[384.10_Alpha - builds] Testing all variants.
Been running 384.10_alpha2-gb9d6669b27 on my RT-AC3200 for a little over 26 hours now without any problems.
I had been having some issues with 384.9, mainly the router becoming unresponsive from time to time. When I saw that the 384.10 aplha was capping the tracked connections, I decided to give it a shot (just in case that was the cause).
That change strictly affect the Classification webpage, it doesn't change anything at the router level.
Ok, interesting. Thanks for settling that. I wondered if that might have been doing something in the background that was causing the router to hang.
It's a problem I've not had previously and troubleshooting to this point wasn't helping. No clues in the syslog either. If it can make it through the weekend without needing a reboot, it will be an improvement.
Tested a while and works just fine.
Uptime 3 days 10 hours 20 minute(s) 51 seconds )uptime is longer, have rebooted several times(
Thanks !
Get this in log sometimes in this alpha, Don`t look like a error but share it anyway ;)
Mar  6 19:35:04 kernel: EN=444 TOS=0x00 PREC=0x00 TTL=128 ID=53890 PROTO=UDP SPT=52072 DPT=27021 LEN=424 MARK=0xa
Mar  6 19:35:18 kernel: =0x00 PREC=0x00 TTL=128 ID=55433 PROTO=UDP SPT=52430 DPT=27024 LEN=424 MARK=0xa
Mar  6 19:44:34 kernel: 2 PROTO=UDP SPT=58590 DPT=27024 LEN=424 MARK=0xa
Mar  6 19:49:51 kernel: 25.136 LEN=444 TOS=0x00 PREC=0x00 TTL=128 ID=632 PROTO=UDP SPT=64891 DPT=27026 LEN=424 MARK=0xa
Mar  6 19:50:41 kernel: SPT=59876 DPT=27020 LEN=424 MARK=0xa
Mar  7 19:29:37 kernel: TTL=128 ID=1711 PROTO=UDP SPT=65354 DPT=27032 LEN=424 MARK=0xa
Mar  7 19:30:35 kernel: 0x00 TTL=128 ID=45833 PROTO=UDP SPT=62023 DPT=27036 LEN=424 MARK=0xa
edit:
Could it be related to country blocks in skynet? (only change i made except alpha firmware)
AC86U dual wan wonky or just flat out not working.
When the primary cable goes down and it can't ping out it should fall over tothe backup dsl but it never does even though it aware the cable has disconnected.
Unless you actually unplug the line from the modem it wont fall over but the minute you do unplug the line it falls over just as it should.
edit:
It looks like snippets of ordinary Skynet syslog entries. This has never happened to me. The entries are always complete.
Ok strange.. Testing to remove country blocks again and see if the entries disappear
edit:
Have not happened again after removal of country blocks (cn il kr) in Skynet
