I have no idea if this has anything to do with it, but I’m running vlan tagging for a fiber optic connection so I can bypass the modem. Along with that I’m using pppoe as well. Would either of those have any effect on the 5ghz band?
Any other suggestions then?Not sure on throughput, but security is a major issue.
If you live in a sleepy town/village don’t worry, if you live in a city it’s not a solution IMO.
That’s weird, because in that forum they are having problems with TKIP on 5ghz, and I’m having problems with AES on 5ghz. It doesn’t make sense! The second I changed it from WPA2 with AES to WPA with TKIP/AES it started working flawlessly. I really don’t want to run a separate Apple router just for my Xbox though. I bought this router to replace the Apple router, so adding it to the mix isn’t ideal. Is there something else I can try?I don’t know how true this is, but it’s one of the only references I can find to your issue
https://forums.xbox.com/en-GB/thread/9BE0EDC1-E057-4C34-88B2-CC38475A6986
If it is true then it seems you are snookered! But I can’t believe Microsoft would leave this gaping hole for so long.
I have an Apple TC and I have it wired to my Asus and broadcasting it’s own Wi-fi in Bridge mode (I use it to connect legacy 2.4G clients so they don’t slow my main 2.4G band on the Asus down).
If you say 5Ghz works for you on your extreme, I would do similar and connect only the Xbox to it.
Don’t be fooled by all the ‘faster’ Wi-fi speed rubbish that routers are marketed with. My AC5300 can supposedly support 5300Mbps however that’s shared over many clients and over 3 bands. A single client won’t go over ~1300Mbps. On top of that your internet is going to be WAY slower than any 5Ghz Wi-fi, so it doesn’t really matter!
Short of using a meda bridge to connect to the xbox, which is what I did, I'll have to check my xbox to see if I get the same issue this is interesting, though they might have fixed it in a preview build.That’s weird, because in that forum they are having problems with TKIP on 5ghz, and I’m having problems with AES on 5ghz. It doesn’t make sense! The second I changed it from WPA2 with AES to WPA with TKIP/AES it started working flawlessly. I really don’t want to run a separate Apple router just for my Xbox though. I bought this router to replace the Apple router, so adding it to the mix isn’t ideal. Is there something else I can try?
Welcome To SNBForums
