AC3200 Merlin Firmware issues
Are you resetting to factory defaults before the flash?
Don't
One more thing to try.....when it asks you to reboot and you can't.........physically unplug the power to the router wait 20 seconds and plug it back in. You do not have to wait 10 minutes. Just wait a couple seconds and unplug and plug back in 20 seconds later lets see what happens then.
Do not use the switch.
Trust me it will not work well as a plex server.
Did you try this?
What is all connected when you do the flash?
Only thing I have connected is my laptop nothing else not even internet.
I think that's it you need your laptop and internet connected.
Make sure internet is plugged in please as well your laptop.
If the internet is not connected you don't need new firmware your router is a complicated switch without internet.
Sorry I was unable to help.
1. No one else has this problem
2. The firmware is good
3. The router works on stock firmware.
4. You are able to load stock firmware so flashing is ok.
5. Nothing left but YOUR process.
6. Take a look through these posts what you need is there try again when you are ready.
