Asuswrt-Merlin 376.45 is out
What about those log entries about
"received packet with own address on eth1 interface" ?
On this interface i have my desktop which does not have any wifi capabilities whatsoever.
You can't have your non-wifi desktop on eth1 because eth1 is the 2.4GHz wifi interface. The wired LAN ports are on vlan1 and connected to br0.
Wifi signal 2.4ghz is very low like 376.44 i back to 374.43 build.In my brother room laptop show only 3 bars.374.43 build show all 5 bars.Symbian phone show only about 30% signal.With 374.43 build symbian show about 70% signal.Very bad signal quality with latest builds.Rmerlin please return tx power settings in numbers.Please remove tx power percentages selection.Rmerlin very please.Only with tx power setup with numbers i have very strong wifi signal.
376.45 - Updated openssl to 1.0.0n
You will be running with known exploits in your firmware if you use 374.43. Good luck with that :rolleyes:
Ookkay... i stand corrected. Always thought that eth1 is the first LAN port...
Then eth2 would be a 5GHz radio?
And these messages happen because i have the same name on SSID for both frequencies?
What router are you referring to N66U ?
Correct
Yes, that sounds likely. Basically it is saying that traffic coming from a device that is associated with one interface (say the 5GHz adapter) has just appeared on a different interface (say the 2.4GHz adapter).
I have a access point in a remote part of my house connected back to the router (both with the same SSID). When I walk through the house with a mobile phone (wifi enabled), that message will appear as the phone switches between the access point and the router.
So at the end of the day, the message is not an error, it's just information.:)
I have GUI problems only when I change the default LAN IP from 192.168.1.1
I still don't know why.
-supe
Drat. I had high hopes for that because I've always preferred 192.168.0.1, for reasons I no longer remember.
I've switched back to the default 192.168.1.1 and rebooted everything.
The router pages still hang for me. It takes about 5-10 clicks on buttons before it happens. Which buttons doesn't seem to matter.
I'm on 43.
Bruce.
I have an RT-AC68U.
Two bugs I noticed with 3.0.0.4.376.44_0 and now 3.0.0.4.376.45_0:
1) Under "General", clicking "USB Application" causes "Updating..." to just stay on the screen (and never goes away). If I click "Cancel", then it changes to "Loading APP List" and shows all the options.
2)
Go to "General" -> "Network Map", then click the USB 3.0 icon to view my HDD. Under "Disk Utility" then "Schedule Disk Scan", no matter what I put there, it never saves. It changes back to Frequency: Disable.
Are those known issues?
Also, what is the recommended file system for the external hard drive? I had issues with FAT32, but NTFS seems stable. Would ext4 be better?
I have an RT-AC68U.
2)
My scheduled scan also reverts to "Disable", going back as far as I can remember with this router. I'm using ext4 on my drive.
Ok so I have flashed this firmware in hopes of fixing my RT-AC66R (bestbuy version :o)
anyway as I posted in another section, I keep having intermittent drops, in well everything, and cant get it pin pointed...
in fact when I was on the phone with comcast the freaking modem reset right when i was on the phone with them, and I asked her if they sent a signal to it, she said no....
And then proceeded to ask if i would reset my router, told her i had reset this stupid router, more times then the hair on my head... And asked her if there was anyway the router could reset the modem??? Because if its on the back side it cant............RIGHT????
Any way, I am trying this as another shot at isolating the problem....
to further explain...have had this router since Jan 1....it has worked fine until 1st part of July (right around 6 mths, which i had 2 others do the same thing in the same time frame).....
I asked my computer guy about it, and he pointed to the fact maybe i had to many devices coming through the 1 channel..(2.4), and that i should if possible move phones and/or tablets to the 5ghz, and to also set up a few guest accts, to help level out the data hose (my term)
what do you guys think of that??
Ok well it didnt hold.....ill post a copy of the log, as it just happened...and these 1st 4 lines, there was a string of stuff it was doing like it in the 20:50 range...anyway here it goes.....please tell me if i can fix it, am about :eek::eek::eek: as can be on this
Aug 20 20:50:14 dnsmasq-dhcp[457]: DHCPREQUEST(br0) 192.168.1.15 00:1b:ea:d5:d2:ce
Aug 20 20:50:14 dnsmasq-dhcp[457]: DHCPACK(br0) 192.168.1.15 00:1b:ea:d5:d2:ce Wii
Aug 20 21:09:05 dnsmasq-dhcp[457]: DHCPREQUEST(br0) 192.168.1.15 00:1b:ea:d5:d2:ce
Aug 20 21:09:05 dnsmasq-dhcp[457]: DHCPACK(br0) 192.168.1.15 00:1b:ea:d5:d2:ce Wii
Aug 20 21:22:25 WAN Connection: Ethernet link down.
Aug 20 21:22:25 stop_nat_rules: apply the redirect_rules!
Aug 20 21:22:31 dnsmasq[457]: exiting on receipt of SIGTERM
Aug 20 21:22:31 dnsmasq[1017]: started, version 2.72test3 cachesize 1500
Aug 20 21:22:31 dnsmasq[1017]: warning: interface ppp1* does not currently exist
Aug 20 21:22:31 dnsmasq[1017]: asynchronous logging enabled, queue limit is 5 messages
Aug 20 21:22:31 dnsmasq-dhcp[1017]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Aug 20 21:22:31 dnsmasq[1017]: read /etc/hosts - 5 addresses
Aug 20 21:22:31 dnsmasq[1017]: using nameserver 75.75.75.75#53
Aug 20 21:22:31 dnsmasq[1017]: using nameserver 75.75.76.76#53
Aug 20 21:22:33 WAN Connection: Ethernet link up.
Aug 20 21:22:33 rc_service: wanduck 332:notify_rc restart_wan_if 0
Aug 20 21:22:33 dnsmasq[1017]: read /etc/hosts - 5 addresses
Aug 20 21:22:33 dnsmasq[1017]: using nameserver 75.75.75.75#53
Aug 20 21:22:33 dnsmasq[1017]: using nameserver 75.75.76.76#53
Aug 20 21:22:33 miniupnpd[502]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
Aug 20 21:22:33 miniupnpd[502]: Failed to get IP for interface eth0
Aug 20 21:22:33 miniupnpd[502]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Aug 20 21:22:33 kernel: Attempt to kill tasklet from interrupt
Aug 20 21:22:33 kernel: br0: port 1(vlan1) entering disabled state
Aug 20 21:22:33 kernel: vlan1: dev_set_promiscuity(master, 1)
Aug 20 21:22:33 kernel: br0: port 1(vlan1) entering listening state
Aug 20 21:22:33 kernel: br0: port 1(vlan1) entering learning state
Aug 20 21:22:33 kernel: br0: topology change detected, propagating
Aug 20 21:22:33 kernel: br0: port 1(vlan1) entering forwarding state
Aug 20 21:22:34 dnsmasq-dhcp[1017]: DHCPRELEASE(br0) 192.168.1.64 3c:77:e6:73:ac:51
Aug 20 21:22:38 WAN Connection: ISP's DHCP did not function properly.
Aug 20 21:22:47 dnsmasq-dhcp[1017]: DHCPDISCOVER(br0) 3c:77:e6:73:ac:51
Aug 20 21:22:47 dnsmasq-dhcp[1017]: DHCPOFFER(br0) 192.168.1.64 3c:77:e6:73:ac:51
Aug 20 21:22:50 dnsmasq-dhcp[1017]: DHCPREQUEST(br0) 192.168.1.64 3c:77:e6:73:ac:51
Aug 20 21:22:50 dnsmasq-dhcp[1017]: DHCPACK(br0) 192.168.1.64 3c:77:e6:73:ac:51
Aug 20 21:23:35 dnsmasq-dhcp[1017]: DHCPREQUEST(br0) 192.168.1.16 34:4d:f7:39:16:72
Aug 20 21:23:35 dnsmasq-dhcp[1017]: DHCPACK(br0) 192.168.1.16 34:4d:f7:39:16:72 android-540bf38a60de39eb
Aug 20 21:25:22 dnsmasq-dhcp[1017]: DHCPREQUEST(br0) 192.168.1.16 34:4d:f7:39:16:72
Aug 20 21:25:22 dnsmasq-dhcp[1017]: DHCPACK(br0) 192.168.1.16 34:4d:f7:39:16:72 android-540bf38a60de39eb
Aug 20 21:25:25 dnsmasq-dhcp[1017]: DHCPRELEASE(br0) 192.168.1.64 3c:77:e6:73:ac:51
Aug 20 21:25:29 dnsmasq[1017]: read /etc/hosts - 5 addresses
Aug 20 21:25:29 dnsmasq[1017]: using nameserver 75.75.75.75#53
Aug 20 21:25:29 dnsmasq[1017]: using nameserver 75.75.76.76#53
Aug 20 21:25:29 rc_service: udhcpc 1036:notify_rc start_firewall
Aug 20 21:25:29 rc_service: udhcpc 1036:notify_rc stop_upnp
Aug 20 21:25:29 rc_service: waitting "start_firewall" via udhcpc ...
Aug 20 21:25:29 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Aug 20 21:25:29 dnsmasq[1017]: exiting on receipt of SIGTERM
Aug 20 21:25:29 dnsmasq[1056]: started, version 2.72test3 cachesize 1500
Aug 20 21:25:29 dnsmasq[1056]: warning: interface ppp1* does not currently exist
Aug 20 21:25:29 dnsmasq[1056]: asynchronous logging enabled, queue limit is 5 messages
Aug 20 21:25:29 dnsmasq-dhcp[1056]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Aug 20 21:25:29 dnsmasq[1056]: read /etc/hosts - 5 addresses
Aug 20 21:25:29 dnsmasq[1056]: using nameserver 75.75.75.75#53
Aug 20 21:25:29 dnsmasq[1056]: using nameserver 75.75.76.76#53
Aug 20 21:25:30 rc_service: udhcpc 1036:notify_rc start_upnp
Aug 20 21:25:30 rc_service: waitting "stop_upnp" via udhcpc ...
Aug 20 21:25:30 miniupnpd[502]: shutting down MiniUPnPd
Aug 20 21:25:31 rc_service: udhcpc 1036:notify_rc stop_vpnserver1
Aug 20 21:25:31 rc_service: waitting "start_upnp" via udhcpc ...
Aug 20 21:25:31 miniupnpd[1077]: HTTP listening on port 47959
Aug 20 21:25:31 miniupnpd[1077]: Listening for NAT-PMP/PCP traffic on port 5351
Aug 20 21:25:32 rc_service: udhcpc 1036:notify_rc start_vpnserver1
Aug 20 21:25:32 rc_service: waitting "stop_vpnserver1" via udhcpc ...
Aug 20 21:25:32 openvpn[525]: event_wait : Interrupted system call (code=4)
Aug 20 21:25:32 openvpn[525]: /usr/sbin/ip route del 10.8.0.0/24
Aug 20 21:25:32 openvpn[525]: Closing TUN/TAP interface
Aug 20 21:25:32 openvpn[525]: /usr/sbin/ip addr del dev tun21 local 10.8.0.1 peer 10.8.0.2
Aug 20 21:25:32 openvpn[525]: SIGTERM[hard,] received, process exiting
Aug 20 21:25:32 dnsmasq-dhcp[1056]: DHCPDISCOVER(br0) 3c:77:e6:73:ac:51
Aug 20 21:25:32 dnsmasq-dhcp[1056]: DHCPOFFER(br0) 192.168.1.64 3c:77:e6:73:ac:51
Aug 20 21:25:32 dnsmasq-dhcp[1056]: DHCPREQUEST(br0) 192.168.1.16 34:4d:f7:39:16:72
Aug 20 21:25:32 dnsmasq-dhcp[1056]: DHCPACK(br0) 192.168.1.16 34:4d:f7:39:16:72 android-540bf38a60de39eb
Aug 20 21:25:33 dhcp client: bound 71.195.227.111 via 71.195.224.1 during 304503 seconds.
Aug 20 21:25:33 kernel: tun: Universal TUN/TAP device driver, 1.6
Aug 20 21:25:33 kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Aug 20 21:25:33 kernel: device tun21 entered promiscuous mode
Aug 20 21:25:33 WAN Connection: WAN was restored.
Aug 20 21:25:33 dnsmasq-dhcp[1056]: DHCPREQUEST(br0) 192.168.1.64 3c:77:e6:73:ac:51
Aug 20 21:25:33 dnsmasq-dhcp[1056]: DHCPACK(br0) 192.168.1.64 3c:77:e6:73:ac:51
Aug 20 21:25:36 openvpn[1125]: OpenVPN 2.3.4 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Aug 17 2014
Aug 20 21:25:36 openvpn[1125]: library versions: OpenSSL 1.0.0n 6 Aug 2014, LZO 2.08
Aug 20 21:25:36 openvpn[1125]: Diffie-Hellman initialized with 512 bit key
Aug 20 21:25:36 openvpn[1125]: Socket Buffers: R=[118784->131072] S=[118784->131072]
Aug 20 21:25:36 openvpn[1125]: TUN/TAP device tun21 opened
Aug 20 21:25:36 openvpn[1125]: TUN/TAP TX queue length set to 100
Aug 20 21:25:36 openvpn[1125]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Aug 20 21:25:36 openvpn[1125]: /usr/sbin/ip link set dev tun21 up mtu 1500
Aug 20 21:25:36 openvpn[1125]: /usr/sbin/ip addr add dev tun21 local 10.8.0.1 peer 10.8.0.2
Aug 20 21:25:36 openvpn[1125]: /usr/sbin/ip route add 10.8.0.0/24 via 10.8.0.2
Aug 20 21:25:36 openvpn[1132]: UDPv4 link local (bound): [undef]
Aug 20 21:25:36 openvpn[1132]: UDPv4 link remote: [undef]
Aug 20 21:25:36 openvpn[1132]: MULTI: multi_init called, r=256 v=256
Aug 20 21:25:36 openvpn[1132]: IFCONFIG POOL: base=10.8.0.4 size=62, ipv6=0
Aug 20 21:25:36 openvpn[1132]: Initialization Sequence Completed
I'm not debating the bandwidth here but the write speed inconsistence between wireless and wired tests. Both the router and the AC7260 are clearly capable to transfer data at 35MB/s wireless...
Run an actual speed test using a tool such as Lanbench. Uplink and downlink speeds aren't necessarily the same, which would explain the speed difference.
Please read the explanations I've posted like dozens of times already.
-supe
Check your security software. Some of them like Eset have a hard time working properly with the router's UI. If you had whitelisted the old IP, then it would explain why issues would (re)appear once you change the router's IP.
Your problem is definitely the modem. First, you saw it reboot on its own. And second, even the router saw that it physically disappeared, as shown in the above log entry.
