joegreat
In my case the update is done for 666 MHz RAM speed...
With kind regards
Joe
You get an immediate answer when you connect via telnet to the router and you issue the command:What i wonder is: does my mem already run at 666mhz or do they run at 555mhz with this firmware ? I have not flashed the asus "special" ddr speed flasher. Is that something i need to do, or are my ddr already running at 666mhz with the 374.40_beta3 ?
chief@RT-AC68U:/tmp/home/root# [B]nvram get clkfreq[/B]
[B]800,[COLOR="Red"]666[/COLOR][/B]
Yes!If the answer is no, can i use the 666mhz "flasher" with this firmware ?
With kind regards
Joe
