ASUS RT-N66U Dark Knight Dual-Band Wireless-N900 Gigabit Router Reviewed
Nice write-up so far Tim!
The E4200 v2 indeed has the best USB read and write performance, as expected given what cNet observed.
I am glad the RT-N66U did very well in the WAN to LAN and LAN to WAN testing, albeit not chart-topping (that title still belongs to its predecessor the RT-N56U) and that it has more than enough total simultaneous throughput ("more than anyone could ever use" as you put it) and maxed out the simultaneous connections test.
Looking forward to the wireless performance tests in Part 2.
I think that, at least on the 2.4 GHz band *, wifi performance is where, based on my comparison tests and those of Geraner and others on amazon etc., it will hopefully excel overall relative to other N900 competitors.
I know you don't test / post signal strength which is what impressed me so much but hopefully the throughput figures in your tests will be near the top.
* I have not tested 5 GHz throughput yet although the signal strength on my Blu-Ray player's built-in dual band wifi adapter was impressive even in the far corner of the house (better than my E4200 v1).
The reason I don't measure signal strength or look at link rates is that they are very indirect indicators of performance. The bottom line is the throughput you get, which is what I measure.
Two stream tests are posted in the charts. Use this link to compare against Cisco E4200V2 and NETGEAR WNDR4500.
Interesting...I do wonder if the Netgear 4500, in their latest firmware, have gotten better on the 2.4GHz. results, but the rt-n66u looks great relative to the 3-stream router competition. Two-stream is most relevant for me anyways, don't have 3-stream adapters at the moment. Although that's subject to change *smile*.
I know that you did a re-test of the Netgear some time ago, but with the components that router has, it's hard for me to understand why they can't get better 2.4GHz. performance out of it.
Thanks for the early posting of wireless results.
This is indeed interesting. A three way shoot-out between E4200V2, NETGEAR WNDR4500 and the N66U (as soon as its testing is complete).
Talk about a cliffhanger ! :D
Add the Airport Extreme 2011 to make it really interesting - routing and wireless performance only, would be interesting to see how different 3-stream implementations compare...
:cool:
Also, since part of the review contained USB storage performance, it would be great to re-test the 4500 with the latest firmware since it specifically states that it was addressed.
This is the .103 Beta notes:
[Fixed]: Guest network can’t access internet when client access main wifi network first.
[Fixed]: can’t find DNS server.
[Fixed]: when using fix ip, DHCP will send NAK and connection will drop and re-connect.
[Enhancement]: improve the read/write speed for ReadyShare NTFS file system.
My retest was done because of an improperly configured client, not anything NETGEAR did. I've yet to see a firmware change improve performance significantly.
I think this router tested perfectly, unlike the E4200v2 :). Although, there are two things I must say. The new firmware improves USB speeds, and also a note that there are more than one 3rd party firmware support with more coming for the RT-N56U. So, to say that "which opens up the possibility of alternate firmware support, unlike the Ralink-based RT-N56U" is not true.
Can anyone say anything about about the USB improvements, if any?
What new firmware are you referring to Shikami. The router was tested with the latest 3.1.0.3.90 release.
I will correct the RT-N56U statement. Thanks for pointing out the error.
ASUS RT-N66U B1 Firmware version 3.1.0.3.90
Add USB performance enhancement into RT-N66U
Yep, that is the one, and just noticed on the firmware notes. I took a quick look at the references speeds, since I am at work :p. Man, I wonder what the "improvement" was, as in difference? The USB performance is not that bad though with recent firmware. I think it is the "sweet spot."
Honestly, 3rd party support has me salivating for this router. The potential, um.
I wonder why include the SD slot only to make it in accessible unless you open the chassis up?
Other than Total Simultaneous Input and USB drive performance from the testing I've seen so far on SNB, looks like the N66U may take the lead in averaged 2.4 and 5Ghz up/down--still more to come on its three-stream testing capabilities.
Not sure what impact if any, very high Total Simultaneous Input capabilities have in a home environment e.g., 810. vs 1268 so maybe the Dark Knight will be the Wireless Router to beat this year for best averaged range and performance :cool:
:cool:
Looks like all the N66U tests results are now posted. The N66U seems to be doing very well. However like Tim said there is no one killer wireless router. They all have their strengths and weaknesses.
Just curious. Why do you write "I think this router tested perfectly, unlike the E4200v2 :" ?
Sharp eyes there, delair2. Yes, all wireless results are in the Performance Charts. The final review will be up tomorrow.
I got delayed because I added some new benchmarks to the charts. The new benchmarks show the results for the simultaneous up/downlink tests I've been running in Location A.
Ha. I was wondering what "up/downlink" was.
