YazFi YazFi - enhanced AsusWRT-Merlin Guest WiFi inc. SSID <-> VPN Client
Feb 23 21:21:36 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=43305 DF PROTO=TCP SPT=40167 DPT=443 WINDOW=1017 RES=0x00 ACK URGP=0
Feb 23 21:21:36 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=250 TOS=0x00 PREC=0x00 TTL=63 ID=43306 DF PROTO=TCP SPT=40167 DPT=443 WINDOW=1026 RES=0x00 ACK PSH URGP=0
Feb 23 21:21:36 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=782 TOS=0x00 PREC=0x00 TTL=63 ID=43307 DF PROTO=TCP SPT=40167 DPT=443 WINDOW=1026 RES=0x00 ACK PSH URGP=0
Feb 23 21:21:36 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=43308 DF PROTO=TCP SPT=40167 DPT=443 WINDOW=1004 RES=0x00 ACK URGP=0
Feb 23 21:21:36 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=43309 DF PROTO=TCP SPT=40167 DPT=443 WINDOW=1004 RES=0x00 ACK URGP=0
Feb 23 21:21:36 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=43310 DF PROTO=TCP SPT=40167 DPT=443 WINDOW=1004 RES=0x00 ACK URGP=0
Feb 23 21:21:36 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=43311 DF PROTO=TCP SPT=40167 DPT=443 WINDOW=1004 RES=0x00 ACK URGP=0
Feb 23 21:21:36 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=43312 DF PROTO=TCP SPT=40167 DPT=443 WINDOW=1013 RES=0x00 ACK URGP=0
Feb 23 21:21:36 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=43313 DF PROTO=TCP SPT=40167 DPT=443 WINDOW=1025 RES=0x00 ACK URGP=0
Feb 23 21:21:36 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=89 TOS=0x00 PREC=0x00 TTL=63 ID=43314 DF PROTO=TCP SPT=40167 DPT=443 WINDOW=1025 RES=0x00 ACK PSH URGP=0
Feb 23 21:21:36 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=43315 DF PROTO=TCP SPT=40167 DPT=443 WINDOW=1026 RES=0x00 ACK FIN URGP=0
Feb 23 21:21:36 kernel: IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=77 TOS=0x00 PREC=0x00 TTL=64 ID=43316 PROTO=UDP SPT=49020 DPT=53 LEN=57
Feb 23 21:21:36 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=60 TOS=0x00 PREC=0x00 TTL=63 ID=43317 DF PROTO=TCP SPT=57672 DPT=443 WINDOW=65535 RES=0x00 SYN URGP=0
Feb 23 21:21:37 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=43318 DF PROTO=TCP SPT=57672 DPT=443 WINDOW=1026 RES=0x00 ACK URGP=0
Feb 23 21:21:37 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=182 TOS=0x00 PREC=0x00 TTL=63 ID=43319 DF PROTO=TCP SPT=57672 DPT=443 WINDOW=1026 RES=0x00 ACK PSH URGP=0
Feb 23 21:21:37 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=43320 DF PROTO=TCP SPT=57672 DPT=443 WINDOW=1017 RES=0x00 ACK URGP=0
Feb 23 21:21:37 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=250 TOS=0x00 PREC=0x00 TTL=63 ID=43321 DF PROTO=TCP SPT=57672 DPT=443 WINDOW=1026 RES=0x00 ACK PSH URGP=0
Feb 23 21:21:37 kernel: IN=wl1.1 OUT=ppp0 SRC=192.168.4.75 DST=198.107.139.139 LEN=782 TOS=0x00 PREC=0x00 TTL=63 ID=43322 DF PROTO=TCP SPT=57672 DPT=443 WINDOW=1026 RES=0x00 ACK PSH URGP=0
Feb 23 21:21:37 kernel: IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=43323 PROTO=ICMP TYPE=8 CODE=0 ID=24348 SEQ=0
no still not connecting to network after
iptables -I YazFiINPUT -i wl1.1 -d 239.255.255.250 -j ACCEPT
This rule will enable all multicast from the guest interface to the router:
iptables -I YazFiINPUT -i wl1.1 -d 224.0.0.0/4 -j ACCEPT
If this doesn't work, remove the previous rules by running
service restart_firewall
then run
iptables -I YazFiINPUT -i wl1.1 -m multiport -p udp --dports 137,138 -j ACCEPT
iptables -I YazFiREJECT -j LOG --log-prefix "REJECT " --log-tcp-sequence --log-tcp-options --log-ip-options
This will show what specific things are still being rejected by YazFi after whitelisting NetBIOS and multicast
successful connection to internt using 5.1Ghz Network
eb 23 21:28:07 kernel: IN=br0 OUT= MAC=d0:17:c2:ec:06:80:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=192.168.2.240 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=44033 PROTO=UDP SPT=44695 DPT=53 LEN=44
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=d0:17:c2:ec:06:80:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=192.168.2.240 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=44033 PROTO=UDP SPT=44695 DPT=53 LEN=44
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=190 TOS=0x00 PREC=0x00 TTL=4 ID=44034 PROTO=UDP SPT=22394 DPT=1900 LEN=170
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=233 TOS=0x00 PREC=0x00 TTL=4 ID=44035 PROTO=UDP SPT=22394 DPT=1900 LEN=213
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=181 TOS=0x00 PREC=0x00 TTL=4 ID=44036 PROTO=UDP SPT=22394 DPT=1900 LEN=161
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=245 TOS=0x00 PREC=0x00 TTL=4 ID=44037 PROTO=UDP SPT=22394 DPT=1900 LEN=225
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=247 TOS=0x00 PREC=0x00 TTL=4 ID=44038 PROTO=UDP SPT=22394 DPT=1900 LEN=227
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=243 TOS=0x00 PREC=0x00 TTL=4 ID=44039 PROTO=UDP SPT=22394 DPT=1900 LEN=223
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=190 TOS=0x00 PREC=0x00 TTL=4 ID=44040 PROTO=UDP SPT=17358 DPT=1900 LEN=170
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=237 TOS=0x00 PREC=0x00 TTL=4 ID=44041 PROTO=UDP SPT=17358 DPT=1900 LEN=217
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=181 TOS=0x00 PREC=0x00 TTL=4 ID=44042 PROTO=UDP SPT=17358 DPT=1900 LEN=161
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=245 TOS=0x00 PREC=0x00 TTL=4 ID=44043 PROTO=UDP SPT=17358 DPT=1900 LEN=225
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=247 TOS=0x00 PREC=0x00 TTL=4 ID=44044 PROTO=UDP SPT=17358 DPT=1900 LEN=227
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=235 TOS=0x00 PREC=0x00 TTL=4 ID=44045 PROTO=UDP SPT=17358 DPT=1900 LEN=215
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=ff:ff:ff:ff:ff:ff:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=192.168.2.255 LEN=78 TOS=0x00 PREC=0x00 TTL=64 ID=44047 PROTO=UDP SPT=19784 DPT=137 LEN=58
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=190 TOS=0x00 PREC=0x00 TTL=4 ID=44048 PROTO=UDP SPT=51840 DPT=1900 LEN=170
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=243 TOS=0x00 PREC=0x00 TTL=4 ID=44049 PROTO=UDP SPT=51840 DPT=1900 LEN=223
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=181 TOS=0x00 PREC=0x00 TTL=4 ID=44050 PROTO=UDP SPT=51840 DPT=1900 LEN=161
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=241 TOS=0x00 PREC=0x00 TTL=4 ID=44051 PROTO=UDP SPT=51840 DPT=1900 LEN=221
Feb 23 21:28:07 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=229 TOS=0x00 PREC=0x00 TTL=4 ID=44052 PROTO=UDP SPT=51840 DPT=1900 LEN=209 MARK=0x80400000
Feb 23 21:28:08 kernel: IN=br0 OUT= MAC=d0:17:c2:ec:06:80:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=192.168.2.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=44046 PROTO=ICMP TYPE=8 CODE=0 ID=45084 SEQ=0
Feb 23 21:28:08 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=190 TOS=0x00 PREC=0x00 TTL=4 ID=44054 PROTO=UDP SPT=47121 DPT=1900 LEN=170
Feb 23 21:28:08 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=241 TOS=0x00 PREC=0x00 TTL=4 ID=44055 PROTO=UDP SPT=47121 DPT=1900 LEN=221
Feb 23 21:28:08 kernel: IN=br0 OUT= MAC=01:00:5e:7f:ff:fa:bc:30:7e:04:00:bb:08:00 SRC=192.168.2.82 DST=239.255.255.250 LEN=181 TOS=0x00 PREC=0x00 TTL=4 ID=44056 PROTO=UDP SPT=47121 DPT=1900 LEN=161
Feb 23 21:42:14 kernel: REJECT IN=wl1.1 OUT= MAC= SRC=192.168.4.240 DST=255.255.255.255 LEN=339 TOS=0x00 PREC=0x00 TTL=64 ID=41781 PROTO=UDP SPT=67 DPT=68 LEN=319
Feb 23 21:42:14 kernel: REJECT IN=wl1.1 OUT= MAC= SRC=192.168.4.240 DST=255.255.255.255 LEN=339 TOS=0x00 PREC=0x00 TTL=64 ID=41782 PROTO=UDP SPT=67 DPT=68 LEN=319
Feb 23 21:42:14 kernel: REJECT IN=wl1.1 OUT= MAC= SRC=192.168.4.240 DST=255.255.255.255 LEN=339 TOS=0x00 PREC=0x00 TTL=64 ID=41783 PROTO=UDP SPT=67 DPT=68 LEN=319
Feb 23 21:42:15 kernel: REJECT IN=wl1.1 OUT= MAC= SRC=192.168.4.240 DST=255.255.255.255 LEN=339 TOS=0x00 PREC=0x00 TTL=64 ID=41784 PROTO=UDP SPT=67 DPT=68 LEN=319
Feb 23 21:42:15 kernel: REJECT IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=46924 PROTO=ICMP TYPE=8 CODE=0 ID=30749 SEQ=0
Feb 23 21:42:19 kernel: REJECT IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=46986 DF PROTO=TCP SPT=57778 DPT=8200 SEQ=2944412152 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B4010303060402080A0292A0D500000000)
Feb 23 21:42:24 kernel: REJECT IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=46992 DF PROTO=TCP SPT=25344 DPT=8200 SEQ=739922280 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B4010303060402080A0292B5F700000000)
Feb 23 21:42:25 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=d0:17:c2:ec:06:80:50:1a:c5:f6:9a:85:08:00 SRC=192.168.2.119 DST=115.70.234.99 LEN=80 TOS=0x00 PREC=0x00 TTL=128 ID=3924 PROTO=UDP SPT=61179 DPT=57393 LEN=60
Feb 23 21:42:26 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=115.70.234.99 DST=220.233.24.148 LEN=80 TOS=0x00 PREC=0x00 TTL=124 ID=6895 PROTO=UDP SPT=57393 DPT=61179 LEN=60
Feb 23 21:42:26 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=d0:17:c2:ec:06:80:50:1a:c5:f6:9a:85:08:00 SRC=192.168.2.119 DST=115.70.234.99 LEN=80 TOS=0x00 PREC=0x00 TTL=128 ID=3925 PROTO=UDP SPT=61179 DPT=57393 LEN=60
Feb 23 21:42:27 kernel: REJECT IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=46999 PROTO=ICMP TYPE=8 CODE=0 ID=32541 SEQ=0
Feb 23 21:42:37 kernel: REJECT IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=47032 DF PROTO=TCP SPT=62454 DPT=8200 SEQ=3765903964 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B4010303060402080A0292E82E00000000)
Feb 23 21:42:37 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=d0:17:c2:ec:06:80:50:1a:c5:f6:9a:85:08:00 SRC=192.168.2.119 DST=115.70.234.99 LEN=80 TOS=0x00 PREC=0x00 TTL=128 ID=3931 PROTO=UDP SPT=61179 DPT=57393 LEN=60 MARK=0x848d00be
Feb 23 21:42:38 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=115.70.234.99 DST=220.233.24.148 LEN=80 TOS=0x00 PREC=0x00 TTL=124 ID=6904 PROTO=UDP SPT=57393 DPT=61179 LEN=60 MARK=0x848d00be
Feb 23 21:42:38 kernel: REJECT IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=47034 PROTO=ICMP TYPE=8 CODE=0 ID=33565 SEQ=0
Feb 23 21:42:49 kernel: REJECT IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=47087 PROTO=ICMP TYPE=8 CODE=0 ID=34333 SEQ=0
Feb 23 21:42:49 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=d0:17:c2:ec:06:80:50:1a:c5:f6:9a:85:08:00 SRC=192.168.2.119 DST=115.70.234.99 LEN=80 TOS=0x00 PREC=0x00 TTL=128 ID=3938 PROTO=UDP SPT=61179 DPT=57393 LEN=60
Feb 23 21:42:50 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=115.70.234.99 DST=220.233.24.148 LEN=80 TOS=0x00 PREC=0x00 TTL=124 ID=6913 PROTO=UDP SPT=57393 DPT=61179 LEN=60
Feb 23 21:42:50 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=d0:17:c2:ec:06:80:50:1a:c5:f6:9a:85:08:00 SRC=192.168.2.119 DST=115.70.234.99 LEN=80 TOS=0x00 PREC=0x00 TTL=128 ID=3939 PROTO=UDP SPT=61179 DPT=57393 LEN=60 MARK=0x80400000
Feb 23 21:42:50 kernel: REJECT IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=47088 DF PROTO=TCP SPT=24885 DPT=8200 SEQ=1116059871 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B4010303060402080A0293199D00000000)
Feb 23 21:42:59 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:18:74:2e:9a:d2:bd:08:00 SRC=192.168.3.186 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=47706 DF PROTO=ICMP TYPE=8 CODE=0 ID=37380 SEQ=40706
Feb 23 21:43:00 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:6c:56:97:dc:67:ea:08:00 SRC=192.168.3.192 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=21454 DF PROTO=ICMP TYPE=8 CODE=0 ID=26372 SEQ=40706
Feb 23 21:43:00 kernel: REJECT IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.4.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=47098 PROTO=ICMP TYPE=8 CODE=0 ID=35357 SEQ=0
Feb 23 21:43:00 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=d0:17:c2:ec:06:80:50:1a:c5:f6:9a:85:08:00 SRC=192.168.2.119 DST=115.70.234.99 LEN=80 TOS=0x00 PREC=0x00 TTL=128 ID=3944 PROTO=UDP SPT=61179 DPT=57393 LEN=60
Feb 23 21:43:00 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:18:74:2e:9a:d2:bd:08:00 SRC=192.168.3.186 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=47734 DF PROTO=ICMP TYPE=8 CODE=0 ID=37380 SEQ=33326
Feb 23 21:43:01 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:6c:56:97:dc:67:ea:08:00 SRC=192.168.3.192 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=21497 DF PROTO=ICMP TYPE=8 CODE=0 ID=26372 SEQ=33326
Feb 23 21:43:01 kernel: REJECT IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:54:60:09:7c:93:9e:08:00 SRC=192.168.4.214 DST=192.168.4.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=ICMP TYPE=8 CODE=0 ID=2795 SEQ=1
Feb 23 21:43:01 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:18:74:2e:9a:d2:bd:08:00 SRC=192.168.3.186 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=47765 DF PROTO=ICMP TYPE=8 CODE=0 ID=37380 SEQ=29495
Feb 23 21:43:02 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:fc:a1:83:ae:45:99:08:00 SRC=192.168.3.175 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=36232 DF PROTO=ICMP TYPE=8 CODE=0 ID=551 SEQ=19999
Feb 23 21:43:02 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:18:74:2e:9a:d2:bd:08:00 SRC=192.168.3.186 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=47863 DF PROTO=ICMP TYPE=8 CODE=0 ID=37380 SEQ=8014
Feb 23 21:43:03 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:6c:56:97:dc:67:ea:08:00 SRC=192.168.3.192 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=21553 DF PROTO=ICMP TYPE=8 CODE=0 ID=26372 SEQ=8014
Feb 23 21:43:03 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:fc:a1:83:ae:45:99:08:00 SRC=192.168.3.175 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=36242 DF PROTO=ICMP TYPE=8 CODE=0 ID=551 SEQ=32686
Feb 23 21:43:03 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:18:74:2e:9a:d2:bd:08:00 SRC=192.168.3.186 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=47867 DF PROTO=ICMP TYPE=8 CODE=0 ID=37380 SEQ=44671
Feb 23 21:43:04 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:6c:56:97:dc:67:ea:08:00 SRC=192.168.3.192 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=21603 DF PROTO=ICMP TYPE=8 CODE=0 ID=26372 SEQ=44671
Feb 23 21:43:04 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:fc:a1:83:ae:45:99:08:00 SRC=192.168.3.175 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=36249 DF PROTO=ICMP TYPE=8 CODE=0 ID=551 SEQ=43076
Feb 23 21:43:04 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:18:74:2e:9a:d2:bd:08:00 SRC=192.168.3.186 DST=192.168.2.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=5538 DF PROTO=ICMP TYPE=8 CODE=0 ID=37380 SEQ=17576
Feb 23 21:43:05 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:fc:a1:83:ae:45:99:08:00 SRC=192.168.3.175 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=36257 DF PROTO=ICMP TYPE=8 CODE=0 ID=551 SEQ=4126
Feb 23 21:43:05 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:18:74:2e:9a:d2:bd:08:00 SRC=192.168.3.186 DST=192.168.2.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=5580 DF PROTO=ICMP TYPE=8 CODE=0 ID=37380 SEQ=7696
Feb 23 21:43:06 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:6c:56:97:dc:67:ea:08:00 SRC=192.168.3.192 DST=192.168.2.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=50446 DF PROTO=ICMP TYPE=8 CODE=0 ID=26372 SEQ=7696
Feb 23 21:43:06 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:fc:a1:83:ae:45:99:08:00 SRC=192.168.3.175 DST=192.168.3.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=36297 DF PROTO=ICMP TYPE=8 CODE=0 ID=551 SEQ=26310
Feb 23 21:43:06 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:18:74:2e:9a:d2:bd:08:00 SRC=192.168.3.186 DST=192.168.2.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=5614 DF PROTO=ICMP TYPE=8 CODE=0 ID=37380 SEQ=50790
Feb 23 21:43:07 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:6c:56:97:dc:67:ea:08:00 SRC=192.168.3.192 DST=192.168.2.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=50514 DF PROTO=ICMP TYPE=8 CODE=0 ID=26372 SEQ=50790
Feb 23 21:43:07 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:fc:a1:83:ae:45:99:08:00 SRC=192.168.3.175 DST=192.168.2.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=10319 DF PROTO=ICMP TYPE=8 CODE=0 ID=551 SEQ=20766
Feb 23 21:43:07 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:18:74:2e:9a:d2:bd:08:00 SRC=192.168.3.186 DST=192.168.2.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=5640 DF PROTO=ICMP TYPE=8 CODE=0 ID=37380 SEQ=7761
Feb 23 21:43:08 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:6c:56:97:dc:67:ea:08:00 SRC=192.168.3.192 DST=192.168.2.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=50525 DF PROTO=ICMP TYPE=8 CODE=0 ID=26372 SEQ=7761
Feb 23 21:43:08 kernel: REJECT IN=wl0.1 OUT= MAC=d0:17:c2:ec:06:81:fc:a1:83:ae:45:99:08:00 SRC=192.168.3.175 DST=192.168.2.240 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=10327 DF PROTO=ICMP TYPE=8 CODE=0 ID=551 SEQ=36109
Feb 23 21:43:08 kernel: REJECT IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=47100 DF PROTO=TCP SPT=26908 DPT=8200 SEQ=4125990768 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B4010303060402080A0293613D00000000)
OK so it looks the the TV might also be trying to act as a DHCP server (assuming my understanding of DHCP ports is correct), and trying to ping the router
thinking about it, the ping is probably the main thing that is upsetting the TV
this seems to be dominant entry for 192.168.4.75
eb 23 21:45:29 kernel: REJECT IN=wl1.1 OUT= MAC=d0:17:c2:ec:06:85:bc:30:7e:04:00:bb:08:00 SRC=192.168.4.75 DST=192.168.2.240 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=47197 DF PROTO=TCP SPT=51482 DPT=8200 SEQ=4269585828 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B4010303060402080A0295864E00000000)
8200 is DLNA I think - is that enabled on your router? Can be ignored if so
@joe scian I'll kick myself if this solves it
iptables -I YazFiINPUT -i wl1.1 -p ICMP -j ACCEPT
Hey Jack,
Installed latest today on a clean install of 384.9 & AMTM on my 5300.
I knew it would likely fail as I have wifi disabled on this merlin router * see sig for why. ** Not my testing router.
Anyway install starts and then aborts with the " System requirements not met see above for why" message. At least thats what I think it says. :confused: It goes by way too fast.
Yet the script kicks me out 2 seconds after the warning comes up and back to the amtm prompt. I would think it would default to a set time 10 or 15 seconds or wait for user input, so they can read the reasons.
Then after kicking me out to the amtm screen it shows as YazFi installed. Yet the install option still shows as red. :(
Hey Jack,
Ah - it works fine on a manual install, but with amtm when YazFi exits, it drops back to the amtm menu and you can no longer see the printed output showing the failures. An easy fix (in theory!)
Maybe... Add a line below the installed comment with the location to a log file with any errors ?
Hi Jack!
Just tried to create an IOT guest network for my chinese cam.. ;) My configuration looks like that:
wl01_ENABLED=true
wl01_IPADDR=192.168.2.0
wl01_DHCPSTART=2
wl01_DHCPEND=254
wl01_DNS1=127.0.0.1
wl01_DNS2=127.0.0.1
wl01_FORCEDNS=true
wl01_REDIRECTALLTOVPN=false
wl01_VPNCLIENTNUMBER=2
wl01_LANACCESS=false
wl01_CLIENTISOLATION=true
I want that the clients in this network are also using my router with stuby to do dns things.
I can see that my cam is connected to that network:
INTERFACE: wl0.1
SSID: MB-WLAN_IOT
HOSTNAME IP ADDRESS MAC
? 192.168.2.110 XXX
But without hostname..?
Also I can't connect anymore to that cam if I am at my normal WLAN network or from the outside :(
Any hints?
Is this still an issue?
OK Jack - you need to kick yourself - thanks so much - it works now !!!!!
Of course rejecting ports 67,68 means it cannot get a response from DHCP server?
As a quick sanity check - is this with or without the other rules we tried? i.e. if you run service restart_firewall and then run only the icmp rule, does it work?
To all - what's the general consensus on allowing guests to ping the router?
Yes it does
YES it does work with only ICMP enabled
It looks like the Panasonic TV is trying to run some sort of server itself - YazFi allows the relevant port (67 inbound, router outbound is unrestricted) on the router so DHCP is successful
Jack
The other issue (prob connected with Dport 8200) is that the Panasonic TV does not connect via DLNA using 5.1 Guest. Sometimes I use DLNA server ( inbuilt into TV ) to connect to my Iphone to view TV channels or movies on iphone. Also sometimes I use DLNA to cast movies to TV - as an alternative to using Chromecast.
I tried issuing this command
iptables -I YazFiINPUT -i wl1.1 -p tcp --dport 8200 -j ACCEPT
but still not working
