Mar 3 22:30:44 dnsmasq[3679]: bad option at line 12 of /etc/dnsmasq.conf
Mar 3 22:30:44 dnsmasq[3679]: FAILED to start up
Why don't you also post /etc/dnsmasq.conf? Probably an easy fix with a postconf file in the short term.DONT FLASH RT-AC68U FIRWARE dnsmasq don't start up
RT-AC68U_384.10_alpha2-gb9d6669b27
https://pastebin.com/cRVCfFJb
Code:Mar 3 22:30:44 dnsmasq[3679]: bad option at line 12 of /etc/dnsmasq.conf Mar 3 22:30:44 dnsmasq[3679]: FAILED to start up
@RMerlin
read pastbin fileWhy don't you also post /etc/dnsmasq.conf? Probably an easy fix with a postconf file in the short term.
EDIT: Apologies, too many tabs open to pastebin
#!/bin/sh
CONFIG=$1
source /usr/sbin/helper.sh
pc_insert "text to find" "text to insert " $CONFIG
I bet you're using a dnsmasq.postconf script which may be using pc_insert which seems broke.DONT FLASH RT-AC68U FIRWARE dnsmasq don't start up
@RMerlin
it works fine.i see a build forthe 3200 is back , is it safe , anybody give ita try yet , I'M afraid my mind is not up to my router crashing and having to rebuild from scratch . guess I'lk be waiting for fedback from the more adventurous among us giving it a shot . . Thanks Merlin fo all the work you put in maintaining this FW.
it works fine.
THANKS guess i'll give it a tryConfirmed , 384.10_alpha2-gb9d6669b27 on the RT-AC3200 loads and works very well.
Thanks Eric for your continued support for this model![]()
Are the Asus bugs still present as they were in _9?
Also in this alpha the message "No active leases" on my RT-AC86U. how did that happen?
| Thread starter | Title | Forum | Replies | Date |
| S | 102.7 Alpha Builds available | Asuswrt-Merlin | 150 | |
[ 3004_388.11 alpha Build(s) ] available build(s) | Asuswrt-Merlin | 36 | |
[ 3006.102.6 alpha Build(s) ] available build(s) | Asuswrt-Merlin | 206 | |
[ 3006.102.5 alpha Build(s) ] available build(s) | Asuswrt-Merlin | 111 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
