Ah, that was the secret!Asus publishes the GPL code on their support site, same location where you can download firmware updates. Select "Others" as your operating system, you will get a "Source code" category then.
376.47 is based on the RT-AC87U`s 376_2678 GPL code.
The AP unit may not need a reset as it's configuration is much less complex than your main router.
I would not be waiting. Upgrade to the latest firmware, as no one else has reported this issue. Do a full reset to defaults, manually enter all settings and only change the settings needed to get a working router. I would also upgrade the AP unit too at this point or at least do a reset to it too, to know where you're starting from if this needs to be investigated further.
RMerlin. I found an odd bug in 376.47. I use a RT-N66U and a RT-AC66U as ethernet bridges. I use only the 5 GHz channel. The Asus firmware automatically disables the 2.4 GHz band when you select a 5 GHz AP. When I upgraded to 376.47 from 376.45 I noticed on Inssider that there was two new AP's named Asus on channel 1 2.4 GHz and they were very close by. Turns out it was from the ethernet bridges. In this operating mode there is no way to control the wireless though the Asus GUI. I downgraded ethernet bridges back to 376.45 and the Asus signals on channel 1 went away. Thanks!
Aah sorry.Need the actual context. What are you testing, and how? What wireless adapter do you have in your client device?
Aah sorry.
I am testning the speed of the wifi,
I pay to get 500 and i get that in Wired
On my galaxy note 3 that has AC wireless I get those WiFi numbers I posted before!
Seems that the 2.4 GHz WiFi speed is quite low (56)
this problem existJust wanted to let you know that Multicast support (IGMP Proxy; IGMP Snooping; Udpxy) is broken: video stream begins normally and smoothly, but after that it gets interrupted every 30secs for about 20secs.
Okey thank you!That's probably normal speed. Most mobile devices only support 75 or 150 Mbps on the 2.4 GHz band, which is in line with the performance you are observing.
802.11ac only works on the 5 GHz band.
For me the wifi range is definitely lower (It was best with .43)
I test it with wifi analysiser and used to able to get all the way to the bottom of garden and get a decent signal , now I cant.
I ran speed tests last night and am now getting around 75/80 when previously I was getting 108 ( i have 100mb but for some reason get 108 )
I'm not trying to be contentious but perhaps working on range and speed rather than bells and whistles for version .48 might be the thing to do ?
N66 owners need to understand the signal and range issues are forever the way it is now because of Asus this is the way they want it. If you want the N66 to be the router it use to be then you need to use older firmware and forget about the new stuff or do like me and get another router.
My AC68U results are similar and I've done what I could to smooth it out. Is there a downside to flashing the. 43 fork or, any additional precautions to take? For my purposes, WiFi signal & throughput are paramount.For me the wifi range is definitely lower (It was best with .43)
What router did you get instead?
Skickat med Sony Z2 via Tapatalk pro
Welcome To SNBForums
