maxbraketorque
Release notes seem to indicate that its the same as 386.2_a1_v2.
Almost, there might be a commit or two that are newer.Release notes seem to indicate that its the same as 386.2_a1_v2.
I simply decided to push it as it is as a point release, since the few non-bugfix changes (nano and inadyn updates) seem solid enough to not require going through a full beta cycle. And adding SNMP to the RT-AX86U probably won't cause any issue on its own (if it's not fully working, then people can always keep it disabled anyway).
As I said, there might be a commit or two that weren`t included in the last public test build.So, does this mean 386.1_2 is the release version of 386.2 alpha?
Can you tell me what you are putting in each setting? I'm getting a error connecting. Saw your comment and installed alpha hoping it fixed it, but it didn't. Still getting an error when trying to connect to dnsomatic.
BTW, on a RT-AC86U
Fix your config then. This is the exact same inadyn software on all router models.Fixed for two AX86U routers, but NOT fixed for AC86U.
When I flashed the AC86U, this is still not fixed.
@Merlin, DNS-OMATIC i still broken for AC86U despite fixing for AX86U...
Clarifying... this thread is about 386.2_a1_v2 'ish.final 386.1_2 version out now!
My understanding is that this was being called 386.2 Alpha, and was subsequently renamed 386.1_2 when released as a "Final". @RMerlin decided that since it only contained bug fixes to the original 386.1(and not a full new GPL from Asus), thus a "point" release. I would suggest a renaming of this thread, as we now have many confused users, and info scattered across two threads.Clarifying... this thread is about 386.2_a1_v2 'ish.
So wouldn't this 386.2x be 'newer' than the 386.1_2? Isn't this .2 on a later GPL release than .1? Looked just now for the GPL of 386.2 and didn't find while posting. Will have to look harder.
386.2_a1_v2 is working very nicely for me on AX88U, AC86U and AC68P.
May I suggest a renaming (and possibly closing) of this thread, now that this Alpha firmware was officially released as 386.1_2? At this point it doesn't seem to make sense confusing users into thinking that this Alpha is newer than the release, when in fact the opposite is the case.Out there for early birds!
Test builds - OneDrive (live.com)
Nothing to be confuse about, this thread is about 386.2 a natural progression which RMerlin will continue on. What he released is 386.1, even most of the correction was from 386.2, this version will live on not unless RMerlin disagrees.May I suggest a renaming (and possibly closing) of this thread, now that this Alpha firmware was officially released as 386.1_2? At this point it doesn't seem to make sense confusing users into thinking that this Alpha is newer than the release, when in fact the opposite is the case.
Just a suggestion...
I would say that we will (one day) get a true 386.2 Alpha when development starts from @RMerlin based on a new GPL drop from Asus. This is not it, but sure, two different views, I get it.Nothing to be confuse about, this thread is about 386.2 a natural progression which RMerlin will continue on. What he released is 386.1, even most of the correction was from 386.2, this version will live on not unless RMerlin disagrees.
Hi, its the same config as the two AX86U routers that work fine.
I'll try another factory router reset on the AC86U when out of lockdown as this is parents router. I did expect it to be the same code which you confirmed.
It was broken on all AX86U/AC86U in the 386.1 alpha and betas - but when inadyn was updated they (AX86U) both now work.
UPDATE: AC86U is ok. First reboot after update implemented and for some reason DNSomatic must have refused an update. A reboot hours later and its registered now.
Happy again, I did think it was odd at the time as expected code to be the same and I knew the AX86U DDNS for DNSomatic worked.
Sorry Merlin![]()
Welcome To SNBForums
