[384.10_Alpha - builds] Testing all variants.
i see a build forthe 3200 is back , is it safe , anybody give ita try yet , I'M afraid my mind is not up to my router crashing and having to rebuild from scratch . guess I'lk be waiting for fedback from the more adventurous among us giving it a shot . . Thanks Merlin fo all the work you put in maintaining this FW.
If you are afraid to rebuild from scratch, then an alpha build is not for you.
Just an fyi, still getting hundreds of these each day, as in 9:
Mar 5 02:25:09 dnsmasq[325]: failed to send packet: Operation not permitted
Mar 5 02:25:10 dnsmasq[325]: failed to send packet: Operation not permitted
They don't seem to make a difference in operations with the router.
RT AC-5300
If you need a had with a rebuild I can help on my day off if you want.
384.10 is based on the same GPL code as 384.9.
What's that error message? Where are you seeing it? I'll need some context...
I see the clients on the DHCP leases page. A few minutes later, the client page is empty and the message 'No active leases' appears. On the wireless log page you will find all clients with the name <not found>
The client is then connected to this router.
Firmware version 384.8_2 didn't have this problem.
Any customization to your dnsmasq settings?
What's the content of your /var/lib/misc/dnsmasq.leases file?
I haven't had any other similar report, so there must be something special with your configuration.
Thanks for the information! I do use a custom dnsmasq configuration with the name dnsmasq.conf.add on /jffs/configs with:
address=/asus.DOMAIN.com/192.168.1.1
And I use Devision (adblocker)
I have now installed 384.9 again. I report again if the problem occurs.
384.10 seems to be working well on my 3200 , just loaded and it worked , another great Merlin build , 26 hours and nothing unusual in the logs , all clients stable a few 128 gb transfers went through without a hiccup .
@RMerlin,
On the syslog, I see this:
Mar 5 16:55:58 kernel: pgd = ffffffc00a662000
Mar 5 16:55:58 kernel: [00000000] *pgd=000000000a76a003, *pud=000000000a76a003, *pmd=000000000a7bd003, *pte=0000000000000000
Mar 5 16:55:58 kernel: CPU: 1 PID: 4554 Comm: dcd Tainted: P O 4.1.27 #2
Mar 5 16:55:58 kernel: Hardware name: Broadcom-v8A (DT)
Mar 5 16:55:58 kernel: task: ffffffc01eb980c0 ti: ffffffc00a6ac000 task.ti: ffffffc00a6ac000
Mar 5 16:55:58 kernel: PC is at 0xf70c9f44
Mar 5 16:55:58 kernel: LR is at 0x1dc74
Mar 5 16:55:58 kernel: pc : [<00000000f70c9f44>] lr : [<000000000001dc74>] pstate: 600e0010
Mar 5 16:55:58 kernel: sp : 00000000ffe1c7e8
Mar 5 16:55:58 kernel: x12: 000000000009ff10
Mar 5 16:55:58 kernel: x11: 00000000f63ff024 x10: 00000000000a02b4
Mar 5 16:55:58 kernel: x9 : 00000000f63ff748 x8 : 00000000000a076c
Mar 5 16:55:58 kernel: x7 : 00000000f63ff780 x6 : 00000000000a0766
Mar 5 16:55:58 kernel: x5 : 0000000000000000 x4 : 00000000f63ff72c
Mar 5 16:55:58 kernel: x3 : 0000000000000000 x2 : 00000000ffe1c7c4
Mar 5 16:55:58 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Mar 5 17:14:01 kernel: pgd = ffffffc00adf2000
Mar 5 17:14:01 kernel: [00000000] *pgd=00000000137ba003, *pud=00000000137ba003, *pmd=000000000a4c5003, *pte=0000000000000000
Mar 5 17:14:01 kernel: CPU: 1 PID: 5513 Comm: dcd Tainted: P O 4.1.27 #2
Mar 5 17:14:01 kernel: Hardware name: Broadcom-v8A (DT)
Mar 5 17:14:01 kernel: task: ffffffc0137eab80 ti: ffffffc00a6a4000 task.ti: ffffffc00a6a4000
Mar 5 17:14:01 kernel: PC is at 0xf7015f44
Mar 5 17:14:01 kernel: LR is at 0x1dc74
Mar 5 17:14:01 kernel: pc : [<00000000f7015f44>] lr : [<000000000001dc74>] pstate: 600e0010
Mar 5 17:14:01 kernel: sp : 00000000ffe85dc8
Mar 5 17:14:01 kernel: x12: 000000000009ff10
Mar 5 17:14:01 kernel: x11: 00000000f62ff024 x10: 00000000000a02b4
Mar 5 17:14:01 kernel: x9 : 00000000f62ff748 x8 : 00000000000a076c
Mar 5 17:14:01 kernel: x7 : 00000000f62ff780 x6 : 00000000000a0766
Mar 5 17:14:01 kernel: x5 : 0000000000000000 x4 : 00000000f62ff72c
Mar 5 17:14:01 kernel: x3 : 0000000000000000 x2 : 00000000ffe85da4
Mar 5 17:14:01 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Mar 5 17:18:57 kernel: pgd = ffffffc0170ed000
Mar 5 17:18:57 kernel: [00000000] *pgd=000000000adea003, *pud=000000000adea003, *pmd=000000000adf2003, *pte=0000000000000000
Mar 5 17:18:57 kernel: CPU: 1 PID: 6321 Comm: dcd Tainted: P O 4.1.27 #2
Mar 5 17:18:57 kernel: Hardware name: Broadcom-v8A (DT)
Mar 5 17:18:57 kernel: task: ffffffc0137e8b40 ti: ffffffc00a6c8000 task.ti: ffffffc00a6c8000
Mar 5 17:18:57 kernel: PC is at 0xf722ff44
Mar 5 17:18:57 kernel: LR is at 0x1dc74
Mar 5 17:18:57 kernel: pc : [<00000000f722ff44>] lr : [<000000000001dc74>] pstate: 600e0010
Mar 5 17:18:57 kernel: sp : 00000000ffbd6de8
Mar 5 17:18:57 kernel: x12: 000000000009ff10
Mar 5 17:18:57 kernel: x11: 00000000f64ff024 x10: 00000000000a02b4
Mar 5 17:18:57 kernel: x9 : 00000000f64ff748 x8 : 00000000000a076c
Mar 5 17:18:57 kernel: x7 : 00000000f64ff780 x6 : 00000000000a0766
Mar 5 17:18:57 kernel: x5 : 0000000000000000 x4 : 00000000f64ff72c
Mar 5 17:18:57 kernel: x3 : 0000000000000000 x2 : 00000000ffbd6dc4
Mar 5 17:18:57 kernel: x1 : 000000000007c674 x0 : 0000000000000000
@RMerlin,
Known, documented (check the release notes!) issue waiting for ASUS to address it -- apparently, same issue in stock firmware as well...
RT AC-5300
Can you PM me that SOA request that seemed to be triggering it?
Without a test case allowing me to reproduce it, I have nowhere to begin looking at this issue. The error message itself is far too generic.
@RMerlin, I upgraded my AC66U_B1 about 3 days ago to 384.9 and I notice that the names associated with IP addresses don't get resolved until I go network map > clients > view list, and then wait about 5 sec for the list of connected users to load. In fact, sometimes I see 0 clients even though there are connected users. It is only after I click on view list that I see the IPs of connected devices and their associated names.
Please review the changelog for more details.
There is a number of known issues in this release that cannot be fixed at this time:
  • dcd process crashing on RT-AC86U (bug in Trend Micro's code, outside of my control).
  • IPv6s on Tracked Connections have their last two bytes set to 00 (bug in Trend Micro's code truncating the last two bytes).
  • No IPS events logged (bug in Asus's code, IPS should work, just fails to log hits)
  • Networkmap listing may be unreliable. (Bug in Asus's code)
  • Users failing to read changelogs will probably complain about the above issues. (Outside of my control).
I know that :) I just wanted to post that because it may have a connection with the empty DHCP.
@RMerlin,
Problem is back! File /var/lib/misc/dnsmasq.leases is empty. (This file was filled)
A possible explanation, I turned off my modem and on. Then he happened to be empty. Perhaps it has to do with that?
Edit: I think I found the problem! I have deleted diversion and the DHCP list is filled again.
@RMerlin,
What is the output of "sort /etc/dnsmasq.conf"?
@RMerlin,
Check your system log to see if there's any error message related to dnsmasq. Maybe something is causing the process to fail starting, so when httpd tries to signal it to dump the list of known leases, the process is no longer there to answer.
HDD spin down exceptions are back to only taking place after a reboot with latest alpha2. I believe the fix you applied on 384.9, 'USB disk idle config changes not applying without a reboot' was working in 384.9.
RT-AC68U
@EmeraldDeer,
In this file I see dhcp-host with the MAC address and IP Addresses. (that is good)
@RMerlin,
I see:
Mar 6 09:51:26 rc_service: service 12410:notify_rc restart_dnsmasq
Mar 6 09:51:26 custom_config: Appending content of /jffs/configs/dnsmasq.conf.add.
Mar 6 09:51:26 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf ) - max timeout = 120s
Mar 6 09:51:26 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
Mar 6 09:52:55 Diversion: updated Standard blocking list from 14 (omitting -1 duplicates) hosts files, 509139 domains are now blocked, from /opt/share/diversion/file/update-bf.div
Mar 6 09:55:53 Diversion: added 'tele2-deals.com' to blacklist (user action), from /opt/bin/diversion
Mar 6 09:56:01 Diversion: added 'ca.cdn.ftl.pub' to blacklist (user action), from /opt/bin/diversion
Mar 6 09:56:09 Diversion: added 'trumbhost.com' to blacklist (user action), from /opt/bin/diversion
Mar 6 09:56:45 nat: apply redirect rules
Mar 6 09:56:45 WAN_Connection: ISP's DHCP did not function properly.
Mar 6 09:56:45 DualWAN: skip single wan wan_led_control - WANRED off
The DHCP list is empty again. I did service restart_dnsmasq but that doesn't solve it. The problem is really in Diversion.
