 ACK FIN URGP=0
Feb 23 20:21:48 kernel: IN=br0 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=192.168.2.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=36421 PROTO=UDP SPT=29110 DPT=137 LEN=58 MARK=0x44180003
no - the quick fix did not work
More of the log - when connected to 5.1Guest network - and connection to internet unsuccessful
Feb 23 20:27:53 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38215 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:53 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38216 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:53 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38217 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:53 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38218 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:53 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38219 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:53 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=241 TOS=0x00 PREC=0x00 TTL=64 ID=38220 PROTO=UDP SPT=138 DPT=138 LEN=221
Feb 23 20:27:53 kernel: IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=38221 PROTO=UDP SPT=23433 DPT=53 LEN=45
Feb 23 20:27:53 kernel: IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=65 TOS=0x00 PREC=0x00 TTL=64 ID=38222 PROTO=UDP SPT=60590 DPT=53 LEN=45
Feb 23 20:27:55 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38223 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:55 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38224 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:55 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38225 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:55 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38226 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:55 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38227 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:55 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38228 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:55 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38229 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:55 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38230 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:55 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38231 PROTO=UDP SPT=137 DPT=137 LEN=76
Feb 23 20:27:55 kernel: IN=wl1.1 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=38232 PROTO=UDP SPT=137 DPT=137 LEN=76
OK, try just the INPUT rule:
iptables -D FORWARD -s 192.168.4.75 -j LOG
We can ignore forwarding since YazFi doesn't restrict traffic out to the wider world, only to the router itself and your LAN.
It looks like it's still struggling to talk with NetBIOS - note don't re-apply YazFi settings after running the quick fix. New quick fix:
iptables -D YazFiINPUT -i wl1.1 -p udp --dport 137 -j ACCEPT
iptables -I YazFiINPUT -i wl1.1 -m multiport -p udp --dports 137,138 -j ACCEPT
After you run the quick fix, can you send the output of
iptables -S YazFiINPUT
These entries below ( when connected to standard 5.1 Ghz Network ) and successfully connected to neywork - NEVER APPEAR when connected to 5.1Guest Network for address 192.168.4.75 . Notice the MAC= 01:00:5e:7f:ff:fa The Mac address of the TV is bc:30:7e:04:00:bb
Feb 23 20:40:54 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=40227 PROTO=2
A quick search reveals this may also related to multicast traffic and/or NetBIOS. Allowing the ports 137 and 138 are the first steps (covered by the last quick fix)
I'll research what can be done for multicast
joescian@RT-AC5300:/tmp/home/root# iptables -S YazFiINPUT
-N YazFiINPUT
-A YazFiINPUT -i wl1.1 -p udp -m multiport --dports 137,138 -j ACCEPT
-A YazFiINPUT -i wl1.1 -p udp -m udp --dport 53 -j ACCEPT
-A YazFiINPUT -i wl1.1 -p tcp -m tcp --dport 53 -j ACCEPT
-A YazFiINPUT -d 192.168.2.3/32 -i wl1.1 -p tcp -m multiport --dports 80,443 -j ACCEPT
-A YazFiINPUT -i wl1.1 -p udp -m multiport --dports 67,123 -j ACCEPT
-A YazFiINPUT -i wl1.1 -j YazFiREJECT
-A YazFiINPUT -i wl0.1 -p udp -m udp --dport 53 -j ACCEPT
-A YazFiINPUT -i wl0.1 -p tcp -m tcp --dport 53 -j ACCEPT
-A YazFiINPUT -d 192.168.2.3/32 -i wl0.1 -p tcp -m multiport --dports 80,443 -j ACCEPT
-A YazFiINPUT -i wl0.1 -p udp -m multiport --dports 67,123 -j ACCEPT
-A YazFiINPUT -i wl0.1 -j YazFiREJECT
still not connecting to the network jack
Jack- when I run 1st rule I get
joescian@RT-AC5300:/tmp/home/root# iptables -D YazFiINPUT -i wl1.1 -p udp --dpor
t 137 -j ACCEPT
iptables: Bad rule (does a matching rule exist in that chain?).
t 137 -j ACCEPT
Looks like a line break has crept in. Anyway, your YazFiINPUT looks OK for now. I can't test this since I don't have a device affected, but can you try
iptables -I YazFiINPUT -i wl1.1 -d 239.255.255.250 -j ACCEPT
I might need to add a config option to allow multicast if this turns out to be the problem
