Asuswrt-Merlin 376.47 is out
I recently got asus ac66u and flashed it with Asuswrt-Merlin. Router is performing well however having issues with transmission, It is not working properly. It shows "Invalid arugment" after some data download. System log shows data write issues.
Also having issues with traffic data save on custom location. Transmission is installed on Entware.
Oct 25 10:53:55 cstats[416]: Problem loading /mnt/sda1/Traffic_H/tomato_cstats_e03f499da690.gz. Still trying...
Oct 25 10:53:59 rstats[410]: Problem loading /mnt/sda1/Traffic_H/tomato_rstats_e03f499da690.gz. Still trying...
Oct 25 11:06:40 transmission-daemon[696]: kali-linux-1.0.9a-i386 write failed for "kali-linux-1.0.9a-i386/kali-linux-1.0.9a-i386.iso": Invalid argument (inout.c:136)
Oct 25 11:06:40 transmission-daemon[696]: kali-linux-1.0.9a-i386 Invalid argument (/tmp/mnt/sda3/Torrent/Completed/kali-linux-1.0.9a-i386/kali-linux-1.0.9a-i386.iso) (torrent.c:536)
I am still strugguling to get transmission working on asuswrt merlin fw. I formatted Usb drive again and installed transmission again. Now attached drives goes to read only mode. I tried to remount drive but getting error Invalid argument. I tried to remount by editing Fstab but it is also not worked. Please can someone help to sort these issues.
  • Screenshot from 2014-10-26 11:52:46.jpg
Just noticed the following records in minidlna log:
[2014/09/21 18:10:38] minidlna.c:1152: warn: Starting MiniDLNA version 1.1.3.
[2014/09/21 18:10:38] minidlna.c:357: warn: Creating new database at /tmp/mnt/WD_1TB/minidlna/files.db
[2014/09/21 18:10:38] minidlna.c:1173: error: SQLite library is not threadsafe! Inotify will be disabled.
[2014/10/26 16:58:54] sql.c:117: warn: sql_get_int_field: step failed: SQL logic error or missing database
SELECT count(*) from OBJECTS where PARENT_ID = '2'
[2014/10/26 17:05:16] minidlna.c:954: error: MiniDLNA is already running. EXITING.
Hi all,
Which one of these antenna doesn't do anything at the moment? So I can get the best wifi connection around my house, is it only the forth used for the Mimo?
Hi all,
Unlike the WRT1900AC, this router uses all four antennas, since it's a real 4x4 stream router.
RMerlin
What about that SQLite error (see above)? Is this up to minidlna or to the firmware?
RMerlin
Sounds like you tried to run minidlna more than once.
The only thing I could see then is HW acceleration was changed by Asus at some point in regard to handling UDP packets (which are extensively used by torrents). This is entirely out of my control as CTF is closed source.
I finally succeeded in fixing my problem with the limitation of bittorrent download speeds. The fix was to format the jffs partition (where I had a firewall rule to allow internet access for download client). I will try to edit again such a rule to see if this has any effect.
