P
podkaracz
Guest
Nowhere in your rantings have I've been able to find where you have stated what WIFI settings you are using or have changed. Same for QOS. Both can impinge on performance. Also, are you using any USB drives? Media Server? Samba? the last three will run up memory usage where adding a swap file to a thumb drive may help (yes, you can add a swap file or partition to stock Asus firmware).
You will get a lot of recommendations here. One thing I've discovered with this "new" firmware is a factory reset after upgrade is a good thing. Manually configure (don't use a backup file). Use Dual Band SmartConnect (same SSID for 2.4 and 5 GHZ), 2.4 GHZ set to 20 MHZ CH 1, 6, or 11, 5 GHZ set to 20, 40 80 MHZ on a non DFS channel (I use 36), disable WPS, Media Center and Samba. Leave all the other WIFI settings to default! (yes, there are many who say to disable this and that WIFI setting but just try it!). Don't use the router for file storage initially (in fact don't use it for file storage at all...use a NAS). Just try it with 384_81858. Antennas, have all three straight up.
Edit: Forgot to mention setting USB3 to USB2 mode and turn off UPNP.
Wifi settings both set to legacy both disabled everything ( i mean everything not a single option enbled in 5ghz and 1 option enabled in 2.4ghz which is enable radio antena so that 2.4g can work ) Qos disabled . Usb disabled and set to 2.0 with hibernation enabled. Media server, samba disabled. Dual band smart connect disabled. 2.4ghz is legacy 20mhz ch 1. Wps as well as upnp is a security risk by aiprotection so i always disable it so its disabled too. I dont connect anything to router other than 1 cable to wan 1 lan to computer and power supply.
So yea thats the settings i use many months now and they are exact same on every firmware i use so like i said everything possible turned off the only difference is how given firmware performs.
