When LED control is disabled it turns the LEDs on. This has always been the case.This is after a reboot. I'd expect the LEDs to be off. Not so
Minor (does not affect functionality) issue with amtm reporting that new firmware version is available:amtm 4.9 is now available
- Adds support for 3006.x firmware: GT-BE98 (by @GNUton) and RT-BE96U, GT-BE98_PRO (by @RMerlin).
- Shows correct firmware version in header for new models.
- LED control lc compatibility with new models. 3006.x firmware models switch AURA lighting on and off if enabled with the changed option to use Night Mode when switched on.
Please post output of these:Minor (does not affect functionality) issue with amtm reporting that new firmware version is available:
nvram get webs_state_info
echo $(nvram get buildno).$(nvram get extendno)
Code:nvram get webs_state_info echo $(nvram get buildno).$(nvram get extendno)
Admin@GT-BE98_Pro-DE30:/tmp/home/root# nvram get webs_state_info
3006_102_1_0
Admin@GT-BE98_Pro-DE30:/tmp/home/root# echo $(nvram get buildno).$(nvram get extendno)
102.1.0
Thanks, I see now where it comes from.I can confirm this behavior:
Output below:
Code:Admin@GT-BE98_Pro-DE30:/tmp/home/root# nvram get webs_state_info 3006_102_1_0
Code:Admin@GT-BE98_Pro-DE30:/tmp/home/root# echo $(nvram get buildno).$(nvram get extendno) 102.1.0
Checking MerlinAU, I can also confirm no updates are actually available![]()
That’s someone else’s software causing that while you updated. Nothing in amtm does anything like that as far as I know._wlcsm_create_nl_socket:268: pid:4253 binding netlink socket error!!!
Oh, it is someone else’s bug:Updating to 4.9 was presented with a "wlcsm" message, which just hung there. After about 30 seconds the "panel showing following data" closed back to the SSH prompt.
amtm 4.9 FW by thelonelycoder
ASUS GT-AXE16000 HW: aarch64 Kernel: 4.19.183
FW: 3004.388.7 IP address: 192.168.50.1
Operation Mode: Wireless router
Activated AMTM, now 4.9, everything seems fine.
Welcome To SNBForums
