[384.9_Alpha - builds] Testing all variants.
Thank you for reaffirming what an ALPHA (Test) firmware is, I'm well aware and just trying to help with the testing.
This isn't mission critical, but if there was something wrong or unstable with this as an upcoming build, then I figured something should be stated so it could be discussed, addressed, or avoided for others if they DO need a stable environment /run a business/ have internet of things relying on their router.
After doing an Initialization, the 5Ghz shows down on the latest Alpha even during the SSID/Smart Connect setup, so there is not a configuration issue, as nothing has been configured yet up to that point.
Rolling back to the latest 384.8_2 version of Merlin brought the 5Ghz back, so I'm strongly suggesting there's either a flashing issue or GPL issue.
After the flash and when you noticed the 5G down, did you reset to defaults so the rest of the community can accurate understand the possible issue at hand?:rolleyes:
If you have reset, I would try to reset again and not use a single import for any setting. Reconfigure the router by hand and screen shots taken before the flash.
I noticed this entry as well in my logs. After a reboot only one of those entries shows up.o_O
This message is there since 45149 was introduce in Asuswrt or Merlin fw. No reset or initialize will fix this. This is just a debug message , harmless but annoying.
Yes, I did an Factory Restore/Initialize as posted earlier, which (by my understanding) should completely wipe all configurations and set the router to it's absolute defaults. :rolleyes:
And even after that, which I power cycled after doing a Factory Restore, the 5Ghz was still not working.
If you use DFS 5Ghz channels it can take upto 1-2 minutes to get any signals.
5Ghz failed to register after an hour of up time.
Tools showed it as disabled, and the LED was off.
Wireless > Professional showed the radio was on.
Upper right tooltip for wireless info said it was on, and broadcasting on XYZ channels.
Not sure why, but rolling back to 384.8_2 brought all functionality back.
Just did a dirty flash on RT-AC3200 and all is working as expected. I am so excited that you included the 3200 again :)!!!
same problem here. My router is RT-AX88U,when I update to 384.9_alpha,5G wireless is disabled.
rollback to 384.8_2, 5G work again.
Is there something wrong with OpenVPN server or am I doing something wrong? I can’t get a connection at all :(
I have not tried the 384.9 Alpha builds yet. I will comment though that several versions ago on one of the earlier 384.x versions, my AC86U would not initialize the 2.4 GHz radio. It always remained OFF. Nothing I tried short of dropping back a version would resurrect it. Eventually when the next .x+1 version came along and I flashed the early beta firmware, the 2.4 radio worked again. So don't feel alone - your issue with the 5 GHz radio is behaving exactly like my 2.4 GHz on an earlier version.
That's 79 hours without disconnection on the 2.4 GHz band here, and 31 hours on the 5 GHz band.
Is this anything to worry about on my AC86U?
Jan 4 09:46:26 kernel: dcd[24290]: unhandled level 3 translation fault (11) at 0x00000000, esr 0x92000007
Jan 4 09:46:26 kernel: pgd = ffffffc015112000
Jan 4 09:46:26 kernel: [00000000] *pgd=0000000006c76003, *pud=0000000006c76003, *pmd=00000000067d3003, *pte=0000000000000000
Jan 4 09:46:26 kernel: CPU: 1 PID: 24290 Comm: dcd Tainted: P O 4.1.27 #2
Jan 4 09:46:26 kernel: Hardware name: Broadcom-v8A (DT)
Jan 4 09:46:26 kernel: task: ffffffc015183540 ti: ffffffc006204000 task.ti: ffffffc006204000
Jan 4 09:46:26 kernel: PC is at 0xf711bf44
Jan 4 09:46:26 kernel: LR is at 0x1dc74
Jan 4 09:46:26 kernel: pc : [<00000000f711bf44>] lr : [<000000000001dc74>] pstate: 600e0010
Jan 4 09:46:26 kernel: sp : 00000000ffd5bd88
Jan 4 09:46:26 kernel: x12: 000000000009ff10
Jan 4 09:46:26 kernel: x11: 00000000f63ff024 x10: 00000000000a02b4
Jan 4 09:46:27 kernel: x9 : 00000000f63ffb14 x8 : 00000000000a076c
Jan 4 09:46:27 kernel: x7 : 00000000f63ffb4c x6 : 00000000000a0766
Jan 4 09:46:27 kernel: x5 : 0000000000000000 x4 : 00000000f63ffaf8
Jan 4 09:46:27 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Jan 4 09:46:27 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Jan 4 09:50:17 kernel: dcd[25744]: unhandled level 3 translation fault (11) at 0x00000000, esr 0x92000007
Jan 4 09:50:17 kernel: pgd = ffffffc015116000
Jan 4 09:50:17 kernel: [00000000] *pgd=0000000015005003, *pud=0000000015005003, *pmd=0000000015210003, *pte=0000000000000000
Jan 4 09:50:17 kernel: CPU: 1 PID: 25744 Comm: dcd Tainted: P O 4.1.27 #2
Jan 4 09:50:17 kernel: Hardware name: Broadcom-v8A (DT)
Jan 4 09:50:17 kernel: task: ffffffc010e855c0 ti: ffffffc015780000 task.ti: ffffffc015780000
Jan 4 09:50:17 kernel: PC is at 0xf747df44
Jan 4 09:50:17 kernel: LR is at 0x1dc74
Jan 4 09:50:17 kernel: pc : [<00000000f747df44>] lr : [<000000000001dc74>] pstate: 600e0010
Jan 4 09:50:17 kernel: sp : 00000000ffea9f08
Jan 4 09:50:17 kernel: x12: 000000000009ff10
Jan 4 09:50:17 kernel: x11: 00000000f67ff024 x10: 00000000000a02b4
Jan 4 09:50:17 kernel: x9 : 00000000f67ffb14 x8 : 00000000000a076c
Jan 4 09:50:17 kernel: x7 : 00000000f67ffb4c x6 : 00000000000a0766
Jan 4 09:50:17 kernel: x5 : 0000000000000000 x4 : 00000000f67ffaf8
Jan 4 09:50:17 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Jan 4 09:50:17 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Jan 4 10:15:07 kernel: dcd[25990]: unhandled level 3 translation fault (11) at 0x00000000, esr 0x92000007
Jan 4 10:15:07 kernel: pgd = ffffffc0061e1000
Jan 4 10:15:07 kernel: [00000000] *pgd=0000000015350003, *pud=0000000015350003, *pmd=0000000017ad9003, *pte=0000000000000000
Jan 4 10:15:07 kernel: CPU: 1 PID: 25990 Comm: dcd Tainted: P O 4.1.27 #2
Jan 4 10:15:07 kernel: Hardware name: Broadcom-v8A (DT)
Jan 4 10:15:07 kernel: task: ffffffc0170701c0 ti: ffffffc0139d8000 task.ti: ffffffc0139d8000
Jan 4 10:15:07 kernel: PC is at 0xf7322f44
Jan 4 10:15:07 kernel: LR is at 0x1dc74
Jan 4 10:15:07 kernel: pc : [<00000000f7322f44>] lr : [<000000000001dc74>] pstate: 600e0010
Jan 4 10:15:07 kernel: sp : 00000000ffe07438
Jan 4 10:15:07 kernel: x12: 000000000009ff10
Jan 4 10:15:07 kernel: x11: 00000000f65ff024 x10: 00000000000a02b4
Jan 4 10:15:07 kernel: x9 : 00000000f65ffb14 x8 : 00000000000a076c
Jan 4 10:15:07 kernel: x7 : 00000000f65ffb4c x6 : 00000000000a0766
Jan 4 10:15:07 kernel: x5 : 0000000000000000 x4 : 00000000f65ffaf8
Jan 4 10:15:07 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Jan 4 10:15:07 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Jan 4 10:16:17 kernel: dcd[26747]: unhandled level 3 translation fault (11) at 0x00000000, esr 0x92000007
Jan 4 10:16:17 kernel: pgd = ffffffc00b15c000
Jan 4 10:16:17 kernel: [00000000] *pgd=0000000013ada003, *pud=0000000013ada003, *pmd=0000000013ac6003, *pte=0000000000000000
Jan 4 10:16:17 kernel: CPU: 1 PID: 26747 Comm: dcd Tainted: P O 4.1.27 #2
Jan 4 10:16:17 kernel: Hardware name: Broadcom-v8A (DT)
Jan 4 10:16:17 kernel: task: ffffffc01e8d9580 ti: ffffffc0065f4000 task.ti: ffffffc0065f4000
Jan 4 10:16:17 kernel: PC is at 0xf7451f44
Jan 4 10:16:17 kernel: LR is at 0x1dc74
Jan 4 10:16:17 kernel: pc : [<00000000f7451f44>] lr : [<000000000001dc74>] pstate: 600e0010
Jan 4 10:16:17 kernel: sp : 00000000ff961e78
Jan 4 10:16:17 kernel: x12: 000000000009ff10
Jan 4 10:16:17 kernel: x11: 00000000f66ff024 x10: 00000000000a02b4
Jan 4 10:16:17 kernel: x9 : 00000000f66ffb14 x8 : 00000000000a076c
Jan 4 10:16:17 kernel: x7 : 00000000f66ffb4c x6 : 00000000000a0766
Jan 4 10:16:17 kernel: x5 : 0000000000000000 x4 : 00000000f66ffaf8
Jan 4 10:16:17 kernel: x3 : 0000000000000000 x2 : 0000000000000000
Jan 4 10:16:17 kernel: x1 : 000000000007c674 x0 : 0000000000000000
It has appeared a few times since updating.
@D_Day, if you want to run alpha and beta firmware you should be willing to read other people's comments before posting questions. Developers time is better spent on new issues instead of continuing to answer the same questions. :rolleyes:
Oh, BTW, this issue has been around for awhile and has nothing to do with the alpha build changes...
He wasn’t asking the developer if there was an issue. What’s the point of the thread, if you can’t ask questions? It seems you know it’s an ongoing issue, then answer his post and explain. That’s what helps the developer.
I did a dirty flash on my AC3200 and have been connected for 30+ hours on all bands as well. Some of the other options I have been successfully using are; VPN with Rules for clients, DDNS, and DNSSEC. The only issue, other than those previously listed, I have found is I get a 404 not found when i try to use the Roaming Block List under Wireless but I attribute that to the dirty flash. Once the next alpha/beta comes out I am going to do a reset and I am sure that will get sorted then. GREAT JOB RMerlin :D and i hope you appreciated my donation ;) Happy New Year!
I'm getting the same thing after a factory reset wipe reconfigure manually. I have again factory reset & reconfigured manually. We'll see if I continue to get. I am also interested in what this is, should there be concern.
I have RT-AC86U also.
Hi @WET,
Doing a quick look up, this member has experienced that log message for awhile now:
https://www.snbforums.com/threads/a...384-45149-12-05-2018.50232/page-4#post-450092
It may be some quirk in the stock firmware. If everything is running well, probably safe to ignore. :)
