New 386.2 alpha builds uploaded 1h ago.
- NEW: Added jittertimer-rngd daemon to HND routers. This will ensure sufficient entropy is generated early on at boot time, reducing boot stalls caused by insufficient entropy for the kernel's random number generator, and also generally improves security related to crypto operations by the router.
Interesting addition. I've not heard the term entropy applied to a kernel, let alone that insufficient entropy can cause a boot stall
May 4 22:05:14 Mastiff: init
May 4 22:05:16 kernel: pgd = ffffffc015446000
May 4 22:05:16 kernel: [f727e5d0] *pgd=0000000014143003, *pud=0000000014143003, *pmd=00000000155b6003, *pte=0000000000000000
May 4 22:05:16 kernel: CPU: 0 PID: 1959 Comm: amas_lib Tainted: P 4.1.27 #2
May 4 22:05:16 kernel: Hardware name: Broadcom-v8A (DT)
May 4 22:05:16 kernel: task: ffffffc01e02ab40 ti: ffffffc0157a0000 task.ti: ffffffc0157a0000
May 4 22:05:16 kernel: PC is at 0xf6a16a58
May 4 22:05:16 kernel: LR is at 0xf6a14728
May 4 22:05:16 kernel: pc : [<00000000f6a16a58>] lr : [<00000000f6a14728>] pstate: 60080010
May 4 22:05:16 kernel: sp : 00000000f727e5b8
May 4 22:05:16 kernel: x12: 0000000000000000
May 4 22:05:16 kernel: x11: 00000000f7280b94 x10: 0000000000000002
May 4 22:05:16 kernel: x9 : 00000000f6c0a979 x8 : 00000000f6b0f000
May 4 22:05:16 kernel: x7 : 00000000f728bce0 x6 : 00000000f6b0fcc0
May 4 22:05:16 kernel: x5 : 00000000f6b0fcc0 x4 : 00000000f727e680
May 4 22:05:16 kernel: x3 : 00000000000f7db0 x2 : 00000000f7280bac
May 4 22:05:16 kernel: x1 : 00000000f6c0a979 x0 : 00000000fbad8004
Just an FYI....I added haveged to my fork back in 2017 (both arm and mips). Ran into entropy shortage problems when I did the original dnscrypt.And it seems much less bloated than a solution like haveged.
Alpha on GT-AX11000 seems to be working as expected. Aside from listing 5 lan ports(figured such) and the extra 5G band, I would not be able to tell the difference in the firmware GUI-Layout than the RTAX88U.Has any one been able to test the 2G port functionality. I was able to get WAN connection with it though I haven't been able to test for the max uplink due to equipment limitations.And it was also causing my GT-AX11000 to get stuck at boot time after going from stock firmware to my test build. My firmware has an additional SSH key over stock firmware, so on first boot it was attempting to create that key. The entropy pool was flat out 0 that early in the boot process, dropbear's key generation was pausing the entire boot process as it was waiting to obtain sufficient random numbers, and there wasn't any activity yet to generate sufficient interrupts to fill up the pool, meaning the router was stuck forever at creating this key. That particular issue was resolved by moving the SSH service start at the near end of the boot process. However a few other processes still took a bit longer to initialize (like AiMesh's config management process which relies on generating a key/cert pair), which led to the addition of this entropy generator. Unfortunately it doesn't work on older kernels/uclibc, so it only applies to the RT-AC86U and newer.
This one was picked because it uses the same method Linus added to recent kernel versions (timer jitter) to resolve that issue at the kernel level. And it seems much less bloated than a solution like haveged. This remains experimental at this stage, I haven't decided yet if I will keep it in, or if it will leave it running permanently or only at boot time. That's what alpha stage is for me, a time to experiment with things.
Took me a minute to find the relevant tidbit of info on that page. Rather fascinating to see an AX68U. Wondering how it differs from an AX86U.
Fascinating, as no one has pointed out yet... It seems this is an upgraded AC68U (the AX version). Just as the AX86U (upgraded AC86U?)...Took me a minute to find the relevant tidbit of info on that page. Rather fascinating to see an AX68U. Wondering how it differs from an AX86U.
Eagle-eyed forum members have been waiting patiently for a sign... lolFascinating, as no one has pointed out yet... It seems this is an upgraded AC68U (the AX version). Just as the AX86U (upgraded AC86U?)...
If it also goes on sale for less than $200.00, then it would be worth considering.
I was lucky to get both RT-AX88Us on Amazon sale events for £200. Different currency.Different currency. The RT-AX86U was available for $200 USD on sale too. The RT-AX68U does not justify that price with half the resources it has vs the much better model up.
you may have misplaced the quotes there. I would have placed them thus: "entry level"There is no comparison between the two (hardware), I would not recommend it at the current price (the RT-AC86U is still the best bang for the buck entry level 'router').
Welcome To SNBForums
