Asuswrt-Merlin 3.0.0.4.372.30_2
Client List
Based on the error message, it sounds like this function gets called while one of these lists is empty.
Thanks, this gives me a starting point to look into it.
The most common invalid names that I see are names that contain quotes, or non latin characters (i.e. people using cyrillic in device names). This also applies to the DHCP reservation page of the router. I doubt that's what is causing your issue in this case, but you can check that page too if you had manually entered device names there.
Same issue here with W7 64bit and IE10.
Just to echo zenmota's issue- I'm facing the same thing on the same setup: Win 8 Pro amd64 / IE 10 32 bit / RT-N66U with 3.0.0.4.372.30_2. No problems encountered on Firefox (or Chrome with Zenmota).
SCRIPT5007: Unable to get property 'length' of undefined or null reference
nameresolv.js, line 64 character 17
The problem has to do with any devices that do not broadcast a hostname, but simply their MAC address. If the devices have a hostname pushed to them (by assigning a static IP), the problem goes away. If the device is removed from the network, the problem goes away.
In my case, it is an iPhone5 and/or a MagicJack Plus that allows me to reproduce the error
After installing 372.30_2 I am having sporadic issues connecting to other machines on the same network as my router using Chrome Remote Desktop. Is anyone else experiencing this. I'm going to reflash the 29-BETA1 to see if it fixes it.
My router is the AC66U.
This may have been an issue with Google's Chrome RDC services, not my network. I tested it again on my LAN machines this morning and they all connected properly. Nothing to see here....
Some people mentioned running into issues when using the TAP interface. I didn't have time to look into it yet - I'm too busy with work to do any debugging for the next week or two.
Merlin
Thanks, I confirm that I am using the Tap interface. Do you need any other data from me?
Merlin
Not at this time, thanks. I just need to find some time to create a TAP test setup.
Found a bug i 372_30_2
In the parent control area it seems hard to add times when WAN is to be opened on specific computers. If hours are added and you go out of the parent control interface and then go back, all input is blank. This woked just fine in 354 betas for me.
Please have a look at this bug.
Thanks for the great job you do with asus routers. :)
I'm getting constant USB HDD (.ext3 format) dropouts with this new firmware whenever i stream something via DLNA. Reformatting has not resolved this? Anybody else having issues? Nothing wireless related...everything is LAN connected.
Sorry my friend but I have 3 device that don't broadcast the host name and never see this issue ( iPhone4s,2 Samsung Galaxy II ) all of them show up on the client list with MAC address and the pop up also show MAC and Manufactures information.
This is a problem with IE. Try a different browser for now.
Client list
OK...
It is not simply a matter of clients without hostnames. I'm giving steps to reproduce:
  • RT-N66U (3.0.0.4.372.30_2)
  • IE (v10 32 bit)
    • Script debugging on !
  • Machines are on network without hostnames or static IPs
I can eliminate the problem by disconnecting those machines from the network or assigning a static IP. It is CLEARLY what is causing it on my setup.
Depends on what you use. There has been numerous bugfixes since 270.26b, especially around OpenVPN and Per IP traffic monitoring. If you use either of these, you should definitely upgrade.
Merlin. First of all thank you!!...again for the firmwares. Invaluable.
I did check the changelog and besides what you mention above is there a wireless performance increase with 30_2 versus 270.26b for the N66U?
And if I do upgrade are these steps recommended:
- upgrade firmware
- clear NVRAM by pressing the reset button while powering up then 10sec after power up
- re-enter settings
Thanks for the fast answer. That is somthing I figured aswell. rather strange though that these bugs keeps coming back in some browser and only in some firmware version. I hope a stable fix for this is coming.
Asus should be as dedicated as you... you are a rolemodel for how support should be done. Thanks
I'm getting no static DHCP leases for my mobile phone
Jul 10 10:47:10 dnsmasq-dhcp[858]: not giving name GT-S5330 to the DHCP lease of 192.168.1.4 because the name exists in /etc/hosts.dnsmasq with address 192.168.1.13
I have stopped dnsmasq manually.
Clear the dnsmasq.leases file in /var/lib/misc
restarted dnsmasq
But still getting 192.168.1.4 as adress
Assigned IP
D0:DF:C7:96:DF:C6	192.168.1.13	GT-S5330
System Log - DHCP leases
GT-S5330                192.168.1.4     d0:df:c7:96:df:c6 23:53:22
- upgrade firmware
- re-enter settings
Not performance, stability. The 3xx driver has broken 5 GHz 40 MHz support.
See the FAQ on the Wiki for the various ways of clearing up nvram. The method you mention won't clear NVRAM but enter recovery mode.
OK...
  • IE (v10 32 bit)
Thanks, I used one of my VM to test it and the problem is only with IE 10 and IE 9 32bits , if you use Firefox on the same machine all works fine.
The problem is related on the security, if you add the site to the trusted you can see all the client listed correctly.
It's not a fix because it lower your safety but it my help Marlin on fix it ;)
Using this new version(RT-AC66U_3.0.0.4_372.30_2-dw), my RT-AC66U cannot detect anymore my 4G modem (it work perfectly with previous version-RT-AC66U_3.0.0.4_354.29-BETA1-dw). Below is log after insert my modem-
Dec 31 17:06:37 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 6
Dec 31 17:06:37 kernel: usb 1-1.2: configuration #34 chosen from 1 choice
Dec 31 17:06:37 kernel: scsi1 : SCSI emulation for USB Mass Storage devices
Dec 31 17:06:39 kernel: scsi 1:0:0:0: CD-ROM GCT Semi CD-ROM 312e PQ: 0 ANSI: 0 CCS
Dec 31 17:06:39 kernel: scsi 1:0:0:0: Attached scsi generic sg0 type 5
Dec 31 17:06:40 kernel: usb 1-1.2: USB disconnect, address 6
Dec 31 17:06:40 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 7
Dec 31 17:06:40 kernel: usb 1-1.2: configuration #17 chosen from 1 choice
My router detect my modem as "M-WiMAX Network Adaptor" for previous version.
OK,
My USB modem (Infinity IW-021) for WAN-failover is definitely no longer stable under 372.30_2.
Although the modem works as a generic 3G_modem it is not listed as a known vendor modem in the pull down configuration list.
Reluctantly I sourced a replacement Huawei E220 and together with the excellent 372.30_2DWRP firmware the WAN-failover is once again stable.
However, and to be honest I never checked previously, when I disconnect the WAN router the USB modem connects but apparently DDNS gets updated with a 10.13.*.* address whilst the the Dual WAN GUI shows
Local = 10.33.200.104
Remote = 10.64.64.65
NOTE: My local LAN has always been 10.88.*.* (so my family can connect to cameras etc. and vice-versa) so not sure if there is a fix for my USB WAN-failover DDNS update bug?
i.e. it would be nice to know that if the USB WAN-failover occurred while no one was @home that we could still be able to connect back via OpenVPN to view the cameras etc.
Regards,
I have the rt-ac66u. I don't see any difference except that there is a new router been added rt-ac56u.
same wifi driver Jan 22 2013 14:56:50 version 6.30.102.9 (r366174)
and same bootloader (CFE) 1.0.1.4. Does this main the flash to the new version failed? I came from 3.0.0.4_354.29-BETA1.
I have a ac usb3 stick from trendnet TEW-805UB it's not working.
the 260 driver has no problem.
Wait a minute...
My Tools - System Information tells me that my CFE is 1.0.0.7, though I use the latest firmware (3.0.0.4.372.31_alpha1). I'm just curious about this misterious difference. :)
Wait a minute...
The CFE has nothing to do with the firmware. A CFE is similar to a motherboard BIOS, while the firmware would be your Windows/Linux installation.
