Beta Asus RT-AX89X_9.0.0.4_388_31185 Beta
I am trying to get a GPON unit to work on my RT-ax89x router. Where can I download the 9.0.0.4.38xxx?
I saw something similar to this on .33673 last night. I had two WiFi devices that could see the 5GHz network and attempted to connect to it, but upon re-connection the signal was unusually weak, there was no Internet access, and within seconds they'd be booted off the network.
Because I needed connectivity at the time, I didn't troubleshoot extensively or test with additional devices. A reboot (via the GUI using a wired client) solved the issue.
In other news, it's a little unsettling to see the beta firmware downloads vanish. With such long spans between official releases, that was my only way to ensure security updates and the only sign that Asus gave to indicate the AX89X was still on their radar. I think I'm just going to shift to an OPNsense mini PC router and reduce my AiMesh system to handling WiFi clients.
Looks like the files are back at the same link. New file posted a couple of weeks ago.
Anyone has 9.0.0.4_388_33699 installed? how is it working? any new feature?
I upgraded to .33699 just now.
The string at the end of firmware filename makes it seem like specialized release to address a specific issue: "he20_us_bdf_minus_1.5dB_1". Not sure what to make of that.
No new features immediately jump out, but I have noticed that RAM usage is a good 4-5% higher than usual. I'm going to keep an eye on that after the runaway RAM leaks from a few versions ago.
I'm also seeing a reduced signal for some devices. For example, the Mac Studio I'm using right now has two signal bars as opposed to the full 3. Reconnecting did not improve the strength. Maybe this has to to do with the "–1.5dB" in the filename?
WAN speed test is 1383 Mbps down, 42 up, so things are good on that front.
I also installed .33699 for the new year. So far so good :-)
Following up: RAM usage dropped back down to 53% and has remained there for the past couple of days.
The weaker signal that I was seeing on at least one desktop has since resolved itself and is now back to full bars.
So I'm not really seeing anything of concern on .33699 firmware.
