AB-Solution - The Ad Blocking Solution
I have a problem with pixelserv-tls too, but I'm not running openvpn
hecking pixelserv-tls
 192.168.1.2 responded, looks good
 pixelserv-tls is not running, restarting
 Starting pixelserv-tls (AB-Solution)...              failed.
and syslog only display this error (and I have -l 2 switch added):
May 30 11:38:39 xxxx: Failed to start pixelserv-tls (AB-Solution) from /tmp/mnt/usb/adblocking/addon/pixelserv-tls.add.
Any help? thanks a lot.
You could perhaps start here:
https://www.snbforums.com/threads/p...bserver-for-adblock.26114/page-96#post-406245
and then follow the suggestions I was given over the next couple of pages ans see if any of the kind advice I got is relevant or helpful to you.
Remove the -l2 switch first, then disable and enable pixelserv in the AB UI.
This might work.
@thelonelycoder
I'm running syslog-ng and as part of the setup, /tmp/syslog.log is symlink to another file e.g. /opt/var/log/messages
Whenever I enter into the setup screen via ./ab-solution.sh, it seems that the symlink to /tmp/syslog.log gets broken. Through come trial and error, it seems that sed -i under check_ps() broke the symlink
Appreciate your help to look into this
@thelonelycoder
You fix your problems, I fix mine. Recommend you check how you add the symlink. AB-Solution does not meddle with the syslog, only send messages to it.
Actually, I do meddle with the syslog by deleting a testmarker I set.
Let me check if I can port the code I use in AB4 to check if pixelserv is up.
It might not reliably work for older pixelserv-tls versions.
This might work.
It doesn't work :(
I have installed the version 1.0.2o-1 of libopenssl. Could It be the problem?
All the AB4 mentions, are making me "jones". :confused:
You Clark are officially allowed and supposed to post such comments.
Everyone else just grind their teeths, keep up the good spirit and hope for the best.
I have not touched any code at all in weeks. Blame my employer, the number is +41 (area code) (more numbers). Ask for the Boss and tell him to give me a break.
But don't tell him that I already compensate part of the accumulated overtime this week.
Not to mention it, but this relates:
I was at the Roger Waters Concert in Zurich this Monday.
The Wall's "Mother" was performed and I find the final words oddly appropriate to my situation regarding the unmentionable:
Mother, did it need to be so high?
@thelonelycoder
I pushed an update to the server. There is no version change, only the release date changed in s.
Use 1233 in the AB-Solution UI to update all files to the updated version(s).
Along with this small change, I have changed the license of AB-Solution and amtm from the GNU General Public License, version 3.0 (GPL-3.0) to GNU General Public License, version 2.0 (GPL-2.0)
The license is now stated in every downloaded file. The AB-Solution website and the amtm GitHub repository also reflect this.
When using AB-Solution and pixelserv-tls, I need to import the certificate to each device on the network - iPhone, iPad, Andriod phones, macbook pro, windows laptop? - to avoid the invalid certificate error?
Sorry, there are hundreds of pages and I am not 100% clear?
Interesting occurrence - I was trying to open ATP/WTA Live application on IPhone 7. It was blocked. Followed the log file and saw that it tried to open google-analytics.com AND secure.us.imrworldwide.com.
So I entered both in whitelist - reprocessed whitelist and application was still blocked. After a bit of mucking around I found i had to enter www.google-analytics.com to unblock the app. Cheers.
thanks for the quick fix, have done the update and confirmed that the symlink to /tmp/syslog.log is not broken anymore
cheers!
How can I add multiple URLs of IP block lists to ab-solution?
Edit: I figured it out.
Edit2: Is it allowed to share a custom_hosts_list.txt?
Did anyone manage to find out why we need to disable/enable adblocking to unblock websites, when there are no blocked domains that show up in the logs?
